Zero Turn Mower?
/ Zero Turn Mower? #21
ZTR is NOT made for steep slopes. Too much weight at the rear.
A nice garden tractor would fill the bill nicely. I would recommend something from the Simplicity line. Nothing cuts a better lawn.
It sounds like he is on a far smaller budget, but I beg to differ with your statement. I can easily mow inclines with my front mount Grasshopper ZTR mowers where you cannot mow with a 4X4 tractor! I can mow up, down and sideways no problem. A mid-mount ZTR is a funeral waiting to happen on steep slopes. Put the engine in the rear with the drive wheels in the rear....well, you better have a good roll bar, your seat belt on tight and be wearing a good fitting pair of Depends! A mid-mount ZTR is not suited for steep inclines. A front mount is designed for such. I've mowed hills you cannot walk up, stopped, backed up to get a spot I missed, and went on up the hill no problem. It is impossible, yup, impossible, to back flip a front mount ZTR mower.
Garden tractors are narrow and have weak transmissions; never made for continious hard pulling. If you don't roll one like a tumble bug down the hill, you'll ruin the tranny every few months. There is a right tool for every job. You just need to use the right tool.
/ Zero Turn Mower? #22
I agree with dargo on the front mount ZT. i have a kubota ZD21 60" now and I love it. It really does a good job. I went from a front mount woods6180 and i can tell you from experience that the kubota( i love this thing) will not go on a hill the way a front mount would. I do not think you could roll a front mount either sideways or up or down.
/ Zero Turn Mower? #23
Sears is selling the GT6000 'garden' tractor for $2650+/-:confused:
It has the Hydro Gear G730 tranny.
What to do:confused:
Be aware that Hydro-gear is the brand of transmission Cub Cadet used in the 5000 series that has had so many failures, including mine......
Totally agree... Unless you have flat land, you need a FRONT MOUNT mower.
/ Zero Turn Mower? #26
We found ourselves needing the drive motor belt and the deck driving belts for our ZTM. The local O'Reilly's Parts Store the 1/2 Powerated Gates line in 1" steps based on my under standing. I know we got a 47 and 84" belts. Powerated are the Green colored belts made for applications that has flat idlers that bends the belts backwards. The standard black fan belt types will break over time when used that way. I think the 47" was about $15 and the 84" was about $23.
V BELTS FOR BACK IDLER AND CLUTCHING APPLICATIONS - ruflex & PowerRated - V-BELTS FOR BACK IDLER AND CLUTCHING APPLICATIONS | Gates Corporation
The deck belt looks OK but the OEM belts only made it 50 hours. The initial owner just uncrated and used without checking belt tension. We would have picked up the deck belt but I forgot the look up the size because we were in a rush to get to town and back to get one area mowed today.
/ Zero Turn Mower? #27
Try the eXmark (preferably on a damp day). I have run their commercial machines (Lazer Z w/60 and 72" decks) on some fairly steep slopes. They are good machines and will go places I wouldn't take the Cub Cadet GT3200 that we currently have. If you can pick the nose up easily, you might want the front weight kit, but eXmark makes good equipment.
When mowing a steep hill, you want to back up and go down frontwards.
Aaron Z
/ Zero Turn Mower? #28
Good call. I WILL NOT purchase a "standard fan belt" for the snowblower or the mowers at work because they don't hold up. A wrapped belt will outlast them by 2-5x.
Aaron Z
/ Zero Turn Mower? #29
Second that.
/ Zero Turn Mower? #30
For those of you who recommend used??there is absolutely nothing available within 100 miles of here?.I've called/checked.
I guess I'll be walking a bit longer unless other opinions/views sway me.
Thanks.
For what its worth I just picked up a Exmark Lazer Z (200 hours) for less than the price of a new quest or cub cadet ztr. Be patient and search craigslist.
At the end of the mowing season landscapers try to unload some equipment.
I was planning on waiting and buying a high mileage walker but the Lazer seems well built and was not used commercially -- just at a Mcmansion.
I also talked to a landscaper with a deere ztr who loved it but kept a small tractor on his trailer for steep slopes -- said he couldn't control the ztr on some steep slopes. I've also got some hills but have yet to try to mow the lawn -- I'll let you know how it goes w/ the exmark
/ Zero Turn Mower? #31
I believe a lower end residential ZTR will work just as good as the expensive ones. It's just that they aren't going to hold up to the wear and tear as well. If you're only doing 1/2 acre per week, save your money.
/ Zero Turn Mower? #32
I've heard the statement many times that ztr's are terrible on slopes. My personal experience is the opposite. My property is mostly flat, with the only sloped areas being where the property meets the road at the lot corners. These areas are about 5'-6' below the road surface with the hypotenuse being about 10'-12' in length. Don't know what % grade that makes it as I don't feel like dusting off my trig. Anyhoo, I own a Dixie Chopper Silver Eagle with Turf Boss III tires. I can stop, back up, turn, drive up, down and across while on these slopes without any traction problems whatsoever. I will say that these tires can be a bit of a double-edged sword in that when the ground is really wet, any semi-aggressive turn will tear the turf up pretty good. When it's dry, no problems at all.
Google Image Result for http://blog.blackhawklawn.com/wp-content/uploads/2011/06/97200.jpg
/ Zero Turn Mower? #33
I have a Ferris ZTR and a Craftsmen. I will use the ZTR for everything EXCEPT on the slope that goes down to my lake. It just does not feel as stable in that situation.
2006 Chevrolet TrailBlazer SUV (A64557)
2006 Chevrolet...
2013 Buick Verano Sedan (A64557)
2013 Buick Verano...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
PALLET OF GANDY APPLICATORS (A64278)
PALLET OF GANDY...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
