how to get better stability?
/ how to get better stability? #1
BC Dave
Van - S Cariboo; BC
Yanmar YM180D
Im new at owning a tractor; but know that tractors are prone to rolling over. With the yanmars they have a narrow front wheel stance; plus the 4WD "D" series have a floating front diff to make stability even more dodgy. I try to keep the FEL low and I have a rear box scraper that I try to keep that low; also it has a roll over protection bar (ROP) ... no calcium in wheels but not so keen on this idea;
Having a smalll sloping property where Im excivating and move logs around for a cabin. I'v already been surprised and scared to the point I was going to bale when a log shifted to the downhill side and the tractor began to list dangerously.
How to get a wider, more stable stance?
Can I block (or fix/ bolt) the 4wd diff so it doesnt float?
I'v seen posts where the wheels have been mounted cup outward; reverse mounting; but other say that this puts strain on the bearings, steering and drive train; can I reverse mount front rims outwards without doing damage?
what about adding dulies to the front? how to mount them? or front / rear rim extension mounts?
/ how to get better stability? #2
Don't bother trying to add duals to the front. The articulating front pretty much eliminates the usefulness of it, and the added difficulty in steering, and tendency to catch on things and twist out of where you want it to track would seem to make it more dangerous than stable.
In the back, the tractor is designed to run with the rims, hubs and tires at different widths. Designed to: In other words, you're supposed to put them wherever you need them to run. I built a set of spools for the rear of my girlfriend's YM2000. I guess it would have been more stable, but I installed them for additional traction more than anything. Spools or spacer hubs could be used to simply widen the rear track, too. The YM2000 was engineered for the spools; I don't know about the 180 or its Japanese market equivalent?
Go buy a set of inner tubes, put them in the tires, and get them filled with Calcium solution or Rimguard (beet juice). That will help. While they're off, makue sure the offset of the rims and hubs are to their maximum width in the rear. You may be able to adjust the stops to give less axle articulation up front, but you'll need some to keep the machine in contact with the ground.
You may also just be in terrain that is too steep to work that machine, unfortunately. Wheel weights will help, too, but sometimes it's more about risk assessment than equipment.
/ how to get better stability? #3
Dave,
Your wheel bearings are an essential connection between your tractor and the ground. Spreading your wheels (by reverse mounting), adding duallies, or adding weight to the body of your tractor will all stress the wheel bearings. I personally don't think that's really a problem, but if you are worried about that, the only other way to improve stability is to add weight between the wheel bearings and the ground.
Adding ballast to your tires will not stress the wheel bearings. Depending on the size of your tires, it can add a considerable amount of weight right where it counts. If you don't want to use calcium, consider using glycol/water mix (antifreeze).
This is purely my speculation, but I suspect that the majority of roll-overs occur when a just-barely-stable load encounters a surprise. For example, the high-side wheel rolls over a stump hidden in the grass, or the low-side wheel drops into a hole, or the operator makes a really sharp turn with a load raised up high. The best defense against this is to keep your load low, and go slow if you're not 100% sure about the terrain.
/ how to get better stability? #4
I wouldn't try to block the front axle rigid. You will loose traction all the time on uneven ground because all the weight will be on diagonally opposite wheels. RF/LR etc. I know from experience that limited spring travel on a 4x4 steals the potential for what it could be capable of with long wheel travel. Plus it would stress the front components.
And turning the front wheels out puts all the stress out beyond the outer wheel bearing instead of centered between the inner and outer bearing. Snapping a spindle when you are already in a precarious situation would probably topple you. Yanmar's manuals prohibit turning the front wheels.
In summary don't rely on the front to help at all. By the time the front axle hits its stops a rear tire will be off the ground, so with no traction for engine braking, the tractor is rolling forward out of control.
Swapping the rear tires out for maximum width is recommended in the manual.
My opinion - cast weights flush to the outer edges of the tires gives the best rollover stability in theory. Water fill in the tires is good too but the unpredictable slosh isn't quite as good as solid weights.
Of course dualies on the back will be effective, and well made spacers too. Maybe smaller rear tires (turf tire option) to get the CG down?
Wow - I see while I was drafting this everybody quicker answered your question. Oh well, FWIW.
/ how to get better stability? #5
Just switching the rear tires around got me an extra 4" of width (to add to 44" on my YM1700) with no cost and very little effort.
/ how to get better stability? #6
Doesn't answer your question but if stability while using your loader in the area you are working is an issue, you could do what I did in my old 9N days and skid the logs using a boom on the rear 3 point to a location where your tractor is stable such that you can move them with your loader.
Terry
/ how to get better stability? #7
Your first sentence says a lot. Once you learn where the hazard points are with your tractor your "seat" will feel a lot more comfortable. When I am traversing a new slope I take it slow and easy until I see/feel how the tractor behaves. Keeping loads at a low center of gravity is always wise when moving. One way to increase your stance is to put wider tires on the front. Gives you better flotation also. The tires in this pic are 2" wider than the originals. I am pleased with the results although I am still careful on hills.
/ how to get better stability? #8
In addition to the suggestions above for setting your rears wider apart, I'll add the possibility of getting wider rear tires. And I also recommend rimguard (aka beet juice) for filling tires. The only reason IMO not to fill your rear tires is if you want to minimize the weight of the tractor (presumably to prevent compacting the dirt/turf you drive on). The stability added by filling tires or adding wheel weights is quite noticeable.
No amount of changing the width of the front will change the balance point of the tractor where your rear tire will lift off the ground.
