deflector rope
/ deflector rope #1
sgoldste01
Webster, NY
John Deere GT245
I have a JD GT245 tractor with 54C deck.
Not surprisingly, there are times when the plastic deflector hanging off the right side of the deck gets in the way. Some people remove the deflector, but I'm not fond of this idea for safety reasons (I'm guessing it keeps things like rocks and such from being flung high into the air).
What other solutions do people use? I think I've seen that some people attach a rope to the deflector (and perhaps tie the other end of the rope to the cruise control arm that's also on the right side of the tractor) so that they can easily grab the rope and lift the deflector as needed.
Is that a good solution? Other ideas?
Thanks!
Steve
/ deflector rope #2
I did the rope thing for a while, but have since taken the deflector off completely.
/ deflector rope #3
Deflector off for me too. Seems the rope would just be in the way for getting on and off that side of the tractor.
The one thing that I think the deflector is good for (and the only thing that I see) is keeping some of the grass clippings from blowing back onto the operator when it is windy. Other than that, no other use. If for slowing objects down, no people should be in the firing line when mowing. And the times the deflector is in the way and would be pulled up with the rope, are the times mowing close to an object (wall or tree or rock) and the chances of reflected objects is very high. Good eye protection is a good idea for the operator.
/ deflector rope #4
Took deflector off on mine to but I bolted a 4" wide strip of rubber belting over top of the discharge where the deflector hinge was, this keeps most of the clippings and debris from flying up in my face but still lets grass blow straight out.
/ deflector rope #5
I did the rubber thing myself on a push mower only I used the rubber used on roofs.works great...russ
/ deflector rope #6
I use a rubber bungee to hold it back for extended periods of time when not mowing.
It does get in the way sometimes when mowing but I thought if it were removed things would fly out in a dangerous trajectory?
JB.
/ deflector rope #7
We did this on our Cub Cadet LT1050 (which is for sale BTW):
The rope ties onto the RH handle on the fender and loops over the deck lift handle.
Aaron Z
/ deflector rope #8
On my JD 185, I have a piece of 1x2 with a hole drilled in it sitting on the top of the mower deck. There is a carriage bolt going through the wood block and in between the guard and the top of the deck (i.e., right through the middle of the hinge), then a washer and nut on the inside.
This works on that machine because there is a ridge in the plastic guard that fits right over the 1x2.
/ deflector rope
Where can I find this rubber belting material?
/ deflector rope #11
Tractor Supply Co. and other farm equipment places may have rubber belting used for hay rollers.
You could cut up an old tire sidewall, too, I suppose.
/ deflector rope #12
Steve
Well, I think you're on the right track safety wise; but not for the primary reasons you suggest. The lawyers told the factory to put on a deflector as it gives a few extra inches of barrier before someone puts a foot into the discharge opening while the blades are moving.
/ deflector rope #13
I cut mine in half, and then I have a bungee for when I want it open completely. If I would take mine off completely, a good portion of the right blade tip is completely exposed, and that sucker is movin.
/ deflector rope #14
You can't legislatte common sense, but you sure can sue when it's circumnavigated ;' >
The concept of the pull rope is a great idea, and I'm gonna' do dat..
However I WILL leave the discharge deflector chute in place. If something can happen in will, even with best intentions. Read the chainsaw chaps thread =80..
Way back, my dad had a kid mowing his lawn at the country place and said kid (college city kid and a dance major), ended up chopping off a big toe with the mower. His error however was mowing downhill on a slope with a push mower. Slipped and stuck his foot under as he fell. Ouch!
Dennis (WA)
2025 Pabreak 84in. Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak 84in...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
iDrive TDS-2010H...
2016 John Deere HPX Gator 4x4 Gas Utility Cart (A61567)
2016 John Deere...
