The BX and the pebble
/ The BX and the pebble #1
zoltanthegypsy
Gold Member
Bainbridge Island, WA, USA
Kubota BX24, GR2120
Or maybe the Princess and the Pea...
I don't trust my BX 24. First time mowing the tall grass: torn drive shaft boot, broken radiator fan and shroud, fuel pump wiring ripped out. That led to a full set of Bro-tek crunch plates. And a $$$ repair bill.
2nd time mowing that same tall grass: front axle pinion seal wiped out. That led to a home-made guard for the front u-joint and seal - so far so good.
3rd time mowing the tall grass: actually, before mowing. Noticed a puddle of coolant on the ground. Upper radiator hose clamp not sufficiently tightened.
Today (same tall grass) it seemed like I wasn't getting full fwd throttle in low range, but I haven't been on the machine for a while so I just figured my memory was bad. (I could hide my own Easter Eggs at this point, if you get my meaning..) Mowing for 3 or 4 hours, and suddenly could only crawl in forward. Reverse was OK.
Crept down the hill and got it on the trailer. 2 hours of pulling off wheels, poking at every linkage I could find. No joy. My guess was something internal in the transmission. Finally pulled up the access flaps in the the rubber mat on the floor pan. It took a while with my elderly eyes, but I finally spotted a pebble on top of the fwd/rev pedal pivot mechanism outside the frame. It kept the forward pedal from moving more than a few degrees.
How it got there, I'll never know. Why it stayed in place - sheer cussedness I guess. Should have checked there first, but I'm so leery of the machine at this point, I just assumed the worst.
Too soon old, and too late smart,
Z. (thanks for listening, I feel a _little_ better now)
/ The BX and the pebble #2
The BX is known for low ground clearance and a soft under-belly.
I too added bro-tek plates and think the money is well spent... had a couple of close calls... a twig hit the hydro cooling fan and a small but stout small branch somehow snagged my fuel line and tore the hose.
Too bad it's so uncomfortable to mow in reverse... might eliminate problems.
Hear the weather has been very good in your corner of the country...
/ The BX and the pebble #4
Is this a new tractor or new to you? How many hours on it and did you put them all on it?
/ The BX and the pebble #5
I have had similar things happen on taller "known good" tractors, so it is not surprising that the BX would be challenged by tall grass.
I suppose if I had to do tall grass with a BX, I would use the FEL down low to the ground to try to knock it over to keep it our of the works.
The BX is very handy for what it is to be used for, and tall grass likely is not in its range of uses. Most of us, we do use it out of its range, but we all have to be careful to mitigate its weeknesses so we can enjoy its strengths.
I wish you luck, and if you are going to do something to challenge the BX, I hope you will ask a question so we can all try to tell how we have handled it.
/ The BX and the pebble #6
Agree w/EE_Bota, tall grass has slayed many the bigger tractor too.
I've had it wrap around the pto shaft and wipe out the pto seal. Also had it to get up into the radiator fan and somehow get the belt to jump off the pulley and wipe itself out too, along w/the seal in the water pump. All this on a tall sitting TE20 Ferguson :D
One time, when bush-hogging down some corn rows, the same tractor's front right front wheel found enough of a hill to where it lifted the front end up and it came smashing down once it was over the hill. When it came down it smashed down on a cornstalk and it bent it down to the point where the stalk was rigid enough to bend the steel oil pan enough to cause an oil leak on the oil filter access cover. On that old Fergie there was an access panel right at the bottom of the oil pan that had to be removed inorder to get at the oil filter. Later model TO20's and up moved the oil filter to the outside of the block but thats another story :D
I've sickle mowed them corns rows since :D
Good luck w/your BX2350, perhaps you've gotten all them gremilns out now :D
Dave
I bought it new a couple of years ago. Only around 90 hours on it so far. Forgot to mention the front tire w/a damaged bead when delivered by the (less than useful) dealer.
I should have said that all the grief (except the coolant leak) happened while bush hogging tall grass. No sticks, no stones. I hate to imagine what a real 'hogging job could do to this machine.
The little thing was brilliant for trenching an irrigation system. Never occurred to me that nice soft grass would be so deadly.
@Volfandt: Now I'm really scared :(
At least this time I can' t blame Kubota. Thanks for the replies,
Z.
