Any Good Uses for Busted Leaf Springs?
/ Any Good Uses for Busted Leaf Springs? #11
Keep the spring. You will find many uses for the metal. Springs are made from very good steel. They can be re tempered to very hard or almost dead soft. But most of the time just use them like they are.
They make good knives, a fro, big chisel's, bucket teeth. Guess just about anything that requires good steel. The temper changes very little when cut or welded.
/ Any Good Uses for Busted Leaf Springs? #12
I've heard about the homemade knifes with that steel.
Personally I might be tempted to scrap them, if they can't be used for weld projects, I save all kinds of steel for fab work, but I don't think spring steel would be good for that.
JB.
/ Any Good Uses for Busted Leaf Springs? #13
Believe it or not and I would have taken the "not" option prior to seeing this done. I have had a trailer for about 30 years that have welded springs on them. I questioned the practice when the trailer was given to me. The man who built the trailer told me that as long as you weld along the long part of the spring and not across they will hold up. Turns out he was right. I wouldn't want to use the practice for long road trip trailers, but this one has been from KS to Wyoming twice and Chicago a couple times and no problems. It has been overloaded on numerous occasions. (springs bottomed on the axle)
In addition I grind form tools from leaf spring for use on my metal lathe when I am cutting wood patterns. Lots of good uses for old leaf springs.
/ Any Good Uses for Busted Leaf Springs? #14
My dad used to make knives from them. I don't remember all the steps tho, I was to young
James K0UA
/ Any Good Uses for Busted Leaf Springs? #15
James K0UA
I have a hunting magazine from 1954 that explains how to make a knife from a leaf spring. Cutting shaping and tempering.
Google leaf spring knife. Lots of hits.
They also make good "spud" blades for ice fishing.
/ Any Good Uses for Busted Leaf Springs? #16
Ive used them welded on the end of a pipe for an ice chisel in the winter...
/ Any Good Uses for Busted Leaf Springs? #17
Knives bucket teeth, chisel and subsoiler shanks. I had a friend that used to travel to China alot with his wife. He brought back several pictures of kids gathering leaf springs in wagons. THey picked everyone of them up in the scrap yard. They made hoes and froes and other things from them and alot of loader teeth there and in Mexico and here are relined with them.
THe man that builds our dumpsters uses large truck leaf springs as tooth caps for a local gravel co. New teeth wear super fast and are about 85 dollars each. He caps them with springs and they last 6 months or better. Ive seen them made on a friends chisel plow that came off a pick up. Personallt Id save them for something. One spring wont make you a hoarder lol.
/ Any Good Uses for Busted Leaf Springs? #18
I have a pickle fork that I made from a single leaf semi trailer spring. The single leaf spring made the best PF ever for heavy duty truck tie rods and such. Separates the toughest of all large tie rods with ease.
/ Any Good Uses for Busted Leaf Springs? #19
Welcome to TBN !
Sounds like a great idea :thumbsup:
JB.
/ Any Good Uses for Busted Leaf Springs? #20
Popular for knife making.
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2025 CTRA 4X2 T/A 16FT ENCLOSED TRAILER (A59906)
2025 CTRA 4X2 T/A...
208320 (A58375)
208320 (A58375)
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2018 John Deere 4X2 TX Gator (A60463)
2018 John Deere...
