JD #9 sickle bar swath board question
   / JD #9 sickle bar swath board question #11
Yep, the swather board slides along the ground. The hay sticks attach to the swather board and sort of windrow the cuttings so they don't clog the inboard end of the cutter bar on the next pass.
I believe the pole attached to the Swather/Grass Board is called a Pitman Bar.
I was just given a JD Swather Board as a gift with JD info still visible. The partal set of 1" numbers stamped into it are 9968. I believe it was sawn off the original machine. Riveted flat bar inner bottom wear strip is still intact. JD Number 1 Mower? Horse drawn?
   / JD #9 sickle bar swath board question #12
Gord Baker
Thinking that is a grass board and a stick. The pitman arm connects to the cutter bar, and makes it move back and forth.
   / JD #9 sickle bar swath board question #13
I saw it referred to as a Pitman Bar. Whatever. You are also correct.
2022 BOBCAT T595 SKID STEER (A52705)
2022 BOBCAT T595...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2013 Cadillac ATS Sedan (A55758)
2013 Cadillac ATS...
5' S/A CART (A52706)