/ The BX and the pebble #8
The next size larger tractor than a BX is a B series. You see a lot of post where people ask should they buy a BX or a B. Usually people say if you are working in rougher area or need larger tires or ground clearance, get a B series tractor. It sounds like if you are doing a lot of brush hogging, you need a B. BX's are great little tractors, but they do have limitations.
/ The BX and the pebble #9
I have done quite a bit of bush hogging w/ my little GC. I ALWAYS leave the FEL on and close to the ground. Do you have your FEL on? I mow the pastures and such when the grass is about 3' tall. I have found some grass wrapped around the fan, but not enough to worry about, just a couple of strands. But I always check under the unit at least once a week to check for "gremlin damage" you never know.:cool:
/ The BX and the pebble #10
Sounds like the experience I get with my tiller. When ever i use it I break it. :( But after fixing it about 6 or 7 times now, I have successfully used it twice both yesterday and Saturday and it did not break! :D Now I am very happy to have it. :laughing::cool: Lets see, with your BX, watch the fuel filter under the operator platform, my neighbor's BX24 had a plugged filter and ran very poorly because of it. So i went out and got him a filter, replaced it for him, runs like a top. :thumbsup: His hydro fan has no blades on it and i offered to replace that but he is a little leery of letting his 15 year old neighbor take apart his $15k tractor. :eek: Why do i do it? It is a neighborly thing. I like helping out with that kinda stuff and being young, love to learn how to fix it. :thumbsup::)
... Why do i do it? It is a neighborly thing. I like helping out with that kinda stuff and being young, love to learn how to fix it. :thumbsup::)
So how far is it from your house to mine? Maybe I could pay you mileage :)
I started this thread (for some unknown reason) just to say that for once my BX wasn't broken. Just a little pebble in the wrong place.
Naturally, when I went to load it on the trailer this morning, I discovered the flat rear tire. The 2nd rotten valve stem in two years. :smiley_aafz:
Z.
/ The BX and the pebble #12
it kinda looks like the rubber boot on the DS is torn too!
/ The BX and the pebble #13
I cant say I am surprized. Last time i used it it had 2 flat front tires. :confused2: He tried to fill them with air but they had bad valve stems. :(
/ The BX and the pebble #14
Z.
I think it is a little ways away, but if I were closer i would love to. I always love working on machinery, it is a lot of fun. :)
/ The BX and the pebble #15
I think the BX tires are a little on the fragile side...
After having several rear flats spoil my weekend plans... I had them foam filled... it was worth it to never have to worry and improved my backhoe efficiency and overall stability. Not sure if the benefits apply to dedicated mowing.
My fronts were always loosing air... I Slimed them and the air loss stopped. Last weekend the right front developed a bubble that eventually let go.
A couple of years ago, I bought a spare set of tires and glad I did.
/ The BX and the pebble #16
Along the same lines as your pebble I had a stick that got wedged just right in the HST pedal linkage while working in the woods. The only difference was that the stick prevented the pedal from returning to neutral and made the tractor keep moving forward at a slow but steady pace. I shut off the machine in a real hurry when I realized something was wrong. After a short search I found the stick that acted like a very effective spring.
Edit: The tractor is a B7800 in my case
/ The BX and the pebble #17
Z.
Valve stems seam to be a real problem, not just with tractors. Every tire shop now replaces them regardless of their shape. For most cars around here that's twice a year, once in the fall when the winter tires go on and once in the spring when they come off. I asked and they said it was cheaper than dealing with the number of people coming back with tires going flat. Maybe they are all being made by the cheapest supplier in China or something.
/ The BX and the pebble #19
Ya reckon......
Same here... never had stem problems till the last few years...
I went to metal stems for my trailers.
Let's see: 1994 (or so) Deere 425: original valve stems. 1998 Suburban: original. 1991 Porsche: original. 2006 Silverado: original. 1999 EZ Loader trailer: original. For that matter, 1990 Honda tiller: original.
Kubota BX 24: two failures in two years. I don't like the trend here. Not to mention, a tractor flat far from home, and way out in the weeds is *ing inconvenient. Fortunately, there was still enough air in the tire that I could (just) get it back on the trailer.
Free, quick on-trailer repair by Les Schwab, so that's the good news.
Z.
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
HD 24ft Free Standing Corral Panel with Feed Bunk (A65583)
HD 24ft Free...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
