Northstar Generators---- Beware!!!
/ Northstar Generators---- Beware!!! #41
The new miller bobcat 250's are powered by Kohler and Subaru. Both 23HP. Rated at 11Kw. If you go with the EFI option it has a 12Kw power out with the same motors. Great machine. I just pick one up this last weekend. Have a 225nt with about 795hours but found that for running as a generator wouldn't hold speed close enough for my tastes. Besides it gave me a reason to upgrade and buy a new toy:)
It's too bad that the diesel 250 is so expensive. I just can't justify an extra $2500 to have the option to weld.
/ Northstar Generators---- Beware!!! #42
Ummm .... how about a freezer (or two) full of food ?
Yeah, getting up to the lake home after a few days without power can leave you with a stinking mess. And it takes weeks of treatment with activated charcoal to get the smell out of the fridge and freezer.
Ask me how I know.............
/ Northstar Generators---- Beware!!! #43
if it was a cabin or weekend home than i can see it, the ones i install units on are all full time lived in homes for the most part. The summer rentals are empty and water off when owner not using them.
/ Northstar Generators---- Beware!!! #44
-crazyal- I agree with the pricing. The difference being a bit more conservative with the fuel (and not by much) and dealing with a bit more noise. What blew me away was when I told my wife I wanted to replace my 225 her response was "go get it". I think she was so ecstatic that I asked her instead of announcing "I'm going to go get it". Maybe after 32 years I'm getting the hang of marriage:)
/ Northstar Generators---- Beware!!! #45
After using smaller generators for years I finally got tired of them after Hurricane Ike. No power for 8-1/2 days. I looked around and finally settled on an INDUSTRIAL diesel 16 KW Isuzu. It will run my well, air conditioner, lights, TV and water heater. I do have to juggle a little as it won't run all at the same time but it's not inconvenient. Really nice to have a/c and water during the summer. Keep a 400 gallon tank of fuel full with biocide and Pri-D. Got fuel for the genny, tractor, pickup and motorhome. Now if the trees don't do me in life is good.
/ Northstar Generators---- Beware!!! #46
it won't run them all at once?
you must have a huge ac, HUGE well, and way too many lamps ( to be on during a power outtage ).
since most water heaters only will pull 5kw incandescent load.. that leaves 11kw for other stuff. well kick on my pull up to 6.5-8 to start.. but probably run at more like 2-3.. ditto on ac, and air handler shouldn't be too bad either.
as long as the well, ac and a ton of other stuff don't all hit on the same cycle.. it -should- carry it.
unless that 16kw is a surge rating, and it's steady statre is much lower.. like 12 or something.. ( or you got monster appliances and are trying to light up the entire neighborhood during the power outtage or something.. )
my 12.5kw genny does my well, ac, air handle, water heater and whatever lamp / radio we are in the room for. ac is 12 seer.. well is submersed.. doubt it is more than 1.5h.. etc also runs a chest refer and fridge.. which we don't continously open..
soundguy
/ Northstar Generators---- Beware!!! #47
I could care less about freezers...they are good for at least 24 hrs when not opening them. I care about my sump and sewage pumps running.
/ Northstar Generators---- Beware!!! #48
soundguy
The first Hospital genset I worked on was at a small, 2 Operating Room facility that used a Winco 5 KW natural gas unit...
More typical today with smaller facilities of say 40,000 square feet and maybe 6 operating rooms are 125 KW prime rated/ 150 KW Standby rated Diesel sets and even then the normal loads tend to hover around 25 KW...
Seems like a costly and unnecessary proposition for homeowners to go with a big genset in terms of initial cost, fuel costs and maintenance.
/ Northstar Generators---- Beware!!! #49
bigger is better the American trend!
the little 3000 watt honda gen. works pretty good on a 21x24 foot cabin. granted A/C and microwave can not be ran at same time. and at moment there is no well yet, and eventually a larger gen will be installed with most likely a propane setup.
but using the little gen, has caused a large change in how things are done. once yet get use to it. it becomes pretty good doings.
as far as auto transfer switch. for me, if placed on the house, i would need it. and would make more dollar sense. due to having fish, to other animals. that need pumps to keep them alive. at moment using battery backups used on computers to deal with power outages for animals.
but when you start getting into units with auto transfer switch. you can also get into better line conditioners / surge suppressors already built into whole house generators. and initial load demand vs running demand. perhaps automatic weekly turn on / turn off after 15 minutes of running to make sure all is good, for me, with the eletronics. making sure there is no large spike in the power or not having enough (brown outs) is a big problem, due to they can quickly kill electronic stuff. (computers, tvs, phones plugged in, internet, yes even microwaves, etc...)
on other hand, having a manual option to turn on a gen, does make good sense. *shrugs* it competely depends on needs.
as far as fridge and freezer. keeping them closed and not using them... while power is off. just does not happen. food and drinks are all there. the separate deep freezer on other hand. is a different story. once a day if that it might be open. so keeping it full so it stays colder long works without power.
