Farmall Cub Lo-boy Radiator
   / Farmall Cub Lo-boy Radiator #1
Whitey
Gold Member
Slippery Rock, Pennsylvania
Kabota B21 TLB
A friend of mine has come to me about a problem with his Cub Lo-boy, the coolant is dissapearing in his system and he cannot find the leak. He thinks it maybe the radiator......but we cannot figure out how to pressure test it to fix it. Has someone come up with a way to pressure test this type of radiator? Also......if it is bad....any reccommendatons on a place to buy a rebuilt or after market one?
Thanks
   / Farmall Cub Lo-boy Radiator #2
Try farmallcubforever.com for parts. There are other places that will come up with a seach.
   / Farmall Cub Lo-boy Radiator #3
why can't you pressure test it? no rubber bung adapter for the top?
sounsdguy
sounsdguy
Actually no.......this is my bosses tractor and as I can tell it is completly open at the bottom. He is losing fluid and he cannot pin point the leak. When you take the blasted radiator off.......the bottom is completly open! The bottom bolts on to the engine casting. We could have the radiator repaired but we can't find a leak.:confused2:
   / Farmall Cub Lo-boy Radiator #6
The cub did not have a "pressure" system. The radiator cap has no spring and builds no pressure. Here's a link: Farmall Cub Radiator Cap, original style
Maybe it's the radiator gasket leaking Farmall Tractor Parts and Restoration .
Here's another link to a core Radiator Core - Case / International Farmall Tractor Parts Shop .
Here's a link to how a cub radiator works: http://www.atis.net/CubFAQ/cub_faq_2.html .
Yall haven't mistakenly put a pressure cap on the radiator, have you ??? Or filled it too full.
I know a cub and Super A radiaotor will steam or "perculate" when it has been worked hard.
Chris
   / Farmall Cub Lo-boy Radiator #7
i'm well aware of the cub rad design with cast base. ( i own a cub ) my POINT was to put a rubber stopper into the top of the rad while seated onthe cast base.. add a couple pis air with a blowgun and THEN look for the leak.
soundguy
Gator (A50324)
Gator (A50324)
2019 Harley Davidson (A50324)
2019 Harley...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
