Foam insulation removal
/ Foam insulation removal #41
I think you want the adjuster to tell you how to get it off and that he'll find and pay the guys to do the job.
I remember using the "fail" paint removers, and they would beat the paint off a surface for sure, but the needles would also go flying, too. Can you even buy them now even if you wanted to?
I'm not sure if they still make them or not. I did try a brass wire brush on a 4.5" angle grinder too. No go.
/ Foam insulation removal #43
I am understanding this thread correctly that you've been able to scrape (or is it cut?) a little off at the time with razor blades, but even a wire brush in an angle grinder won't take it off?
Thats about the way it is. I should be hearing something from the ins co soon I'd think.
/ Foam insulation removal #46
I'd be leery of a wire brush on a grinder. spins too fast and may gouge the concrete depending on hardness he speced the floor to be.
They have putty knife scrapers you can buy to attach to a reciprocating saw. flexible but quicker.
/ Foam insulation removal #47
I don't know why I continue to follow this thread, but I do. Get a floor scraper from a paint store and scrape it. Then sand with a floor sander with #80 screen. I have done this very, exact, same job before. We then sealed the concrete. Quit beating the dead horse and do this.
My friend, this is open cell.....not closed. The few places where 'closed' is at come off easily.
/ Foam insulation removal #49
Open cell should not have created that kind of overspray and residue. You will typically find only a few spots to scrape, but not the fine continuous mist that is in your picture. We only get this from closed cell. Secondly, open cell cleans up far easier than closed. I am sorry for your experience and hope you get it worked out.
What product did your contractor use?
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2019 22ft Forest River Salem Cruise Lite T/A Trailer, (A61574)
2019 22ft Forest...
2012 Ford Explorer SUV (A61574)
2012 Ford Explorer...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
KBH Tender (A63688)
KBH Tender (A63688)