/ how to get better stability? #9
Yes, there are several things you can do. The front end becomes a lot more stable if you change over to wide round "turf" or "industrial" profile tires instead of the cleated Ag tires. Those changes require a different rim. And you want to retain the proper front/rear tire ratio to keep the 4wd happy. Other than a rim+tire change, I'd leave the front alone.
The rear tires can be spaced out to full width and reversed for even more width. I've also seen Yanmars with dual tires on the rear. Any tractor shop can show you how to do that.
My YM336d has the widest turf tires made, reversed and set out as far as they will go, and then mounted on spacers a couple of inches thick to put them out even farther. Coupled with fat turf tires on the front, I'd say it is just now getting to be reasonably stable.
Yes, all of this obviously stresses the rear bearings more, but the Yanmar axles are large, strong, well supported in large bearings mounted in thick castings. If you read back through a few years of messages, I think that you will find very few rear axle or bearing problems. I can't think of one offhand....though I do remember problems from overloading the front axles.
Goodluck, rScotty
/ how to get better stability? #10
I put duals on mine for floatation on the beach but the added benefit was it is incredibly stable. I never really appreciated how stable it was as I put them on as soon as I got the tractor until I spent some time without them.
Last winter I put a few hundred hours on a larger(L48) tractor and even with the rear tires filled and set to their widest it was not near as stable as my little l2800.
I will be doing a bunch of logging with the L48 this next winter and will for sure put duals on the rear and probably on the front too for the mud.
Rick
Rick
HA someONE did the dulies!
Thanks for that and all the above advise.
I beleive I have a wider set of rear ag tires; than the narrower rice tires; the rears are set at there widest stance ...
yes i do need to get more familiar with the tractor and its limits; and learn not to not push the limits; but I was being carefull when i got a scare ... It does have ROP bit I never want to have to rely on it ...
wheel balast does seem to make sense ...
thanks all; gives me lots to consider
/ how to get better stability? #12
I'll second the vote for duels. It's unbelievable the amount stability it adds.
/ how to get better stability? #13
Here is an idea i saw at one of my local state parks. They had a 5000 series JD and used about 5-6 wheel weights on the up-hill side of the tractor. Drove it on a pretty sloped area with the weights up hill and it did not even look tippy. This was a pretty good idea so they could flail a new trail through a meadow and since it is wheel weights, they wouldnt put excess stress on the axle, just the rim and the tire which would have to have proper pressurization. I got a few ideas, but this is probably the easiest because my tractor has the same problem. :)
good suggestions;
Ideally I'd have front dulies with wheel weights ft & back; but am still concerned with the ft wheel bearings.
Or the other consideration is getting front turf tires that are wider.
also Im tempted to block the floating ft 4WD axel so It has less side to side sway.
Cost is a consideration in all this.
Cheers Dave
/ how to get better stability? #15
I don't think it's a good idea to completely block the front axle movement. My International has a LOT of axle movement, by design, clearly, but it's a lot more than the Yanmars I own have. Were I working in some of the terrain I've seen, I would back the stops out a little bit, to more like what my Yanmars have. I'll make up a number and guess 15 degrees, rather than the 25 or so it seems mine will achieve.
If you have no articulation in the axle, everything you hit will be tipping your machine over. If the rear of the tractor is on some obstacle, the hinged front axle will let the machine flop; my International will flop further than the operator could stay in the seat. I don't think that's true of my Yanmars.
A major problem I see is the idea of "finding the limits" of the machine. Statically, the tractor will tip much farther than any operator should be comfortable sitting. When moving, the forces are so incalculable that I don't see how an operator could find the limits without reaching them. Reaching the limit on a slow steering, no reserve acceleration or power tractor is going to mean a rollover.
The cheapest thing to do is move the rear hubs out as far as they will go. Set up your rear wheels so that they are spaced to maximum. This will also help the most. Then, change what you're doing that makes things risky. As was suggested, don't skid logs with the loader. I've seen people who have built small logging arches for the three point hitch on little tractors. This seems to give them much more capability, safer operating conditions, and less abuse on the tractor.
Then, fill your tires with your choice of liquid ballast. If you don't like calcium (I don't like the idea either, and don't use it), try windshield washer fluid or beet juice, sometimes sold under the brand name "Rimguard." If you can, buy or make cast wheel weights. If you can't safely do your job with those three changes, and still have a reasonable safety margin, then you'll have to do something to change the operating conditions. That may mean a different tractor, or spending a few days cutting better access routes where sideways operations aren't as prevalent, or whatever.
/ how to get better stability? #16
Where can you get spools or spacers for the rear wheels on ym1500 yanmar?
/ how to get better stability? #17
I built my dual wheel spools, and some others here have done that as well.
did my fronts myself and got the rears from unverferth.com
Rick
:thumbsup:
nice job on your dullies;:cool:
... SOOOOO ...
how-d ya make the front dullies?;
and could you post some pics of your setup? (i am squinting at your avaitar but cant see the details ....lol.
/ how to get better stability? #20
Some things that I did to make my Yanmar more stable on side hills.
I have filled the rear tires w/ beet juice. It helped. I also found it helped the Yanmar to put a little dirt in the loader and run it real low to the ground when mowing. Conversely, when using the loader on hills, I found it helps the stability to attach the mower and raise it just off the ground, just for some low slung weight. (makes maneuvering around much harder, but does make steering a bit easier when the bucket is full).
In the end I have given up mowing with my Yanmar because it still has stability issues on my significant side hills. I use my old Ferguson TO35 for mowing instead. On hills where the Yanmar scares the bejesus out of me, the much wider tread width of Fergy doesn't even cause me to raise an eyebrow.
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
Frontier Forks (A64126)
Frontier Forks...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
More info coming soon (A61569)
More info coming...
