tn70 won't lift
   / tn70 won't lift #1
georaider
new holland tn70
I WAS WORKING CUTTING FIELDS UNHOOKED ONE CUTTER BACKED UP TO OTHER HOOKED UP BUT WILL NOT LIFT.UNHOOKED STILL NO LIFT CHANGED HY FILTER STILL NO LIFT HELP!!
   / tn70 won't lift #2
Do you have the automatic lift system on your tractor? I can't trmrmber exactly how it works but you either have to push the button to activate it or latch it closed to make the 3 pt controls work manually. I don't have the manual for my TD95D handy but I had a similar problem when I first got the tractor and I could not command the lift with the normal lift levers.
   / tn70 won't lift #3
draft control?
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
2010 Toyota Tundra (A50323)
2010 Toyota Tundra...
JMR Tree Boom Skid Steer Attachment (A50322)
JMR Tree Boom Skid...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
Crosley 10ft. Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
