Built my boom pole today
   / Built my boom pole today #31
Originally Posted by RonMar
Triangles are our friends.
But only when all the corners meet other corners. In my sketch, the support brace meets the side of a triangle, so the full benefit is lost.
Bruce
   / Built my boom pole today #32
This looks like it's going to be a good rainy day thread for me. ...love this kind of *****.
I had a boom on my old 7274 Cub Cadet's bucket. It was not really long, but simplicity itself. I am setting up my R4010 LS the same. I simply mounted a receiver hitch tube on top of the bucket back to accept a five foot piece of 2X2X1/4 square tube. It lifted 300 pounds with only a little flex.
There is a bonus with this setup as it allows me to slip in a trailer ball and push trailers around.
My only concern is, in the short time I've had my LS, using my homemade forks, I find the bigger tractor cannot lift as big a log as the old CC. The tilting torque of the quick release bucket seems much less. I can see that the leverage from the tilt rams' connection points to the front of the bucket is greater with the quick release structure in between. I'm disappointed, seeing how much bigger the new hydraulic pump is, and considering the 14 more HP I just bought. I don't know how to tweek the hydraulics for more power, or if it's even possible.
Of course, using a boom, this tilting torque is all important.
   / Built my boom pole today #33
a long structural member has 3 basic modes of stress. Tension(pulling), Compression(pushing) and shear(bending). Tension is the strongest mode, and you will get the most out of the material used. Compression is the next strongest, but considerably weaker than tension. Shear is the weakest mode....
I would put it a little differently. Tension and compression are similar for metals (concrete being different because it is markedly weaker in tension than compression). Shear stress failure is what it sounds like, the separation of material by opposing forces. Bending and shear stress are not exactlyl the same. Bending forces result in local tension, compression and shear stresses. Bending is bad because it results in very high stress components in a very localized area, leading to failure. A bending mode failure could fail from tension, compression or shear depending on the shape of the member and load application (although shear might be the best candidate).
The original design shown isn't optimum because of having the brace away from the top truss support, but it is still providing a lot of support because it is reducing the moment arm that creates the bending forces. All these designs look like they have a lot of margin for small tractor use.
   / Built my boom pole today #34
"I like it. Good design, making better use of materials. The only suggestion I would make is to weld the struts to the center of the tube instead of clamp them. "
The idea of only clamping the jury struts was to avoid welding there. As you also said, the main tube will fail (if it ever fails) in compression. I figured I could keep it in column with the clamped method, without weakening it by welding to it at that critical mid span region.
   / Built my boom pole today #35
You are correct that no matter where the truss support is, the trussed beam is still stronger than the un-trussed beam. It's just going to be strongest if the support is directly over the leg. True that moving the leg out will create even more support than moving the truss support in, but that's due to other factors.
Take a look at the sketch that BCP posted (post #13). It's a good illustration of the principle. In that sketch the beam is able to bend without bending or breaking any other member of the structure. Imagine if the truss support were directly over the leg. The only way it could bend in that instance is for a weld to break or for some other member of the structure to stretch, bend or break.
In this particular instance the beam is plenty heavy for the application. We're splitting hairs a bit for the sake of discussion and for future reference.
I just try to fully understand these concepts and get people's thought's and opinions. Thanks for your input!
Do you have any idea what the increase in capcity would be if he changed his original design to the optimum ?
   / Built my boom pole today #36
I don't. Rough guess: about half again as much.
Is there someone out there more versed in this stuff than I am that could chime in?
   / Built my boom pole today #37
Anyone care to do some 3-D modeling and finite element analysis ,anyone ...?
Bueller ...?
   / Built my boom pole today #38
I'm betting that the sub-optimal layout could exceed the machine's capability.
The sides of the beam contain unseen small triangles between where the lower brace supports the beam and where the beam supports the truss king post. Assuming I'm seeing that the beam is square tubing, the tube is itself a small truss, with the top under tension, and the bottom under compression. For the tube to fail in that few inches of reach from the brace to the king post would be after the rear wheels of the tractor were in the sky. Be careful of your front drive axle's innards when you have a heavy load on the boom. They weren't made to handle those kinds of stresses (ask me how I know :().
The failure illustrated in the sketch would not happen unless the truss itself failed first, as either the king post failed under compression, or the top cord failed under tension, or both. Yes, I'd say the layout isn't optimal, but it's still way stronger than not being trussed.
I hope I don't come across as an uppity newbie.
   / Built my boom pole today #39
Maybe someone with some Mechanical engineering experience could comment on my idea of instead of the top chord and king post of welding a continous say 1 inch x 3/16 stiffener bar vertically on top of the 2 x 2 main beam? I am guessing that the 2 x 2 stiffened in this manner would also outperform the actual lifting force of the machine and be easy to do. Any thoughts?
James K0UA
   / Built my boom pole today #40
Bruce
Bruce, you are absolutely correct. That structure would fail right where the lower structural support meets the boom pole, by collapsing the side that triangle forms. As mentioned, it should be out under the base of the kingpost, which will keep the kingpost in compression so it can support the tension on the forward running guy and rearward backstay(kingpost truss, common in bridge and crane construction, as well as older aircraft wing design).
Jimgerken: Properly welded attach tabs will only add to the cross section of the column at that location, increasing it's strength
For the OP, that structure will probably bend the formed rear structure of the kubota bucket(stamped component instead of a closed boxed structure), before the boom fails... I was a little disappointed by that Kubota bucket design:(
As for rainy day reading, this is not a new subject on TBN. Search "boom Pole" and you will come up with pages of further reading material, and some examples of really what not to do:)
Best 30' Grain Drill (A50514)
Best 30' Grain...
Unused 2025 CFG MY50R Mini Excavator (A49461)
Unused 2025 CFG...
LIGHT BAR AND WIRING (A50854)
LIGHT BAR AND...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
