red hot muffler on LT1045
/ red hot muffler on LT1045 #1
lil_country
Central Oklahoma
2006 B3030 & 2006 Cub Cadet LT1045
I just bought a used LT1045. Today my wife mowed with it for the first time. She had been mowing about 30 minutes when I noticed that sparks were coming from the muffler. I had her stop, and on closer inspection I could see that the muffler was bright red. It was so hot that the front tires were hot. Any help diagonsing the problem would be appreciated.
/ red hot muffler on LT1045 #5
Is it a few years old? I'm wondering if something is loose around the intake or cyl head letting air in and leaning out the air/fuel ratio? Some early Courage singles had issues with bolts loosening up.
It is a 2006 model, but has very low hours. It is also a 2 cylinder model. I'll try adjusting the mixture and see if it helps.
/ red hot muffler on LT1045 #7
Also be sure there are no mouse nests under the shroud, assuming this is air cooled.
/ red hot muffler on LT1045 #8
Good call there. I haven't heard of a single issue with the Courage V-twins. I owned a 20 and loved it.
If there was a nest, there would have been flames. That muffler was about to melt down.
I've adjusted the fuel mixture. We will see if that helps. Thanks for the response.
/ red hot muffler on LT1045 #11
Every single time I've had a problem with an overheating air-cooled-engine it has been a problem with timing. Check the timing next, if what you've done so far has no effect.
/ red hot muffler on LT1045 #12
Had the same problem one time... ended up being a blown head gasket causing it to run lean...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
Gehl RS5-19 (A62177)
