Tooth Bar for 68" Bucket
   / Tooth Bar for 68" Bucket #1
tonydn6
New York
Bobcat CT235
Hey guys, I have the Bobcat CT235 with the 68 inch bucket. I am in NJ but keep the tractor in NY and won't be up for a few weeks. Can anyone with the 68 inch bucket help me with the bucket inside measurement. Need that info to order bolt on tooth bar for my bucket. I am assuming 67 1/2 or 3/4 but want to be sure. Thanks guys!
   / Tooth Bar for 68" Bucket #2
Mines CT225 w/same loader. Bucket is 67 1/4" inside. That's at the actual boucket material where you have to drill through the sides.
Note: this is on the first version loader (Rhino built) not the model year 11 that came out last Fall (Bobcat built).
   / Tooth Bar for 68" Bucket #3
You didn't ask but if I were you I'd go with a minimum of 7 teeth and probably 8,for that width.
Boone
Pic is 64 1/2 " inside (7 teeth).
   / Tooth Bar for 68" Bucket #4
The Bobcat dealer had a set of 7 bolt-on teeth with hardware for under $90 for the 68" bucket on my CT335. They fit nicely into the predrilled holes, and installation took about 15 minutes.
   / Tooth Bar for 68" Bucket #5
Can you ask if they have extra one to ship?:drool:
   / Tooth Bar for 68" Bucket #6
I was looking for teeth to bolt on to the existing holes in the 68" bucket. My dealer didn't think they had anything. Do you have a part number?
   / Tooth Bar for 68" Bucket #7
The sales slip lists item # 6728247. The number 0727455 is cast into the top of each tooth right above the Bobcat name. The kit included 7 teeth and 14 bolts with nuts.
Thanks SSdoxie...I have the rhino loader, so assuming all is the same. 67 1/4 it is then. :thumbsup:
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
BAT WING SHREDDER (A58214)
BAT WING SHREDDER...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
