4wd tractor vs 2wd
Status
Not open for further replies.
/ 4wd tractor vs 2wd #61
I did not see it mentioned ... but a 4wd has the ability to climb over stuff that a 2wd would just try to push with its front wheels. The taller the item the greater the 4wd advantage. This advantage is present not only with objects, but in any soft going. In plowing, the 2wd fronts have to push against the dirt they sink into while the 4wd climbs over. The 4wd uses less fuel in these conditions because of this.
larry
/ 4wd tractor vs 2wd #62
My two cents on this....It really all comes down to when you need you it and you don't have it then you'll wish you spend the extra money for it. More positive thinks about having it than not.
Most tractors I'm sure has a way to switch between the two modes.
Same thing can apply to the FEL, it's help me get unstuck on more than one occasion in mud and snow even with 4WD and since small tractors 4WD is not a locking type, get one tire spinning and your most likely hung. With the FEL you can push yourself back and get free.
/ 4wd tractor vs 2wd #63
Certainly there are conditions in which 4wd is not an advantage. What you are missing is that there are also conditions in which it is an advantage.
If the ground is soft enough to bury yourself to the frame, it probably isn't going to help much. But if the ground is firm and the problem is just slippery muck on the surface, it makes a big difference.
I was dragging a big log in reverse and needed to back up out of a little dry creek. The slope was dry and firm, but was crumbling away as my rear tires were trying to climb it. Switched to 4wd and the rear easily climbed up and over the loose soil.
So is it always an advantage? No, of course not. But sometimes it's priceless.
/ 4wd tractor vs 2wd #64
I don't remember all of the times I wasn't frustrated because I had the advantage of 4wd.
I do remember all the times the 2wd loader tractors were stuck.
A month ago I had a hard time getting my 2wd 310D up a slight slope in a field to dig a trench for a drain tile. Once the trench was dug, I had the customer dump stones in the trench. With his 4wd 70hp New Holland, he crawled over/through the piles of mud with the front axle to dump stones in the trench. He had no trouble hauling the stones up the slope either.
By the grin on his face, I would say he thought it was pretty cool.
/ 4wd tractor vs 2wd #65
I don't know. I plan on doing mainly tillage work, with a secondary use for pulling heavy, red oaks, some 20-30 in diameter,some as thick as 48 in anywhere from 8 ft-40ft long. They are heavy. Of course I can cut them to managable sizes with a chainsaw. Do you think a 38hp Massey Ferguson 2605 2wd will handle them properly ? I have also considered the Case IH Farmal 70 2wd, and the NH T4020 2wd, which is almost the same tractor, except the body work, and rearends. I know they are heavier, but the cheapest new one I see myself getting is probably around $19,000.00, while the 2605 is around $12,000.00 That does include, rotary cutter, plow, tiller, cultivater, grain harvester, manure spreader, etc.. I will be also purchasing
/ 4wd tractor vs 2wd #66
I ment, that doesn't include attachments, and implments, and pull behinds. The 4wd 2605 is about $14,500.00 I also have to buy the land too.. I mean, I have work to do where I live for now, but I plan on buying some property in the norther part of the state of WV. I live in southern WV. The closest dealer that sales CASE IH, is in Virginia, about 60 miles away. I plan on moving closer to them, when I find some property. I have already found some nice parcels, but I haven't decided yet. I don't know how much I will be spending on property though.
/ 4wd tractor vs 2wd #67
Another thing I dislike about a 4wd tractor, is that you will have to ballast it, if the 4wd axle weight shifts percentages of weight balance.
/ 4wd tractor vs 2wd #69
5500 - You are not being nice. :)
Shannon wants to buy a tractor, some land, and be a farmer. He has no intention of buying a loader, only rear mounted equipment.
I have seen the light, he wants a 2wd.
When he finds out how much land costs, he will be back with more cost saving ideas. That is good, because offering suggestions is easier than solving my own problems.
/ 4wd tractor vs 2wd #70
Ok, Iam sorry. :confused2:, But what is there to ballast on a 4wd, if anything the two wheel is un-ballast, because 4 wheels pulling is better than 2 wheels pulling, think about it.
/ 4wd tractor vs 2wd #71
I broke one of my front shafts thus unable to use four wheel drive. It rendered my tractor very limited to what I could do. Mind you, I only have a 20 Hp tractor so not much weight. I use mine for road work, fire wood and general hauling stuff around.
I don't think I would have bought a 2wd.
/ 4wd tractor vs 2wd #72
Tractorboy5500,
Hehehe.:laughing: I was told before if you can get it out yourself, you are just delayed.;) If you need help, your stuck.:eek: I haven't been stuck yet, as I carry my own "jacks".:D
hugs, Brandi
Guess I missed this one, I can say I have been delayed many times and stuck 3 times, so far. I dont have jacks on mind yet.
/ 4wd tractor vs 2wd #73
What is there to ballast on a 4wd? I am glad you asked.
Proper ballasting of a 2wd tractor for tillage work would include filled tires and cast iron rim weights. Basically, more weight yields more traction.
The rear wheels of a 4wd tractor should do just as much work as the 2wd version, therefore filled tires and iron weights. The front axle is meant to be front axle assist. It is meant to provide additional traction, not to be a substitute for the rear axle doing the work.
The fully weighted tractor can be too heavy for yard work, and more than a person wants to haul behind their truck. And then there is the money thing.
Both 2wd and 4wd need rear ballast, as well as suitcase weights or loader for front end weight. Shannon can add $1500+ to the quotes for proper ballasting.
