4wd tractor vs 2wd
Status
Not open for further replies.
/ 4wd tractor vs 2wd #221
There are times, especially on hills, when I have had a lot of slippage or even got stuck or hung up in 2 wheel drive. When I go into 4 wheel drive I was able to get out. I have a 4510 and a Yanmar 336d and it is the same on both.
With the type of conditions I have I need the 4 wheel drive and now pretty much keep it in that mode.
/ 4wd tractor vs 2wd #222
Is it just me or has this thread gotten completely off base and the postings out of hand? I think the point on 2 versus 4wd has been made.
Seem to me it might just be time to shut this thread down!
/ 4wd tractor vs 2wd #223
Yes It got off base, but other threads do the same, guess I got caught up in it to, maybe someone else might have something to say as for the 2wd and 4wd contest.:)
/ 4wd tractor vs 2wd #224
As for me, 4WD, and HST is an absolute must on a tractor used for landscape work. For general farming it may not be a must have. The guys doing the haying next door have 3 tractors, all 2wd.
/ 4wd tractor vs 2wd #225
The post is about 2wd vs 4wd. I emphasized my perspective, and insults started arising, which brought forth critisim, and judgement. My point about a 2wd tractor is that, when you look at a picture, or painting of a farm, an old 2wd sets off a farm envirnment in my opinion. 2wd tractors are in my opinion good enough for the job, 4wd to me, turns it into something different, not so much a tractor anymore the way I see it, it has now become an 4wd farm machine, but the original tractor design has been altered in my opinion. To me the effect of plowing with a 2wd tractor is better, than that of a 4wd tractor.4wd sort of takes out the enjoyable factor of making a 2wd get the job done. I simply like a 2wd tractor better, 4wd is almost like training wheels on a bicycle..(if it is ballasted correctly) To me only a large scale operation, corporate, really benifit from 4wd, so to speak, because they can plow a large field quicker, for profits. A small scale farmer 20 acres, and less, tilled land that is, should be able to use a 2wd effectively no problem, if they are good enough..Not putting down 4wd tractor owners, just that I prefer a 2wd tractor.. Quicker does always mean better. I have seen fewer bottom plows, vs more bottom plows do a better plowing job if done carefulling using the same tractor. Sure, using a 3-4 bottom, vs a 1-2 bottom may get the job done, but sometimes it doesn't do as good of job. I would prefer a large single bottom on a 38hp tractor more so on a 2 bottom because I would have more control, and would likely create better furrows, this is not so say that done properly a 2 bottom won't acheive the same results, and on up the latter with more hp, and more plow bodies.. I don't think plowing in mud is a good thing to do anyways, unless you are planting rice, or something. Sometimes it is necessary but, if it is real muddy, you probably shouldn't be plowing anyways..
/ 4wd tractor vs 2wd #227
Looking at the 8560, probably gonna do it. I want to get a bucket for it too.
Well Mr.Nod, did you get a tractor, if so let us know, By the way I see that you are a new member, hope we didnt scare you by this thread, sometimes things get carried away, and if you got a tractor you have to post pics, we all like pics. welcome to TBN
Status
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2011 GMC Acadia SUV (A64557)
2011 GMC Acadia...
PALLET OF LOAD JACKS W/ CASTER WHEELS (A64278)
PALLET OF LOAD...
2022 BOBCAT T66 R-SERIES SKID STEER (A65053)
2022 BOBCAT T66...
2003 NISSAN 350Z (A67148)
2003 NISSAN 350Z...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
