Driving A New Well
/ Driving A New Well #1
bp fick
Super Member
Beaver Creek, Northern Michigan
John Deere X390
I've put this off for over a year, so today was the day to start.
I'm pounding it down, bit by bit. I'm down about 14' feet so far. I already hit some water. I intend to drive it down 20-23 feet and I will be using a jet pump I got off Craigs last year. I really want to stop using our deep, submersible well for irrigation of the gardens.
I'll keep you posted as to how this goes.
Couldn't find a widow maker to rent at our one and only rental yard. Oh well. My neighbor looked through his junk iron and we found an axle shaft and an old gear that has to weigh 40 pounds. Welded the axle to the gear. Slide the axle down the well pipe. Pick up the gear and let it slam down.
It's working better than anything I've ever use before. Thanks to my neighbor, Tom. :thumbsup:
/ Driving A New Well #3
Good luck Fick. I drove a sandpoint well last summer (see posts) and it was one of the most satifying accomplishments for our property. I still need to bury the electric line for our pump....but we have great water. I rented an electric Jack Hammer to drive the pipe. (worked slicker than goat grease)
I look forward to seeing your results. :thumbsup:
/ Driving A New Well #4
I'm curious as to what happens if it encounters a rock? I'm not saying it's not practical, since it obviously works, but what do you do if it refuses to go deeper? Pull out and try another spot?
I'd like to try this here, but we have stony ground (nothing too big though, no boulders) and a layer of gravel after the clay runs out.
Sean
/ Driving A New Well #5
Can you explain this procedure? Do you have a section of screen with a point on it? I remember seeing a screen with a point on it a very long time ago and never knew what the point was on the screen for. Unfortunately it wouldn't work in my area, you have to go down about 50 to 80 feet before encountering any water at all and then it would be a pretty limited supply I'm sure.
/ Driving A New Well #6
yeiks, id like to do that here, but our water is down about 700 feet :mad:
Driving a well, (washing in a well) is particularly suited for sandy areas, where the water table is 20 feet down. These are known as "Cottage Wells" for that reason. This describes our area. Sandy gravel all the way to the water table.
This is considered "surface water" as it is above the hard pan or clay located, I would guess, at 40 feet or so.
I have driven through these layers, in the past, all the way to 90 feet, but I do not recommend it. These wells typically use a simple jet pump which only lifts water from 25-28 feet anyhow.
/ Driving A New Well #9
Do a search on "driving a new well". I posted with pictures last summer on how I drove my well....and there is lots of info available on wells via google too.
These sand point wells are shallow wells (under 25 feet deep) so you need to have a high water table to use this method. Deep wells are a whole nother story.
Fick.....I Just saw your response after I was typing mine. You wisconsin guys sure get up early. :0
A driving well point, pictured, has a hard point, and the body of the point, is perforated and has a stainless steel screen. I am driving a 1 1/4" diameter point. The point cost about $80. The pipe is standard galvanized steel pipe. It is easier to drive 4' sections of the threaded pipe.
Local hardware stores will cut and thread the pipe, to size, for $1 a threading.
The pipe is very expensive at almost $2 a foot, at local hardware prices.
What is really expensive is the "driving couplings". These are hardened and will take the shock of being pounded on without becoming damaged. Mine cost $10 each.
You drive down a section, thread on another section of pipe and pound again.
Update:
Since I've driven 12' already, from now on, I'll drive shorter, 4' pieces of pipe.
More pieces means more drive couplings at $10 a crack, but oh well. Teflon on each connection, at least I am doing so.
That home made driven has been a godsend. You do have to stop and constantly re-tighten the couplings as the whacking tends to shock them into a loose state, which is a no no on the threads, of course.
When it comes time to hook up the pump, I may be asking some questions and some advice. So, all you jet well pump gurus, you may need to help me out on a few things.
/ Driving A New Well #12
When we drove our sand point....after about 12 feet I tried pumping via the pitcher pump with each new section of pipe. We were still not pumping water at 30 feet. YIKES! THEN I discovered we had not properly primed our pitcher pump after I pulled a secton of pipe from the well and tried pumping again. In reality we were hitting water at about 12 feet....IIRC. Duh! (Oftentimes I go too fast for my own good. ;) )
Quick Tip: A good way to check the water in the pipe is to tie a nut on a string and slowly drop it down the pipe - in say.....two foot increments. At some point you will hear a "splash". You can measure the water standing in the pipe by measureing the water on the string / vs dry string with the nut laying on the "floor" of the sand point to determine how deep the water is.
/ Driving A New Well #13
I'm going get with a neighbor that has an existing well to see what kind of footage my water table is at. I may have a try at this technique in the near future.
The homemade driver is working very, very well. I'd recommend this style over the the more traditional two handled pipe style any day. I've slipped a large washer, with a 1 1/4" center over the axle shaft. This washer is taking a beating, but it is protecting the surface of expensive drive coupling. No marking them at all now.
I also wanted to mention that I find I have to keep the pipe wrench handy. The impact causes the couplings to loosen a bit. After 20 reps with the driver, I re-tighen the coupling as a pre-caution.
We're down 17 feet now and the point is in water. Yes, as foggy1111 mentioned, we use the nut tied on the end of a string method for checking. We have 4' of water in the column. I'd like to go on down another 5-6 feet and see if we can have 8 feet of standing water.
I admit, doing this when I was younger didn't hurt so bad the next morning. :D
/ Driving A New Well #15
Why is that BP?
It has been my experience that most household wells could use a little exercise.
/ Driving A New Well #16
I've got an uncle that had a rig come in and do his a few years back. Went to around 750', although everyone in the area are less than 100'. He pulled it in by filling 3 decent sized catfish ponds. Ice cold.
Why is that BP?
Do you think so? I've been pounding on the household well for two years. Kinda thought having a separate irrigation well would save wear and tear on the household well. No?
OK, got it down around 19 feet and have almost 6 feet of water in the column. Probably try pumping on it. I've got another 4' section to drive, if I think it is needed. We shall see.
You guys have thoughts on "conditioning" a new point well?
/ Driving A New Well #19
I've not much water well experience, but I have some oil well experience. If you pull too hard it will sand up. Which is what the propping agents are to help avoid. Such as a gravel and screens. Each well is different. Now if you have two wells on the same property and at the same depth/zone, you'll deplete it faster. But water will replenish itself to a certain degree the shallower it is. Deep water wells are also different as they may be fed continuously by another source. On the same note, some shallow water wells are just pockets of water, just like oil/gas. Once it's gone, it's gone. My wife's grandfather hand dug and bricked his well back in the '40s and it lasted up until the '60s, which is about the time community water made it that far as the story goes.
/ Driving A New Well #20
That would be my take too. I'd save on my domestic deep water....and use the sand point for irrigation where possible.
If your area is anything like mine (which I think it is) you have an abundant supply of shallow water....but it's most likely not potable.
I have never got our shallow well tested. Keep forgetting. :eek: It sure seems clear and cold.....but we drink bottled water at my "deer land" and dont have much need for drinking water.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
2006 Utility Spread Axle Trailer (A62679)
2006 Utility...
213208 (A64277)
213208 (A64277)
2022 BOBCAT T66 R-SERIES SKID STEER (A65053)
2022 BOBCAT T66...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
