red hot muffler on LT1045
   / red hot muffler on LT1045 #1
lil_country
Central Oklahoma
2006 B3030 & 2006 Cub Cadet LT1045
I just bought a used LT1045. Today my wife mowed with it for the first time. She had been mowing about 30 minutes when I noticed that sparks were coming from the muffler. I had her stop, and on closer inspection I could see that the muffler was bright red. It was so hot that the front tires were hot. Any help diagonsing the problem would be appreciated.
   / red hot muffler on LT1045 #3
What engine is in this LT1045?
Kohler Courage 20
   / red hot muffler on LT1045 #5
Is it a few years old? I'm wondering if something is loose around the intake or cyl head letting air in and leaning out the air/fuel ratio? Some early Courage singles had issues with bolts loosening up.
It is a 2006 model, but has very low hours. It is also a 2 cylinder model. I'll try adjusting the mixture and see if it helps.
   / red hot muffler on LT1045 #7
Also be sure there are no mouse nests under the shroud, assuming this is air cooled.
   / red hot muffler on LT1045 #8
Good call there. I haven't heard of a single issue with the Courage V-twins. I owned a 20 and loved it.
If there was a nest, there would have been flames. That muffler was about to melt down.
I've adjusted the fuel mixture. We will see if that helps. Thanks for the response.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2016 FREIGHTLINER CASCADIA DAY CAB (A52576)
2016 FREIGHTLINER...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
FRONTIER LR5060 LOT NUMBER 148 (A53084)
FRONTIER LR5060...
