made a tooth bar for BX25
/ made a tooth bar for BX25 #1
CT Jay
SW Connecticut
Kubota BX25
Just painted the toothbar I made not long ago for my BX25. It got pretty rusted up recently, when it was bare steel, so now after painting it I thought I'd take a few pictures before I began sticking it in the ground and messing up the paint job until it starts to look the way it's supposed to look.
/ made a tooth bar for BX25 #2
Nice work. Paint sure gives it a nice look. :thumbsup:
/ made a tooth bar for BX25 #3
Looks real nice ! :thumbsup:
I see you mounted bolts in a slightly different location on bucket.
Which for a tractor of that size will be just fine IMHO. :cool: ;)
Boone
Even though I used grade 8 - 1/2" bolts, they really don't have much structural stress on them. The shanks of the teeth, curling around and under the bucket, are flush against the leading edge of the bucket, and all the force from digging is there, rather than on the bolts. The bolts are primarily to prevent the bar from falling off when the bucket is in dump position...and they also keep the bar locked in place when back dragging.......but 99% of the load force is transferred direct from bar to bucket when digging.
/ made a tooth bar for BX25 #5
Once again. :thumbsup::thumbsup::thumbsup:
Boone
/ made a tooth bar for BX25 #6
If you're willing - what was your source and cost for the teeth? Looks great!
APease.....here's a link to a post I made on the TBN welding forum back a few months ago when I first built the toothbar this winter, before I painted it.....
http://www.tractorbynet.com/forums/2277272-post36.html
One thing I probably didn't mention in that post was that I used two 3/16" x 48" pieces of steel stock from TSC, which I then doubled up to make a single 3/8" piece by welding all around the perimeter. I realized that a single 3/16" piece would be too flimsy. I then trimmed it down to 46 & 1/2" to fit inside the BX25 FEL bucket (and welded the ends to seal off all edges)
It was my first welding project, and I ran into a warpage situation, and the guys on the welding forum had lots of great advice, since I had no idea at the time that warping is a common problem with welding......if you're interested in seeing the whole thread, this is it....
http://www.tractorbynet.com/forums/welding/197781-how-straighten-out-warped-steel.html
When I was making my toothbar, I copied a lot of ideas from an earlier post by Tachdriver, who had made a really great looking toothbar......here's a link to his original post, with his pictures of his design, if you want to see a better job than what came out of my own efforts....
Made my own Tooth Bar for the BX-25 - Page 2 - TractorByNet.com
/ made a tooth bar for BX25 #8
Nice!!! :thumbsup:
/ made a tooth bar for BX25 #9
Hi Ct jay:
Could you provide details on the clamp on bucket hooks/brackets on top of bucket. These look similiar to what bxexpanded sells (which I have 3 SOMEWHERE in garage). Would like 2 do something similar but use on grapple to make quick removalable.
Thanx Pat R
Dah after looking at your profile see they are bxexpanded didn't remember seeing brackets there just hooks guess some digging in garage this weekend is in order. lol
They are indeed BXpanded products that you saw on my FEL. Can't remember what was in the pictures I posted of my tooth bar, but currently I have 3 hooks (one a slip hook, in center) and two clamps for BXpanded's pallet forks. All are listed on their website BXpanded.
Stargazer......I assume you're an astronomer, by profession or hobby, from your screen name?
I dabble a bit in astronomy. I have a Celestron 11" SCT (Edge HD optics) on a Celestron CGEM mount, and several TeleVue and Explore Scientific eyepieces, etc......but I'm starting to think I'll never get to use my scope again because it seems it'll never stop raining here.
J
/ made a tooth bar for BX25 #12
Hi CT:
Just as hobby have a 8" konusky reflector that I need to set up and try/use as well as an ancient 4.25" edmund scientific from 40+ yrs ago. God wonder if still in business. It was the pallet fork brackets that had me confused. mine are screw tighten on bottom of bucket, different manf. Yes either raining or to hot/buggy here at nite. thanx again for info, sent email to bx to see if can buy unpainted/no hook part alone else when find my hooks will "borrow" idea to copy for grapple.
PR
2021 Case TV450B (A64126)
2021 Case TV450B...
2012 PETERBILT 367 (A65643)
2012 PETERBILT 367...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