/ Northstar Generators---- Beware!!! #50
if I didn't have a farm.. I'd likely only have a 6.5kw genny.. but with the farm, the extra KW is nice.
soundguy
/ Northstar Generators---- Beware!!! #51
soundguy
Your right... generally lots of motor loads on a farm to take into account.
/ Northstar Generators---- Beware!!! #52
After 10 years of debating, I finally bought me a larger diesel generator as well. The trouble was that all the units I was finding were powered by Chinese knock off diesel engines and no-name gen heads. I bought a 55 KW Yanmar unit with all Deep Sea electronics and auto transfer. It took two electricians to prove to me that buying a 20 to 25 KW (very minimum size for my application) would not save me any fuel over the much larger unit. Unless I'm drawing over what the smaller size could put out, my larger generator actually burns the same amount of fuel since it's working at such less capacity and I have the ability to run absolutely everything as normal.
After having a couple of ice storms and a tornado that left us without power for weeks I'd pretty well had it with a tiny 8.5 KW Honda that only let me run lights, fridges and a furnace. With a family member having unexpected health issues recently, I cannot have my home without A/C during our typical upper 90 degree days with high humidity. According to the electricians, the power from my generator is cleaner than from my utility company, so no worries about electronics. I've toyed around with the settings and now have it set to "exercise" for 1/2 an hour a month and wait 5 minutes without power before coming online. We get lots of short outages and I see no need for it to kick on for them. If the power is out for over 5 minutes, it's generally gonna be out for a while.
After looking and shopping for so many years, I ended up knowing more about generators than many of the online sellers. I mention that because you need to be cautious of some claims made by come companies about their generators. I can't decide if I want to sell my "old" (only about 5 or 6 years old) little Honda generator or not. It's a great little generator and portable. Otherwise, I'm very satisfied now (after 10+ years of debating how to go) with a reasonable sized diesel generator. I'm in the New Madrid fault zone and if we had a bad quake, a natural gas generator would be worthless since gas lines would likely be out for months. I have 6 months of food, about a million gallons of water and at least a months worth of power (before having to refuel) ready.
Oh, I forgot, the "larger" Northstar generators did NOT have engines that I'd be comfortable trusting. Not all Chinese stuff is bad. That is a proven fact. HOWEVER, if price is the main factor, the Chinese sure can build some junk knock-off stuff.
/ Northstar Generators---- Beware!!! #54
Every Natural Gas Genset I've come across can also use Propane and vice-versa...
Most of the Hospitals go with Diesel because the likelihood of being able to refill during a long term outage is greatest with Diesel...
The Natural Gas Units sure do burn clean and never have to worry about stale fuel problems...
/ Northstar Generators---- Beware!!! #55
Unfortunately for me, I discovered that I needed a meter about the size of a VW and a 2" dedicated gas line for the size generator I bought. Take those obsticles and add in the amount of NG it would take to run my generator and, for me, the answer became clear.
/ Northstar Generators---- Beware!!! #56
Natural gas would be nice, but it is pricy and the gen-set must be de-rated from the gasoline listing. Plus, as you said, my gas pipe is two inch from the road, then one inch for 100 feet into meter.
/ Northstar Generators---- Beware!!! #57
Freezers stay cold a long time, particularly if you throw a blanket or 2 over them. Even without the blanket, my chest freezer stays frozen 24 hours or more. I run my Kubota 9kw diesel generator about 4 hours in the evening, and then again in the morning if I am trying to conserve fuel, but at less than .4 gal/hour and 50 gallons in a drum, I really don't need to worry about prolonged outages. Here is a link to info on the unit:
Kubota 9,875 Watt Diesel Generator
Remote start from the house and a manual transfer switch is all the convenience I need.
Why fool around with Northern junk?
Nice unit... Did you purchase from Central Maine Diesel? I'm suddenly in the market to budget in a genset as we've been without power for >24 hours and the community has almost turned into a WROL situation. 850k people without power with the windstorm that blew threw Northern IL yesterday morning.
/ Northstar Generators---- Beware!!! #58
I've looked at them on line but haven't gone there to see them. I'm thinking that they buy a Kubota (or other brand) engine and then mate it to a generator. Not that it's bad but I would like to know more about what brand generator they use (I have no worries about the engines they use). If you do look into them further then please post what you find out.
/ Northstar Generators---- Beware!!! #59
Will do, also looking at a Detroit Diesel / Delco combo - looks to be economical and used in a lot of commercial configs - the 20kw price points are lower... Seeing that we will be out another 3 days without power, this has moved up the priority list for future preparedness.
http://www.emerson2-71gm.com/Gensets.html - anyone have any thoughts?
/ Northstar Generators---- Beware!!! #60
Haven't followed the thread real carful but on that emerson you do know that it's a 3ph unit and all home and most smaller farms are single phase. You can do it but will require abit of finagling to split out your load to the three phases or a phase converter.
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2011 CATERPILLAR TH337AG TELESCOPIC FORKLIFT (A64279)
2011 CATERPILLAR...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Location Tampa, FL (A61567)
Location Tampa, FL...
2019 FORD F350 4X4 PICKUP TRUCK (A59912)
2019 FORD F350 4X4...
