Northstar Generators---- Beware!!!
/ Northstar Generators---- Beware!!! #1
HCJtractor
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I shopped for a large generator for several months and finally decided on the new line of Northstar generators from Northern. These new models have just been introduced and were said to be improved. I did like many of the features as compared to the old ones, including a newly designed Honda engine, a metal gas tank, and a better frame. I ordered a 13,000 watt model. Boy, that's when my troubles began. Soon after ordering it, I found they had been recalled because of a "gas cap issue." After another month of waiting, my local dealer finally released one. He installed the battery, fired it up and found it to be defective. So he unboxed another one, and it was not much better, but he told me how to play with the choke to make it work. After I got it home, and tried to power my small welder, the same issue arose. It would rev up and down and voltage fluctuated wildly. After numerous calls to Northstar, they suggested having my local technician work on it. For a $2600 generator with less than 5 minutes run time, I was not happy. Also, there is no technician at my local Northern. Luckily, my local manager had pity and refunded my money. They admit there have been numerous problems with these new large generators, and they expect them all to be recalled. So beware. I would wait if you plan on getting one. The kinks are obviously not worked out. The glowing review online is bogus and they denied publication of my poor review. So much for honesty.
Ended up buying what I should have gotten all along---a blue Miller Bobcat 250. Works great!
/ Northstar Generators---- Beware!!! #2
Another one knows about NT, and found out the hard way.
I'd put HF in line above NT.
/ Northstar Generators---- Beware!!! #3
Yep, had a similar story with an ETQ generator form Northern Tool...I ended up throwing it away...:mad::mad::mad:
/ Northstar Generators---- Beware!!! #4
Dang it. I was really hoping these were resonable in the quality department because I was thinking that I would want one.
The electricians that given me quotes to upgrade to 200 amp service ALL recommend Honda generators, though they are expensive :(
~Kevin
/ Northstar Generators---- Beware!!! #5
~Kevin
Generac gardian house generators are nice units also, and i cant fault the Hondas. I have an Onan myself, and have had 15 years of carefree service with it.
/ Northstar Generators---- Beware!!! #6
my 7 yr old northstar pto gen is doing fine.. sounds like the gassers? maybee the engines? are having an issue.
bad governor perhaps?
soundguy
/ Northstar Generators---- Beware!!! #7
Who makes the motor on a Miller Bobcat 250?
/ Northstar Generators---- Beware!!! #8
Just as an 'aside': We have people up here getting Natrual Gas Generators. Keep in mind that you may need a larger Meter Setting that will service the larger draw, and that gas consumption may reach $75- a day...............food for thought.............know what your getting into..........~S
/ Northstar Generators---- Beware!!! #9
also i install lots of gensets, and i truly feel an automatic transfer switch is a waste of money. if no one is home, why run a generator. Mine is set up with a battery start from indoors and a manual bypass. works great, easy for the wife to use and it wont run for 8 hours while were at work. Mine runs on propane
/ Northstar Generators---- Beware!!! #10
also i install lots of gensets, and i truly feel an automatic transfer switch is a waste of money. if no one is home, why run a generator ?
Ummm .... how about a freezer (or two) full of food ?
/ Northstar Generators---- Beware!!! #11
Our power goes out all too often. I'm shopping for a generator and automatic transfer switch now. I would be fine with a manual start, manual transfer system if it was just me here, but my wife has no interest in starting a generator and operating a transfer switch.
Last summer the babysitter came to care for my daughter so a couple of friends, my wife, and I could get out to see a concert. We didn't get twenty minutes from the house when my cell phone rang and the babysitter reported that the power was out. Without power there's no cooking, water is limited to whatever happens to be in the pressure tank when the power failed, no water heater, etc. We turned around, I got out of the car, and my wife and friends headed back out to the concert while I stayed home and tended to the 5k portable generator. These are the kinds of situations where the automatic system shines. If I had one then, the babysitter would have thought that the power went out for a minute and came back on. She might have noticed the gray box out back humming, or maybe not, and I would have enjoyed the concert.
I guess it's all about deciding how much that convenience is worth to you.
/ Northstar Generators---- Beware!!! #12
A freezer can keep food frozen for over 24 hours as long as no one opens the door. I know this to be true, as we have power outages here all the time. New freezers even longer.
/ Northstar Generators---- Beware!!! #13
ok... but dont complain to me when it burns all that fuel ...hehe. It depends on the size of the unit your getting also. To run wells and electric heat/waterheaters...your looking at a large unit.
/ Northstar Generators---- Beware!!! #14
So after 24 .... whadda ya figure - call all the neighbors and invite them over for a cookout/pic-a-nic ? :laughing:
Ok, I won't .... (we're on a 250 Mcf free allocation per year :D .... and we only use around 100 -115 Mcf per year to heat our home ;))
/ Northstar Generators---- Beware!!! #15
I keep toying with the idea of getting a Kubota diesel generator. Don't have NG and propane trucks are not getting up my driveway in the winter so if we loose power for more than a couple of days I'd have to be switching to portable tanks. My current honda powered Generic has served me well but at 4500w it's just enough to turn the well pump on. Plus that engine running at 3600 rpm gets tiresome.
/ Northstar Generators---- Beware!!! #16
im confused, all i said was it didnt have to run for the 8 hours im at work. i can start it up when i get home. Ive been doing this for 15 years, and ive never lost any food yet.
/ Northstar Generators---- Beware!!! #17
yup, thats a problem. i have installed large generators capable of powering up an entire 200 amp service on some of the large lake houses here in Idaho. they all run on large diesel tanks, and you have to keep a path clear for them. these do empty a tank full of gas pretty fast. Some people put in 500 gal diesel tanks, but I'm not sure how long they would run on that size tank. never did the calcs.
/ Northstar Generators---- Beware!!! #18
The secret is keeping the Freezer full to capacity and not opening the door and having it in a cooler area helps...
My friends were plagued with power outages and they would keep empty one gallon milk jugs and two liter soda bottles filled with water in the freezer is there was room.
They had both water and a cold source... power was out two days and the chest freezer and upright freezer had no problems...
/ Northstar Generators---- Beware!!! #19
good idea about the water. I have had mine without power for over 12 hours and i never noticed any difference in the frozen foods. they usually never go for less than 8 hours without power. A refer is a little harder to maintain, but its usually only milk, mayo etc that you need to worry about
/ Northstar Generators---- Beware!!! #20
Keeping frozen bottles of water is always a good idea as a freezer is more efficient when it's full. And, like you said, if the power goes out a full freezer will take much longer to defrost.
KMC 6-36 (A64119)
KMC 6-36 (A64119)
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2019 John Deere 712C Cornhead (A63111)
2019 John Deere...
