Zero Turn Mower?
/ Zero Turn Mower? #1
vettebob1
I 'was' looking at a 'garden' type tractor. The reason being is I live in the mountains, so to speak, and my 1/2 acre of mowable area needs a machine that can handle the inclines. In my attempt to measure the slope, using the page in an owners manual, I have just less of 15 degrees mostly with one area that might be the 15 degrees and maybe a tad more. I was told by the John Deere dealer NOTto consider a zero turn mower. He said I needed at least a X320. So for the last week or so I have been investigating Cub Cadet, Sears 'garden' type tractors....due to the heavier duty transmission.
I went to the ExMark dealer who also handles other brands and told him about my incline and he immediately shows me the Zero Turn!!!! I said why are you showing me this? I was told NOT to look at these and I did tell him by whom. He kinda chuckled and said he would not say anything negative about the JD folks. His reasoning sounded legit about why a zero turn. 1) the engine is in the rear which puts the weight where it is needed for inclines. 2) the machine is built with a low center of gravity (the John Deere place was going to put fluid in the tires to keep the center of gravity low?) 3)the driver is in the middle not at the end of the machine.
So what do ya'll think? With my incline is the Zero Turn a good choice? The eXMark is kinda expensive but maybe not that much more than other 'good' ones?
I look forward to the responses.
/ Zero Turn Mower? #2
:welcome::welcome:
ZTRs can be problematic on high slope angles - especially units that do not have a brake as most don't (Kubota and JD are exceptions, though Everything Attachments does sell an after market setup for the front wheels of other brands). If there is any question in your mind about safety, by all means demand a test drive on your own property before commiting to a purchase.
PH
/ Zero Turn Mower? #3
ZTR is NOT made for steep slopes. Too much weight at the rear.
A nice garden tractor would fill the bill nicely. I would recommend something from the Simplicity line. Nothing cuts a better lawn.
/ Zero Turn Mower? #4
I would have to agree that a garden tractor style would likely be a better choice in the situation you described.
Lots of different makes and models out there, so good luck choosing what works best for you.
/ Zero Turn Mower? #5
My experience has only been with the 38" and 32" Toro ZTRs. They're great on dry, level ground and not worth a flip on any slope or damp grass. I can sure get stuck easily.:eek:
/ Zero Turn Mower? #6
The main point to remember regarding use of the typical zero-turn mowers (mid deck, deck under machine) is that when you lose traction - you also lose the ability to steer. It's different strokes for different folks. Some people feel more comfortable on inclines with a ztr and some prefer the tractor-style. As PossumHound mentioned, nothing beats a demo on your property - an experienced ztr operator would be welcomed also.
/ Zero Turn Mower? #7
I have a Cub Cadet Tank-S model S6031 that will hold on an incline of alittle over 18 degrees with no slip at all. Excellent machine if you are looking for a zeroturn that will hold a hill. I have found no problems with this machine so far and am well pleased with it.
/ Zero Turn Mower? #8
I agree with possomhound 100% the markup on these machines is huge so get the dealers to come to you with their machines and try before you buy! Your property sounds to be quite the chalange for any machine and a reputable dealer will be happy to bring a couple of machines to you for a test drive. And on that drive you do the drive and challange the machine. When you are finished with a couple of machines your question will be answered and you will have your machine. And if a machine screams at you "I am yours" write a cheque, get out the cash or what ever method is your choice, shake a hand smile and say thank you. Oh ya, dont forget to thank any other dealer that shows up with macines that dont measure up.
/ Zero Turn Mower?
I have posted several sites. It is quite confusing. Tractor? ZTR? People have their favorite.
I will go with the advice of 'bring it out here and test drive it'.
The model I have been directed to is an eXmark 'Quest'. It seems sturdy. It is the residential model so it is not huge. It has a 44" deck which is more than enough for my needs. Plus it weighs as much as the garden tractors; maybe more than some.
The 'garden' tractors are 54" decks and are 'large'. But to get the 'tranny' that is what I had/have to look at; one was only 46".
Need more thought on this I guess.
thanks
/ Zero Turn Mower? #10
A Zero turn for a half acre is over kill like using a semi to haul 1 tooth pick.
/ Zero Turn Mower? #11
The best advice I can give is to have a dealer bring the unit out and try it!! Degree of slope is an objective measure, but YOU need to get on the machine and see if YOU feel comfortable and safe. There is quite a difference between ZTRs.
Will
/ Zero Turn Mower?
OK, what do you suggest instead?
I have been using a Toro personal pace and it takes me 1 1/2 hours to do. I'm 65 and in decent shape but admittedly I would rather use something else. I'm told the cheapies ain't goin' to work. So yes I have to pay a premium price to do it myself. So what do you suggest?
