MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,299
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Pajoube,
What attachments do you have and how are you using them? I'm looking at using buckets/blades for moving gravel and maintaining about 300 yards of road and using the brush cutter on about 4 acres.
Have you ever tested your 425 to see just how much it will lift? If it would lift a and transport a bucket full of gravel for a couple hundred yards, that would be fine with me, but it would also be interesting to see how close you could get to the 800 lb stated limit. If I end up purchasing a PT 425, I know I'm going to run that test.![]()
PJ is the poster child for PT425 excavating work. I think he has dug the largest hole for the smallest tractor using his mini hoe and bucket. :laughing:
As for the 800 pound lifting capacity, I think they measure that at the quick attach and I don't think it includes the weight of the attachment. With that said, I have hauled several 20 yard dump truck loads of moon dust (granulated limestone) around out kids' ball park over a two day period. The large light material bucket was over-heaping and the back tires were bouncing. I hauled it in reverse with the bucket low to the ground so it acted like wheelie bars while going the full 8mph in reverse! The little PT425 excels at hauling lots of loose material FAST! :thumbsup: The distances covered were around two diamonds and down the middle, so about 800 feet. That was the biggest workout I ever gave the machine and I was quite impressed.
