Sickle Bar New member
/ New member #1
catfishbaitface
South Dakota
Hello all, I just found and signed up for this site. I did a little investigating and found no answers---yet. What I have is a 14 acre "hobby farm". We have a fruit orchard with everything that can be grown here in SD. Also put in a pond and am stocking some fish.
What I would like to know is if a wheel powered sickle mower would help in the thinning of the "thousand's" of young saplings that reappear every year???
The saplings are mainly ash, elm, buckthorn etc. All I have to "farm" with is an old liquid cooled Kawasaki ATV 400 Bayou. It has a poor turning radius but lots of pulling power. I would also use the mower to cut down the prairie grass which gets quite tall (3') to alleviate fire danger around the outbuildings. Any info I could glean would be greatly appreciated. I'm trying to get by on the cheap, sickle mowers can be found here fairly regularly at auction. I would have to dismantle and rebuild probably. Thanks for anyone who may help!
/ New member #2
14ac? I'd get a tractor.. even if a scut...
if you have bigger work, open areas, and constrained budget.. a good classic or antique can do alot of work and save some bucks..
soundguy
/ New member #3
Try scrolling down the main page to the Gravley & Ariens section of the forem and ask some of the people that have this type of mower,, Good luck to you..
/ New member #4
Hey CatFish,
When I was younger man, I had to mow hay with an old John Deer ground powered sickle mower ... I was pulling it with a tractor .. but I can recall using my full vocabulary (and even some made up words) to describe the process... I was very happy when the old man sprang for a PTO powered sickle mower...
I realize with the ATV using the PTO is not an option ... how about one of them gas motor powered brush hogs .. I think I've seen TV commercials for them?
Tractor / ATV on!
/ New member
Thanks for the quick replies!!! I have been looking at other options-BCS walk behind units that can be had with a host of options-but the woman (with the purse strings) thinks we can do it cheaper. I'm an older fella myself with lots of mechanical background and thought I'd ask here first. I really appreciate all advice given me! Maybe I could just get a disc unit for the ATV??
Bruce
/ New member #6
a cat 0 disc for an atv is lil more than a toy.
if you are on a budget.. get an antique tractor... compaired to new.. HP are pennies on the dollar. In many cases you can get a used for 00 series in 33-48 hp for 1800-2500$ and get some real work done. might even get a package deal and get a mower and disc with it for that price.
soundguy
/ New member #7
That is good advice from Soundguy. An old tractor will work much better than an ATV. I bought a SCUT, and owned a 450 ES honda as well.
/ New member
Thanks!! I now can narrow my search and sound / appear to know what I'm talking about, I would like to have more options for "down the road". It's funny, I first started using the internet in 1990 and there wasn't much out here, now I don't have to waste near as much time!!!!:licking: I will post more when I can show I have the job corralled (sp?).
Thanks
/ New member #9
Bruce
Welcome to the forum Bruce,
For the the work you are doing the smallest
diesel powered BCS with a flailmower
attachment will do everything
and more for you and you will be able to
do a lot more with the 2 wheel tractor as well.
You can buy the mowing sulky for it and sit back
and just mow.
Visit the Earth Tools - Walk-Behind Tractors - (502) 484-3988 homepage and
you will be able to see everything the gentleman
has to offer.
He has a working farm where he uses his 2 wheel
tractor for the farms needs.
The towed motorised flail mowers from england are 2 and three times as expensive as the smallest BCS and the flail mower attachment for it.
/ New member #10
I built this to pull with atv to mow around pond dont know how big it will cut. I also built a tree shear that goes on the front of the atv I use after we burn off the prairie grass and its to muddy to get anything else on ground. if I get a chance I get will get photo of tree shear this weekend
/ New member
Well I thought I had better post an update! I am rethinking my strategy now thanks to all your input!!:mad: What I thought to be a simple plan of attack on my sapplings has evolved into more research. I will not be using my ATV for dragging a sickle mower. I AM going to look around for a small tractor capable of handling attachments. Also, I found out that there is a dealer 40 miles away who handles the "walk behind" type tractors (BCS brand). I really like this forum and the knowledgeable contributors. :)
/ New member #13
Good luck, as you have learned, there is generally no "cheap" way to do this sort of thing, just "less costly". I too am an older guy. I grew up farming and then got out of it to the point I didn't have any kind of tractor. I started by using my pickup then ATV then a well used Ford NAA.
I now have some fairly new equipment and the work is much easier. I know from experience that you don't get younger or stronger with the passage of time, so be thinking long term even if you can't swing it now. As per Soundguy older tractors are still a pretty good way to go and if you are mechanically inclined. you may never need anything else.
In the interim look at a good spray rig for weed and sapling control and maybe some controlled burns.
Good luck.
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A69167)
2001 FREIGHTLINER...
2020 Nissan Murano SUV (A66738)
2020 Nissan Murano...
FOUR RACKS OF MISC FILTERS (A68842)
FOUR RACKS OF MISC...
2025 Auger with Bits Mini Skid Steer Attachment (A66734)
2025 Auger with...
2015 Ford F-350 Knapheide Service Truck (A66736)
2015 Ford F-350...
225/70R16 Tires - Set of 4 (A68134)
225/70R16 Tires -...
