Did I break it bad?
/ Did I break it bad?
I'll wager your wedges weren't properly adjusted. Due to loader movement, they do have to be adjusted occasionally (even if the loader isn't removed and re-installed).
I'd say that might be a good wager...:thumbsup:
I see that the wedges are mounted in slotted holes. The bolts in one of the wedges are in the bottom of the slot while the other on the opposite side of the tractor are in the top of the slot. I does appear that they have moved recently.
They could have moved when the FEL gave way - or before. Anyway I need to get up and going.
I know I'll have to take them out to replace the arm back in the bracket so I want to put them back in correctly.
Is there a procedure for adjusting these wedges?
Should I replace the bolts with new ones?
Edit: I'll still have to address the issue concerning the relief valve.
Thanks
/ Did I break it bad? #22
Thanks
Can't hurt to replace the bolts, but probably not necessary.
As far as the procedure:
Loosen bolts
Tap wedges until solidly in place
Tighten bolts and torque.
I'm pretty sure the torque is 90 ft-lbs, if memory serves me (of course, I'm lucky to remember my name...which, coincidentally, is why my TBN nick is my name...if I ever forget it, I can just log on to TBN).
This procedure is in the operator's manual for your tractor or loader, BTW.
/ Did I break it bad? #23
You can see those black parts in the loader recepticals? They're called "Wedges".
When the loader is installed, those wedges are tapped down, then the bolts are torqued.
That would be correct and should be done every time the loader is installed on the tractor. The big thing here is the loader has to be supporting the tractor before the adjustments are made.
Your wedges are rubber? Odd... The wedges on my old 670 (#60 loader) were steel.
Since MarkV brought up the relief valve...good point. It should have relieved before the loader came off the mounts. That valve might be sticking. I had both rear tires (no 3PH ballast) off the ground and the loader never came off the mounts (nor did the relief valve let go...)
My JD650 had the #60 loader also and the wedges were steel.
I'm not sure what you mean by this. Are you saying to put the weight of the tractor onto the FEL before I torque the wedge bolts?
thanks
/ Did I break it bad? #25
thanks
I'm not sure what he means either...but you do want those masts seated in the recepticals.
/ Did I break it bad? #26
Once the loader is on and your front brackets are engaged, on level ground drop the bucket to the ground and slightly lift or take the pressure off the front of the tractor. This will ensure the loader back supports are seated to their fullest then loosen the wedge bolts, adjust and tighten.
/ Did I break it bad? #29
I was just thinking what would be the result if only one side had let go!:(
/ Did I break it bad? #30
Wrong - After the loader is re-installed and the wedges correctly adjusted, do not tinker with it. Closely study the position of the wedges, and make a proper permanent note as to where the wedges are. Use a Sharpie magic marker, and put some thought into it.
Once the wedges are correctly positioned, let them alone. They are not meant to be adjusted each time the loader is installed.
Each time after mounting the loader, make a visual check to see that the wedges have not moved. If the wedges continue to shift, then that problem needs to be corrected.
/ Did I break it bad? #31
I believe you are in error...IIRC, the operator's manual specifies the wedges to be checked (adjusted) each time the loader was installed. Not much to it...
I had the #60 loader which used those wedges...the thread the Gizmo2 linked to pretty much explains it.
Adjusting wedges isn't rocket science...very simple operation that takes two minutes if you're really slow.
Just out of curiousity, have you ever owned one of these little Deeres with a #60 or #70 loader?
I got it back together. I used a come-a-long to pull it back into place and after some wigglin' and adjustin' the wedges went in and I have them tightened down on the mast arms.
The hydraulics all seem to be OK. I can raise and lower the bucket and it rotates. I'm not going to put it under a load until I've had a chance to go over the entire tractor and do a long overdue PM. I'll need to get a torque wrench and take care of those wedge bolts too.
Thank-you all for helping me through this. Truth be told, the last thing I needed to have to do was spend money on fixing this tractor.
Very soon I will be toasting all the good folks on this forum with a cool beverage.
hud
/ Did I break it bad? #33
hud
I know we were all glad to help...but after that toast, you might want to figure out why the relief valve didn't function.
I wonder if the wedges were so bad out of adjustment that they gave before the relief valve had a chance?
hud
/ Did I break it bad? #35
Roy I brought up the relief valve question originally. Now I am wondering if the wedge adjustment thing, not something I have owned, could have been out of adjustment in a way that caused the loader mount to fail within the hydraulics design specifications? I know you owned the same tractor, any thoughts?
MarkV
/ Did I break it bad? #36
In all fairness here I did inadvertently leave out the work "Check". Whad'ya know, we are all correct.:D
/ Did I break it bad? #37
MarkV
I don't know...but I do think it's quite possible those wedges may have been loose. Hudlow did think they were tight, however...
As you know, the adjustment bolts are threaded in to them, so they would not come out completely.
Hopefully, hudlow will get it all installed and have no further problems. So, unless hudlow posts more, I'd reckon this thread is about finished.
/ Did I break it bad? #38
One more thing to check. Are you sure that the lock cams were fully engaged? I think I once did something similar when I didn't notice that the springs between the lock rods and cams had compressed without the cams rotating into the forward "locked" position. At all other times my loader simply goes into relief if I try to lift something that is too heavy.
/ Did I break it bad? #39
I have used a 955 with a 70 loader on it quite a few times. I have removed and re-installed the loader about four times. Tomorrow I will visit the 955 and
check the wedge detail while I am there.
The wedges are a semi-permanent adjustment. Once they are correctly set
they should only need adjusted to compensate for wear. Fiddling with them repeatedly will lead to them not staying tight.
MarkV probably has the correct analysis. When the dealer mounted the sub-frame and the loader, they did not adjust the wedges correctly.
Everybody with a 60,70, 80 loader should check their wedge adjustment.
/ Did I break it bad? #40
I disagree with you and adjusted everytime the loader was re-installed. This was done numerous times in the 2-3 years I owned the 670.
However, the manual just states the procedure and doesn't really specify how often....matter of how you interpret the manual, I suppose.
And, they never got loose (referencing your last statement).
(ADDED)The attached file is from the manual. It was an attachment on the thread the Gizmo2 linked to. Note the FIRST (bolded) instruction.
2016 CATERPILLAR 308E2 CR EXCAVATOR (A64279)
2016 CATERPILLAR...
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A59911)
2012 FREIGHTLINER...
2017 Mack Semi (A64047)
2017 Mack Semi...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
