JD #9 sickle bar swath board question
/ JD #9 sickle bar swath board question #1
sjbrunk0
Member
Edgerton, KS
JD 2040
I'm restoring a JD #9 mower and the swath board is broken off, from what's left it looks like somebody had made one out of plywood.
Yesterday I cut a board to approximately what I figured it should look like, but when I went to mount it onto the mower I was puzzled...
There's just one bolt and a spring to hold it onto the mower. What keeps it from pivoting down on that bolt and dragging along the ground?
If anyone knows how this is supposed to work or has a picture of a functional one I'd sure appreciate it.
/ JD #9 sickle bar swath board question #2
There was a cast bracket that the board fit into. Maybe that is missing?
Here are a couple pics showing the No. 9 mower, then the outer shoe on the sickle bar where the grass board fits on with the single bolt and the bolt with the spring (that spring keeps the grass board nestled inside the outer shoe but allows it to pop out rather than be broken off). Then a pic of the grass board with the metal piece at the tip. Also shows the stick attached to the grass board.
Hope this helps. Go to jdparts and find the parts info.
/ JD #9 sickle bar swath board question #3
Well, I don't have a JD #9 mower, but I have rigged swath boards for several of my sicklebars.
My old Allis Chalmers 80T trail mower has a swath board like the one your described. I cut it out of a board and attached it with a bolt, nut, washers and spring. The grass stick is missing from this photo.
Here's another variation--the mid mount mower from my 1951 Farmall Super A. The outer shoe forms a kind of swath board and carries several grass sticks. The Super A was used by Caltrans for mowing highway ditches. I haven't gotten around to rebuilding the cutter bar yet. ONe of these years.
Finally, here's my old Massey Ferguson 31 mower. I added a pair of grass sticks to the outer shoe and rearranged the grass stick on the inboard shoe in an effort to reduce the amount of clogging this mower experiences. Sorta works, but the cut is still not that good despite rebuilding that cutter bar three times so far.
Old sicklebars are a PITA. I'm switching to a drum mower next season.
Hmm... maybe the swath board is supposed to drag along the ground? I think I have all of the parts that are shown in the picture.
View attachment 215463View attachment 215464
View attachment 215465View attachment 215466
View attachment 215467View attachment 215468View attachment 215469
beenthere,
Thank you for sending those pictures, it helps! I previously thought the swath board was supposed to be held above the ground by that bolt and spring, but looking at your pictures am now thinking maybe it just drags along on the ground?
/ JD #9 sickle bar swath board question #6
Yes, it drags on the ground. Spring loaded to pop around obstacles.
/ JD #9 sickle bar swath board question #7
beenthere,
Yep, the swather board slides along the ground. The hay sticks attach to the swather board and sort of windrow the cuttings so they don't clog the inboard end of the cutter bar on the next pass.
Thank you both, you guys are great.
Hey, wanted to let you know I made my swath board... and it works like a champ! Thanks for the help, guys!
/ JD #9 sickle bar swath board question #10
/ JD #9 sickle bar swath board question #11
I believe the pole attached to the Swather/Grass Board is called a Pitman Bar.
I was just given a JD Swather Board as a gift with JD info still visible. The partal set of 1" numbers stamped into it are 9968. I believe it was sawn off the original machine. Riveted flat bar inner bottom wear strip is still intact. JD Number 1 Mower? Horse drawn?
/ JD #9 sickle bar swath board question #12
Gord Baker
Thinking that is a grass board and a stick. The pitman arm connects to the cutter bar, and makes it move back and forth.
/ JD #9 sickle bar swath board question #13
I saw it referred to as a Pitman Bar. Whatever. You are also correct.
2018 JOHN DEERE 310EL BACKHOE (A59905)
2018 JOHN DEERE...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A59905)
2014 REITNOUER...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
MASSAGE CHAIR (A58214)
Broom Attachment (A59228)
Broom Attachment...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
