Bradco bachoe questions...
/ Bradco bachoe questions... #1
55acwd45
Have a Bradco 9hd backhoe from a skid loader that we mounted to our WD45. Tractor has an old PTO hydro pump, seems to work well.
Problem is that there doesn't seem to be enough pressure for the backhoe. The stabilizers won't completely lift the tractor off the ground. Loader has 20 gallons of fluid in it and almost all the lines are new. From the pump it goes to the relief valve which is directly threaded into the diverter valve. I took the relief valve apart (ball/spring type) and it had already been threaded in the entire way. And the backhoe has a new filter.
I was told that the backhoe is most likely a closed loop type. And the tractor being an open loop as the return just dumps unrestricted into the reservoir. Anyone know if that could be the problem? Loader and hoe are plenty fast. The loader will lift about 1500# and when the bucket its tilted down it easily lifts the front of the tractor off the ground at idle. Have only tested the backhoe's functions as we are not quite done with the mount yet.
/ Bradco bachoe questions... #2
You will need at least 11gpm to operated the backhoe...that's the Bradco spec, not mine..I have a 511 bradco and use their PTO pump setup..holds 15gals of fluid and put outs at least 14gpm..your resevoir tank must be at least as large as the hyd pump capacity..BobG in Va
I guess I should have specified more clearly, the loader and hoe use the same reservoir and PTO pump. The tank has 20 gallons in it right now and should hold a few more gallons. I don't know what my pump is, but I'd guess that it is around 20gpm. I think its 11-14gpm spec for the hoe. From what I've read they work fine with stock pumps like on a Kubota, just very slow. The vertical sections of pipe and the two bars that make up the loader frame at the reservoir tank. Should be enough there to suck the heat out of the oil.
Do you know if the return line on yours has pressure or just dumps into the tank?
/ Bradco bachoe questions... #4
I usually lift the tires clear off the ground with the hoe, then lower the stabilizers, seems easier.
The hoe won't lift the tractor either... it should if it had full pressure.
When switching from loader to backhoe on the diverter it would lug the engine more. It ended up being the backhoes bronze filter cannot flow enough. The filter was brand new and clean. Took it out and it does not load the tractor now. Will have to put a canister filter on it. Still doesn't fix the power problem though.
Getting there. Have a new relief valve, filter/assembly and gauges on the way. Should be able to get it up to full power after that. Had to beef up the mount quite a bit for the top link. New inline filter for the backhoe (sintered bronze) was too restrictive and put a load on the tractor.
I wonder if the backhoe working as it should could lift the back end of the tractor off the ground with the boom fully extended? Do the cylinders have more digging than pushing power?
Added 1/2" thick 5" wide flat bar on tractor side behind the channel.
Made a new piece for the hoe side. Its 6" wide channel with 4" chanel welded inside of it.
Added 2" wide angle 1/4" thick to corners of mount. And on the hoe side where the tabs for the top link are welded them to a 1/2 thick plate and welded the plate to the channel.
That picture is before but it doesn't look much different. Had to build the entire mount.
I'd guess that the backhoe mount weighs over 100# now. The skidsteer (Gehl?) mount it had was very beefy.
With the loader and backhoe I'd guess the tractor weighs 7000-7500#. Should dig well.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2019 FORD F-250 XL EXT CAB TRUCK (A59823)
2019 FORD F-250 XL...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2019 Ram 2500 4x4...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
