Coated Steel Pipe - Value?
/ Coated Steel Pipe - Value? #1
yeehaw
I've got some coated steel pipe (think the ole 2 3/8) that appears to be brand new - has the greyish - rubber feeling coating on the outside and a lining on the inside. they are 10 ft sticks... any idea of how much they are worth? I cant find anything about them on the internet, everything I find is about uncoated stuff.
I was told i could weld it by just grinding the outside coating off---but I may be better off selling this and getting some other pipe (got this "years ago" for a steal)
thx
/ Coated Steel Pipe - Value? #2
I bet you got coated conduit
Admin
went to a scrap yard - almost no one knew what it was--- one guy said some utility companies use it instead of stainless b/c it wont rust--- but didnt know the value--- just coated steel...
/ Coated Steel Pipe - Value? #4
or, perhaps because it is a much cheaper rust resistant option than stainless steel.
correct - I worded that wrong.... 8~)..
also supposedly "non conductive and noncorrosive" so maybe some sort of conduit but we'll see...but heavy as all get out
turns out it is made by Thomas and Betts and says Ocla on it....may be 15-20 years old - but looks brand new.
/ Coated Steel Pipe - Value? #7
If possible check out the coatings for fume toxicity prior to welding.:)
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
Bush Hog 13414 (A64126)
Bush Hog 13414...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
INTERNATIONAL BUCKET TRUCK (A63276)
INTERNATIONAL...
