DS vs DK
/ DS vs DK #2
What is the difference between the DK and DS series tractors? I have a CK25 but getting the itch to move up!! Say a 40 or 45
My impression is the DS is a more basic tractor meant to compete with the likes of Kubota's L3400, etc, basic tractors. i.e. it is a step down in some ways from the CK.
For moving up a notch, consider the DK which has a heavier frame and more features.
One thing I particularly don't like about DS is the hump in the middle instead of a flat deck.
/ DS vs DK #3
Yes the DS is a side step to the CK, has
An older design transmission and engine in it. The DK is a more robust tractor, newer engine, transmission and a heavy frame. Deffanantly the next step up if you have a CK
Don't know if you get them in the US but the EX series is in-between the CK and DK, a really good option to look at if your budget can't stretch. To a DK, sold a EX50 to a Contractor a little while ago who is loving it, he just finished harvest with with and he has had so much work for it, it has
Almost paid for itself in 4 months! Not bad considering he originally bought it for his personal property to do weekend work!
/ DS vs DK #4
The DS 4110 and DS4510 are larger, heavier tractors than the CK series, they are based on the original DK chassis, before the SE models came out about 5 years ago. You have manual engagement of 4wd, basic 3 point hitch, basic seat, no tilt steeing wheel, but you get the same loader lift capacity as the DK40-DK50. The DS3510 is closer to a CK35 with same loader lift capacity. I suspect our DS is the EX series mentioned earlier.
/ DS vs DK #5
I did this comparison not too long ago, here's what I remember:
3 point lift lever on the back
standard rear remotes
telescoping three point arms
I believe the seat is better on the DK
tilt steering wheel
These additional features helped me decide to go the DK40SE route instead of the DS40.
/ DS vs DK #7
this is the joys of same name but being different models across the world, over here our DS series is basically the old LX series but with new hoods! DK series looks the same though, still a really good step up to a CK!
/ DS vs DK #8
DS=Cheap Horsepower
A few less features but if you want 35,41 or 45HP with good strong loader lift capacity for minimum cash outlay they are where it's at.
They have sold very well in my area.
BTI
/ DS vs DK #9
We have a DS45 and are very happy with it. The DK has some more features, but we would have had to step down a level to stay within budget.
/ DS vs DK #10
DS 45 in Australia also has draft control , one standard remote and the cheap option of Hydraulic Shuttle.
I wanted as much HP for my dollar and spent the savings on implements.
Very happy with the DS4510HS.
Giyi PG72 QA 72" Grapple (A60463)
Giyi PG72 QA 72"...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2013 CAT 950K WHEEL LOADER (A60736)
2013 CAT 950K...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2006 Freightliner M2 106 Terex Hi-Ranger HR46M 46ft. Insulated Bucket Truck (A60352)
2006 Freightliner...
1995 HEIL  ALUMINUM TANKER TRAILER (A60736)
1995 HEIL...
