Tooth Bar for 68" Bucket
/ Tooth Bar for 68" Bucket #1
tonydn6
Member
New York
Bobcat CT235
Hey guys, I have the Bobcat CT235 with the 68 inch bucket. I am in NJ but keep the tractor in NY and won't be up for a few weeks. Can anyone with the 68 inch bucket help me with the bucket inside measurement. Need that info to order bolt on tooth bar for my bucket. I am assuming 67 1/2 or 3/4 but want to be sure. Thanks guys!
/ Tooth Bar for 68" Bucket #2
Mines CT225 w/same loader. Bucket is 67 1/4" inside. That's at the actual boucket material where you have to drill through the sides.
Note: this is on the first version loader (Rhino built) not the model year 11 that came out last Fall (Bobcat built).
/ Tooth Bar for 68" Bucket #3
You didn't ask but if I were you I'd go with a minimum of 7 teeth and probably 8,for that width.
Boone
Pic is 64 1/2 " inside (7 teeth).
/ Tooth Bar for 68" Bucket #4
The Bobcat dealer had a set of 7 bolt-on teeth with hardware for under $90 for the 68" bucket on my CT335. They fit nicely into the predrilled holes, and installation took about 15 minutes.
/ Tooth Bar for 68" Bucket #5
Can you ask if they have extra one to ship?:drool:
/ Tooth Bar for 68" Bucket #6
I was looking for teeth to bolt on to the existing holes in the 68" bucket. My dealer didn't think they had anything. Do you have a part number?
/ Tooth Bar for 68" Bucket #7
The sales slip lists item # 6728247. The number 0727455 is cast into the top of each tooth right above the Bobcat name. The kit included 7 teeth and 14 bolts with nuts.
Thanks SSdoxie...I have the rhino loader, so assuming all is the same. 67 1/4 it is then. :thumbsup:
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
3 PT AUGER W/ SHAFT (A64280)
3 PT AUGER W/...
