How do you like your 62D drive over mower deck?
   / How do you like your 62D drive over mower deck? #1
purpony
CT
JD 2440/JD 3020/JD 314/JD 345/JD 850/JD 2320
I purchased my 2320 new in 2008. I also purchased a 60" woods (painted JD green) rear mount finishing mower. Loved the mower in the beginning for several reasons, shoots the cut grass out the back, not to the side, and its a quick and easy hookup. Things i dont like about it is, pain to store and its harder to mow around things since its sticking off the back.
I found a good deal on a barely used 62D drive over mid mount deck but need to pull the trig shortly if im going to buy it. I was wondering how everyone liked theirs and was also wondering, is it a pain in the butt to install? I use my tractor for everything so i am always taking the mower on and off.
I also was reading something about the 2320 and/or 2520 height adjustment knob now working correctly? is this a big problem? I like to leave my grass somewhat long.
thanks all!
   / How do you like your 62D drive over mower deck? #2
I love my 62D for its ease of install and removal. The toughest part is the PTO shaft, as its tucked back pretty far and a bit off center.
being able to drive over the deck, attach the pins and front support, raise the lever and drive off is a snap. Coming from a 755 with a slide in install of the MMM makes this one so much easier.
I have found that the height control is not as precise as I would have hoped. I mow at 1 click down from lock, or 2 down, and if I go any more than that, it seems to lower the deck over an inch to the next click, which is just too short from my lawn. I also mow long and have found the highest setting to be the best. Its just too bad that its a waste of all the other dial settings.
I do wish I had the brackets for the iMatch, not that I have one but would be a nice place for chains when I move it around. I guess some have the brackets, others don't.
   / How do you like your 62D drive over mower deck? #3
I agree with Jester. I really like the 62D. The hardest part of installing is the driveshaft, but after the first few times it's pretty easy. Why it doesn't have more upside adjustment is not clear, but it's OK in the upper positions. You have to make sure you have the lift arm links adjusted so it's right at the up-limit stop when in the locked position, otherwise you have no usable height setting.
I don't have the 3-pt brackets on mine, but I lift it with a strap around the front wheel supports and a the loader. I'm making a vertical stand for it for service and storage which will help a lot.
It's a real good match for the 2320 for mowing around trees, shrubs, etc. Some people have complained about the 2320 gearing for mowing but I don't have much slope and mow in high range all the time.
   / How do you like your 62D drive over mower deck? #4
KennyG please post some photos of you vertical storage when you make it. I will be looking for ideas when my 2520 arrives.
   / How do you like your 62D drive over mower deck? #5
I don't have exactly the same system as I use a JD 3520 and a 60D MMM. But the thing was copied from the 2#20 series. It works just fine. Driving over it just requires a bit of attention, no physical effort and generally clean hands at the end. The height setting works perfectly on this model. I'm sure you'll have a lot of fun and a beautiful yard with your 62D.
   / How do you like your 62D drive over mower deck? #6
Here is commercially available option if can't or don't want to make your own: Mower Deck Axles,Carrera,Cayman,John Deere,Kubota
I have been using them for 5 or more years, he even has some of my pictures on his site. Very well made and a great guy to deal with.
   / How do you like your 62D drive over mower deck? #7
Get it,you won't regret it.
The 62D is very user friendly. Once you get the hang of it,it is a snap to install/remove. I'm not familiar with the height deal with the 2320,but the 2520 uses the rockshaft position for height adjustment,and IMO,it's very simple.
Greg
   / How do you like your 62D drive over mower deck? #8
I have a 2520, with the 62D and it is great. I also have an X495, also with a 62" deck. I have one @#**$ of a time with the deck on the 495. As a matter of fact, I usually get a friend of mine that works with tractors all the time to install it for me. Somehow he has the touch for hooking up the PTO shaft. Just reaches under and badda bing.....it's on. Me....forget it.
