Any Good Uses for Busted Leaf Springs?
/ Any Good Uses for Busted Leaf Springs? #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
In the process of re-building a trailer I found a busted leaf spring. Right now the leaf spring is in the scrap bin, but I wondered if there is some genius use for it worth more than the 4 cents a pound or whatever I'd get at the scrap yard.
Any and all suggestions welcome.
/ Any Good Uses for Busted Leaf Springs? #2
I made a homemade 3pt fork, using 2 equal length leafs as forks.
/ Any Good Uses for Busted Leaf Springs? #3
I have one about 2 inches wide from back when springs were tapered thin toward the end and the end was rounded. My father used it as a tire iron on his A-Model ford tires so I continued the tradition. Just a few years ago I bought one similar at a garage sale that is just a little shorter and about 1-1/2 inches wide. They make a perfect pair. They are half of a full length springs.
/ Any Good Uses for Busted Leaf Springs? #4
We use to sharpen them and peel pulpwood - good for peeling fence rails.
/ Any Good Uses for Busted Leaf Springs? #5
Leaf spring material is a hard steel. I can be used to make all kinds of tools and such. If it were me, I'd keep every piece of it.
No Kidding!!! I guess I thought the springs would flex too much. Those must have come from some very big springs.
/ Any Good Uses for Busted Leaf Springs? #8
No, the springs are actually medium size, maybe from a 1/2 ton pickup. They do flex some, but it hasn't been a problem so far.
/ Any Good Uses for Busted Leaf Springs? #9
Single spring works great as drywall (or any sheet material) lifter. Stand wall board up and slip arced spring under apply foot pressure and presto!!
/ Any Good Uses for Busted Leaf Springs? #10
In third world countries where they recycle everything I have seen them used for cutting edges, for heal plates on buckets, harrow teeth and a hundred other things I can't remember right now.
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
DEUTZ MARATHON...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
