What do you think of this stick welder?
   / What do you think of this stick welder? #21
I never was a fan of 6013, if it was removed from the planet today I wouldn't mis it a bit.:laughing:
Vertical up with Lincoln's 6013.
   / What do you think of this stick welder? #22
I still stand by my recomendation of the 6013 rod. But If/when you get the welder, go to TSC or where ever and pick up a pound of 6011, 6013, and 7014 and TRY each for yourself.
IF you get an AC machine, you CANNOT use the 6010 rod. It is DC only. BUT 6011 is the AC equivellent pretty much.
6010/6011 are both HOT rods with LOW deposition rate. That means they burn in deep and dont deposit much filler. It isnt hard to burn clear through 1/4" metal on only 100A. But 6013/7014 it is almost impossible.
Also, due to the low depsoition rate, fit is alot more critical. Peices must fit tight together. No rough torched ends with gaps here and there. Wont weld good at all.
6013/7014 are very similar. (in case you didnt know, the first two #'s indicate the tensil strength of the weld. 60= 60,000psi....70=70,000psi). But both of these rods are easy to weld and "contact" type rods. They have a higher fill rate, which doesnt mean as much penetration, but they can also fill larger voids and cracks much easier, like using a torch to cut ends instead of a bandsaw. They are also much easier to start/re-start.
7018 I'd stay away from for a home "hobbiest". First of all, proper storage is everything. (oven to keep em warm and dry). And 7018 is a DC rod as well. You can get 7018AC, but it doesnt weld as well as 7018DC on a DC machine. And again, the storage. Also, with 7018, when you stop a weld, the end glasses over. You have to take the electrode out of the stinger, and drag the tip across the bench a few times to break the "glass" just to be able to re-start. A real PITA for just a hobbiest.
Again, my best advice is to get a little of 6011, 6013, AND 7014 and try em all for yourself. Personally, at home, My "GO-TO" rod of choice is always 7014.
   / What do you think of this stick welder? #23
Now I am not trying to start anything here, but I do disagree a bit with this. Yes the 7018 forms a covering over the end when you stop the arc, and must be broken off some way, but it is not a big deal, (at least to me). What I have started doing is just "pinch" it off with thumb and forefinger and re-strike it. I do not take the electrode out of the stinger, and it only takes about 1 second to do this. Or you can use a rough file to drag it across a couple of times. 7018 makes great beautiful welds with pretty good penetration. I do not use an oven. Yes I know there will be hydrogen bubbles in the weld, but not too many. Overall I am very pleased with 7018 on my Everlast PA160, usually run in the range from 75 to 85 amps. I do use the 6011 for root pass in thick material, and then cap it with 7018.
I do use some 6013 for thin material where deep penetration would be detrimental. So I would actually recommend 7018, after you go thru the 6013 or 7014 drag rod phase of learning how to hold an arc and watch the puddle. But I will say this, if you want better looking beads, faster with less learning curve, get a DC machine of some kind. Oh and while I am not recommending against the PA 200, or any larger DC machine, I have never needed more than my PA160 has. I guess everyone has an opinion, and now you have heard mine. Thanks.
James K0UA
   / What do you think of this stick welder? #24
You are correct that it really isnt a big deal. But I thought I'd mention it because if no one did, he'd be cursing it trying to get it to restart.
And then theres the lack of having a rod oven as you mentioned. A 7014 weld will hold just as good as a 7018 IMO if welded properly. And the 7014 is easier to run with. PLUS he mentioned getting an AC unit, so my comments are directed more toward a NON DC machine.
And again, IMO, 7014 will do just as well as 7018 for the home welder. So why run a more difficult rod. I like taking the easiest route to get the desired results. And IMO, 7014 is the easier route. If I have a weld fail that was welded with 7014, there's a 99% chance that it would have also failed using 7018.
   / What do you think of this stick welder? #25
I also thought I share a few pics. This trailer was built with nothing but 6013 rod on an AC machine and with all cuts being with the torch.
It was built ~ 15 years ago before we had a mig. And has hauled countless loads of firewood.
   / What do you think of this stick welder? #26
I too had a Lincoln 225 AC machine on the farm when I grew up. Built 2 ea 40 foot long cotton hauling trailers with that machine and a Victor torch using 6010 and 7018 DC rods on that AC machine. Talk about hard to hold an arc, but they did produce sound welds. Those trailers are still around today hauling cotton to the gin. I did have a fair amount of experience welding with DC prior to using the old cracker box, but they will do a fair job if your welding skills are good. DC is more forgiving to the beginner as it is much easier to hold a steady arc with it as you can get close or long arc the rod and it will keep burning with DC, not so with AC. You get to close and it will freeze on you. They can do just about whatever is needed at the home level. As for 7018 storage, I keep my 7018 sealed in the original air tight seal till I need them and afterward, I just keep them dry in a rod storage box with a heat lamp that stays burned out about as much as it stays on. They weld pretty good without a hot rod box. If I am concerned with moisture, I just stick the rod for a few seconds till I see the steam boil off and then start welding with it. As long as you dont keep them exposed to moisture so long that the steel wire in them rusts under the flux, they will work plenty well for home use. For most uses, we dont have to worry about underbead cracking from hydrogen embrittlement. If I was welding on a pressure vessel or pressure piping, heck yeah, those rods would never see ambient temps, but for my farm use, no problem. If it breaks off from hydrogen embrittlement, I will just weld it again. SO far none of my welds have ever failed including those on those trailers that I built about 40 years ago. The hot box I used then was an old refrigerator with a 60 watt light bulb. I kept my 6010 / 7018 and whatever else I had in the same box.
Ok, I guess I'm committed now (or need to be committed). I picked up an auto-darkening helmet, gloves, chipping hammer, soapstone markers and a couple of those magnetic doohickeys that hold piece-parts at 45 or 90 degrees for welding.
Going for the PowerArc200.
Ian
   / What do you think of this stick welder? #28
Ian
I'm right there with you as I bought the hammer, gloves, and magnetic doohickeys last week. The auto darkening helmet is next week, and I think it will be an I-Mig 200 in a few weeks after that.:thumbsup:
I think my first attempt at a project will be a welding table.:cool:
I think I'll be burning a bunch of rod attempting to lay beads on some scrap steel I have around till I get to where I think I can weld something that will hold up. Maybe I'll catch on fairly quickly.
I'm going to try to find some 6010 and 6013 to begin with.
I'll have to rig an adapter extension cord before I can use it. The 220 plug I have out in the barn is for my wife's pottery kiln. It's a bit bigger than a standard dryer plug.
Ian
   / What do you think of this stick welder? #30
Ian
6010 around here can only be had at a welding supply store.
TSC and NAPA both only carry 6011, 6013, 7014, and 7018AC.
But again, that may just be around here
Auger Skid Steer Attachment with Bits (A59228)
Auger Skid Steer...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
John Deere 5525 (A60462)
John Deere 5525...
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
