Jun 4, 2011 / John Deere rotary mower #307 #1 L Lewellen Farms LLC New member Joined Jun 4, 2011 Messages 1 What is the recommended rpm's to run this mower?
Jun 4, 2011 / John Deere rotary mower #307 #2 Muhammad Administrator Moderator Joined Mar 21, 1998 Messages 21,059 Location San Diego, CA Tractor Kubota 54105 Welcome to TBN.
Jun 6, 2011 / John Deere rotary mower #307 #3 Briana03 Elite Member Joined Jul 23, 2010 Messages 3,270 Location San Diego, California Tractor None Hello & WELCOME to TractorByNet.com! I have moved your thread to the John Deere Lawn & Garden Forum. You'll get a better response there.
Jun 6, 2011 / John Deere rotary mower #307 #4 T thatguy Elite Member Joined Mar 1, 2005 Messages 2,816 Location Bedford, VA Tractor John Deere 2320 Lewellen Farms LLC said: What is the recommended rpm's to run this mower? Click to expand... Most mowers they recommend running them at the 'rated' engine RPM - which gives rpm the implement is designed for (IE - rear is 540 and the mid is +/- 2100-ish) Your tractor may have an indicator on the RPM guage that show the 'rated' speed Brian
Jun 6, 2011 / John Deere rotary mower #307 #5 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,687 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) Lew Run at engine RPM that gives 540 PTO RPM. Less RPM if you are satisfied with the cut. (like what thatguy says )