/ Zero Turn Mower? #13
I have a Deere ZTR and it works fine for me. HOWEVER it does not handle steep slopes well, especially going down. I'm with the others - try one out at your place before making up your mind.
As much as I like mine, your situation sounds more like a garden tractor to me
/ Zero Turn Mower? #14
Don't tell a man that a power tool is over kill! I subscribe to the Tim Allen this thing needs "more power!" theory.
/ Zero Turn Mower? #15
I agree with the others on a good garden tractor, but for the price of a commercial ZTR $7-8k you can get a decent small Kubota/John Deere/Massey/Cub Cadet machine with a deck and 4WD.
Then if you need to do snow in the winter add a FEL, and so on.. Depends on your situation - a ZTR is a single season machine, but if you get a good small 4WD unit it works in all seasons with the right attachments.
As for slopes on a ZTR 15-18* is not an issue for a short inclines/slopes, but for 1/2 acre with variable or long slopes I would seriously consider a multipurpose 4WD machine than a ZTR.
/ Zero Turn Mower? #16
BINGO
Use a ZTR on a steep slope make sure you potential ending zone is a place you are OK landing in. Before you totally loose the ability to steer you need to get it starting to nose down and hit it hard to regain some control.
It needs to be treated like a stall condition in a plane. You have to keeping moving at a good rate of speed to have steering control.
/ Zero Turn Mower? #17
I'd have to agree that a ZTR for a half acre is overkill.:laughing: But I'm 71, it's hotter'n you know what in Texas in the Summer, so I recently traded from my Toro personal pace mower to Toro's new 32" ZTR, and I'm living in town on a 70' x 170' lot.:laughing: I do help out some neighbors a bit (81 year old living next door) and even take it on a trailer to a daughter's place. I've got 13 hours on it now.:laughing: And I even spent the money for the bagging kit to use in the Fall for leaves and in the Spring when I scalp the lawn on the first mowing. Expensive? Darned right, but probably less than a lawn care service would charge me.
/ Zero Turn Mower?
I want to thank everyone for contributing their opinions? It truly has been informative. I have been posting to several forums to try to garner as much info and beliefs as possible. The lawn mower forum has pretty much sided with the Zero Turn (but was not too much in favor of the Quest?. The Tractor Forum(s) have pretty much sided with the garden type tractor. But?I suppose that should have been expected from each group. I thank KennyV for the video link; that was very enlightening.
The video kinda took me by surprise. But not for its information. The slope was said to be 16 degrees and from the viewing of it, it did not look that scary? When looking at my slope it looks a tad scarier than in the video. Soooooo, that got me to thinking?. I don't know how to measure a slope? I copied what was in the owners manual for measuring a slope. I took my level with me, this time, and aligned the sheet of paper with the level and took a reading. I came up with 15 degrees again with the one area slightly above that?.maybe 16 degrees or a tad more?? Maybe viewing a video is not the same as being there?
Anyway?I am at a cross roads again. The muscle of the tractor is impressive but one does sit higher than on a ZTR; which infers the center of gravity is higher? Maybe that is why the John Deere rep said that I would need to put fluid in the tires to lower the center of gravity? That does not make me feel self-assured. The ZTR looks like you are closer to the ground (the rider) but the video showing the sliding did not instill confidence either; but I realize he was forcing the issue. With the eXmark the hand brake I believe is down by the feet?not good. And there is NO foot brake.
I know the walk behind mower will work. But at 22" that takes a long time. There are other options of walk behind 26-33" but they are monsters with all sorts of hand controls and stuff you gotta do and on a slope that does not instill confidence either.
I realize my situation requires I get off my wallet?which I'm having a tuff time doing. I see so many tractors and ZTR's at around $2K, +/- , but none of them can work in my situation?so I'm told. Spending $3,500 minimally and more than likely over $4K+ is hard to accept.
For those of you who recommend used??there is absolutely nothing available within 100 miles of here?.I've called/checked.
I guess I'll be walking a bit longer unless other opinions/views sway me.
Thanks.
/ Zero Turn Mower? #19
I have an old, bought in 1989, White FR-12 zero-turn with 52" front deck. I use it to mow the ditch by the road that is about a 30* incline. Absolutely no problem as long as I mow horizontally in reverse. If I try to mow forward it tends to slide down the hill. This has been a fantastic mower. In fact after White was bought by MTD they sold the design to Ingersoll. They continued it as the Grazer. They now have sold it again, to Zipper. Check it out at Zipper Zero Turn Mowers - Home. They are made in Wicita, KS.
MrHiggins
/ Zero Turn Mower?
Sears is selling the GT6000 'garden' tractor for $2650+/-:confused:
It has the Hydro Gear G730 tranny.
What to do:confused:
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
2015 Ford Fusion Sedan (A64557)
2015 Ford Fusion...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
