4wd tractor vs 2wd
Status
Not open for further replies.
/ 4wd tractor vs 2wd #221
There are times, especially on hills, when I have had a lot of slippage or even got stuck or hung up in 2 wheel drive. When I go into 4 wheel drive I was able to get out. I have a 4510 and a Yanmar 336d and it is the same on both.
With the type of conditions I have I need the 4 wheel drive and now pretty much keep it in that mode.
/ 4wd tractor vs 2wd #222
Is it just me or has this thread gotten completely off base and the postings out of hand? I think the point on 2 versus 4wd has been made.
Seem to me it might just be time to shut this thread down!
/ 4wd tractor vs 2wd #223
Yes It got off base, but other threads do the same, guess I got caught up in it to, maybe someone else might have something to say as for the 2wd and 4wd contest.:)
/ 4wd tractor vs 2wd #224
As for me, 4WD, and HST is an absolute must on a tractor used for landscape work. For general farming it may not be a must have. The guys doing the haying next door have 3 tractors, all 2wd.
/ 4wd tractor vs 2wd #225
The post is about 2wd vs 4wd. I emphasized my perspective, and insults started arising, which brought forth critisim, and judgement. My point about a 2wd tractor is that, when you look at a picture, or painting of a farm, an old 2wd sets off a farm envirnment in my opinion. 2wd tractors are in my opinion good enough for the job, 4wd to me, turns it into something different, not so much a tractor anymore the way I see it, it has now become an 4wd farm machine, but the original tractor design has been altered in my opinion. To me the effect of plowing with a 2wd tractor is better, than that of a 4wd tractor.4wd sort of takes out the enjoyable factor of making a 2wd get the job done. I simply like a 2wd tractor better, 4wd is almost like training wheels on a bicycle..(if it is ballasted correctly) To me only a large scale operation, corporate, really benifit from 4wd, so to speak, because they can plow a large field quicker, for profits. A small scale farmer 20 acres, and less, tilled land that is, should be able to use a 2wd effectively no problem, if they are good enough..Not putting down 4wd tractor owners, just that I prefer a 2wd tractor.. Quicker does always mean better. I have seen fewer bottom plows, vs more bottom plows do a better plowing job if done carefulling using the same tractor. Sure, using a 3-4 bottom, vs a 1-2 bottom may get the job done, but sometimes it doesn't do as good of job. I would prefer a large single bottom on a 38hp tractor more so on a 2 bottom because I would have more control, and would likely create better furrows, this is not so say that done properly a 2 bottom won't acheive the same results, and on up the latter with more hp, and more plow bodies.. I don't think plowing in mud is a good thing to do anyways, unless you are planting rice, or something. Sometimes it is necessary but, if it is real muddy, you probably shouldn't be plowing anyways..
/ 4wd tractor vs 2wd #227
Looking at the 8560, probably gonna do it. I want to get a bucket for it too.
Well Mr.Nod, did you get a tractor, if so let us know, By the way I see that you are a new member, hope we didnt scare you by this thread, sometimes things get carried away, and if you got a tractor you have to post pics, we all like pics. welcome to TBN
Status
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
John Deere 185 Hydro Riding Mower (A66285)
John Deere 185...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