On the 62D I have no problems. I can't believe how much easier is is to install the deck. I just got my unit late last year, and shortly thereafter I took the deck and loader off, and installed my front blade. This spring I was kinda dreading having to switch it all back, but wow, the deck went on with no problem. The fact that the tractor has a higher ground clearance helps, but to me the main thing is that the PTO is offset a bit, and is much easier to reach. The collar on the stub shaft from the mower stays in the open position, until you get the connection, and then automatically snaps into the locked position.
Very simple operation, if I can do it, anyone can.
As far as the 3pth lift brackets on the mower, JD stopped including them sometime before last September. Mine came through without the brackets, and I was a little dissappointed, as I thought this was a nice feature, especially for cleaning and servicing the deck. Something about JD had done a survey and most respondents didn't feel the lift brackets were all that much of an advantage. (Thats what my dealer apparently found out from Deere) Me....I think there were some safety issues, and to avoid any future potential problems, JD decided it wasn't worth a potential law suit when a deck fell on somebody that didn't have the pins properly installed when lifting it with the 3pth.
REV
   / How do you like your 62D drive over mower deck? #9
"KennyG please post some photos of you vertical storage when you make it. I will be looking for ideas when my 2520 arrives."
Here are some axle stands for my 62D I made from a couple of sizes of round stock and some Harbor Freight 8 inch wheels.
   / How do you like your 62D drive over mower deck? #10
Kennyd thanks for the link, and runner for the pictures.
Looks like you remove the rear wheels and slide a small axle through and add wheels?. I am surprised that the rear wheel mounts are that strong to support the deck vertically.
thanks for all the replies and info. Made the deal tonight on the 62D deck. Cant wait to get it and try it out! Here is a pic. I didnt get a chance to ask the seller if this has the 3pt mounts on it... does it? lol
   / How do you like your 62D drive over mower deck? #12
Yes, it has the iMatch lifting brackets-they are the ones with the two large pins installed. Did you get a manual?
   / How do you like your 62D drive over mower deck? #13
Yes it does have the three point hitch lift points. Those pieces of steel on top at the front with the two pins in each one are the lift points. I wanted those on mine when I ordered it but they quit using them after 2009. But congratulations on your find you will absolutely love it.
Thanks, i was guessing that was them. Its good cause now i can also use the setup i originally made for my rear mount mower for washing and removing blades.
Didnt ask about the manual but im sure the guy has it and will ask for it. He is leaving for vacation so i will not be getting it until the end of may.
   / How do you like your 62D drive over mower deck? #15
Kind of a bummer to learn about not being able to lift with the I match.... I don't have a concrete floor, just gravel so the dolly wheels would useless. I guess I will have to figure something out to be able to carry it.....
   / How do you like your 62D drive over mower deck? #16
I'm with you Tom I was hoping to use the imatch to move it around myself.
   / How do you like your 62D drive over mower deck? #17
There has to be a way to do it. The thing is when you watch the Deere videos online I have seen them pick it up like that... I will have to do something...
   / How do you like your 62D drive over mower deck? #18
Looks like a great deal. I don't want to insult anyone, but if you don't have the manual, the one way to screw this deck up (and my dealer told me this about 4 times in case I didn't read the manual) is to drive over it without releasing the dolly wheels. The deck itself has to be flat on the ground. The dolly wheels won't support the tractor weight.
It seems obvious but my dealer said he had several people break dolly wheels on the drive overs.
thanks for the tip. I would say that is pretty obvious but when you are in a rush, and or new to one and excited to try it out.. i could see someone forgetting to release the wheels!
ok- i probably should have asked this in the beginning, but... i have never used a MMM on my 2320 before and sitting here at work thinking, i have not looked under my tractor in a while... Are the lift arms attached factory on my tractor or is there an install kit?
Next question... i was readying that the 62D deck can be raised and lowered 2 different ways?? using the bucket hydraulics? or the 3pt hitch... is this correct? If i used the 3pt hitch, this raises and lowers the 3pt with the deck? Then if i want to leave the deck on and use the 3pt i need a lockup kit? If i wanted to use the hydraulics, i loose bucket function?
thanks
John Deere Gator (A53317)
John Deere Gator...
John Deere 5075E (A53317)
John Deere 5075E...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
Kubota L3130 (A53317)
