dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,592
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Some of you will recall my previous posts last fall dealing with my grapple falling off. Here is some of it, if you are curious, but basically it turns out that the grapple as designed is not perfectly compatible with the SSQA on Kubotas as the Kubota plate is stepped back slightly at the tip and the Gator grapple is wide open in that area so a little too much flex and it can pop off:
http://www.tractorbynet.com/forums/owning-operating/195968-everybody-loves-guessing-game.html
So here is my fix: I added 2 beefy sections of 3" x 4" x 3/8" angle in the upper corners as braces and added some 3/4" x #9 expanded metal to stop sticks from poking through and jabbing the grill or knocking open the SSQA levers inadvertently.
This is the problem:
You can see the step in the Kubota orange bracket way up at the top - that first 1/2" or so that is exposed is stepped back from the rest of the plate below it.
And here is the angle clamped in place prior to welding to fix it:
Here's a couple shots of it after I finished and painted it up. I am not currently accepting commentary on the quality of the welds
But I made up in quantity what I lacked in quality...I hope..
I do not have time this weekend to try it out yet, but hopefully next weekend I can. I believe this will finally fix the problems I had for once and for all. I forgot to get pictures with it on the tractor after I was done, but it all fits fine and I think will solve all my issues with this. Sad to have to do this to a new unit, but that's the way it goes.