The farm is getting smaller.:(
/ 4wd tractor vs 2wd #74
I know about that. My intention is to buy one thing at a time. For example, make about a $3,000.00 down payment on a new tractor, with a few implements I will need. Pay about $1,000.00-$1,500.00 a month on it, till it is either paid off, or almost paid off, then save up for a 10% or 20% down payment on the land. I may purchase the land first, then the tractor. My strategy is basically the same though. I still have to consider building a shed on the property, for the equipment, and my tools, etc.. Prep the land, then build a cellar (This maybe about $3,000.00) I don't know. Rent small excavator, dig cellar, pour foundation and forms, lay block, find I Beams, and ceiling, buy freezer, and refrigerator, as well as build shelves, plus buy metal cellar door, build steps, and buy solar power kit for lighting, freezer, and refrigerator. Price of Freezer, and refrigerator, plus solar power not included..lol.. Oh, yeah dig two wells, if the property doesn't have any. Self drilling kit $800.00, to have it drilled $2,500.00-$3,000.00 not sure on exact price. Plus the pump, is about $700.00 for a cast iron old fashion one. There is a brand called Bison pumps, but they are more expensive, but are probably better. Hopefully, I can find a good parcel with a well,or two. After all this, I plan on building a small house/cabin/cottage. Building material for that will be about at $15,000.00 ( I will be doing all the work). I plan on only build about a 600sqft-900sqft place, with the option of adding on later. I hope to go all solar, and wind turbine, with grid available..takes patience..
/ 4wd tractor vs 2wd #75
Yes, about 95% of the time anyone buy a tractor with front end loader either 2 or 4 wd, the dealer will fill the rear tires anyway, thats a given for just about any tractor not just if its 2 or 4 wd. When I bought my tractor I didnt get the fel, I got it 3 years latter, and had the same dealer install the fel, they told me its a must to fill the rear tires, either its a 2 or a 4 wd. And yes there is alot of differnts in traction just using the 2 wd with the tires filled.
Also seen 2 wd with fel and front weights?????:confused:
/ 4wd tractor vs 2wd #76
The house I can get under roof for about $4,000.00, but that isn't including all insulation, drywall, or wood paneling, not sure on interior walls. I plan on putting T1-11 5/8 in 4x8 siding on exterior, Galvanized metal roofing. Not sure if I will use 2x4, or 2x6 wall studs. 2x6 construction cost about $40% more for the dry lumber. Plus the added cost of the insulation used in 2x6 24in wall cavities. May have better insulating properties, but not sure that will be a problem..8 ft porch, likely 2 exit doors, 6 windows, brick fire place, normal weight block foundation, likely will use quickrete concrete, depending on the price of concrete in the area for footers. Like to find cast iron tub, for reasonable price, but they are so expensive. That fiberglass stuff from lowes, isn't all that appealing to me. The cheap stuff tends to crack. Probably will put down hardwood floors of some kind, probably the basic type. Likely oak. Laminate doesn't dent, but water isn't a friend to laminate flooring. Considered a woodstove, but a fireplace will cost about the same amount to build, plus I like a fire place better anyways.
/ 4wd tractor vs 2wd #77
I went to a Massey Ferguson dealer, I didn't ask him about tire ballast, but he told me he would deliver the tractor for free, wherever I needed him to. I am still yet to go check on another dealer on what kind of offers he might have. I need a trailer too, but I can wait for that. I don't have anywhere to really put it right now. I will need a trailer, but I can wait for it. I will likely go with a 2wd, but I could change my mind by the time a actually buy one. I know from experience to stay witin your means. Never go in debt. Pay things off as much as possible, and as soon as possible. I also heard the liquid tire ballast isn't good for the rims, or the tires ??? Corrosion problems ?
/ 4wd tractor vs 2wd #78
Yes I know what you mean about buying one thing at a time, I did buy the tractor brush hog and box blade I wanted, but waited 3 years to get the front end loader because of the money at the time, and as time went on I bought other items, and I bought a bigger GN trailer about a year ago, "finally". I just bought a used round hay bailer a month ago, now I need the cutter and rake next, I hate waiting sometimes.:( Guess I will need to build a bigger shop next.
Yes I did hear some of the stuff they use to put in tires are somewhat corrosive, I have about 70% water and 30% antifreze. One set back is its not as heavy as liquid tire ballast. But this gave me 1061lbs of weight, I think that should be enough.
/ 4wd tractor vs 2wd #79
If one only uses the steering wheel to turn then 4WD is fine and may have the best resale. If one uses brakes to turn on a dime then I prefer 2WD in that case.
FEL use is more funtional with 4WD. With a 2WD when you need the traction the most then the weight on the rear tires is often the least.:mad:
In old stuff 4WD can increase repair bills.
/ 4wd tractor vs 2wd #80
I cleared my 5 acres after the loggers left a mess. I started with this 54hp Ford 3055 with 2WD. I bought it used for $3500 with a wore out JD rotary cutter. It's rear wheels were about 5 feet or so high. The tractor was almost too lite to tackle the big trees remains. You catch a large log wrong with just a box blade and that log will spin you around. You need weight to handle large logs and small tractors just don't have it. I was glad I bought the 3055, as I was looking for 20-30 hp tractors to clear and clean up the mess with. I can honestly state using anything smaller than the tractor pictured can get you and your tractor hurt in a hurry working large logs.
hugs, Brandi
Status
UNUSED LANDHERO LDH-LB9510 LEAF BLOWER (A62131)
UNUSED LANDHERO...
VWS Toolbox/Fuel Cell (A61166)
VWS Toolbox/Fuel...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
2007 JLG 3246ES ELECTRIC SCISSOR LIFT (A62129)
2007 JLG 3246ES...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
