What do you think of this stick welder?
   / What do you think of this stick welder? #11
I have had one of the exact tombstone welders you are looking at for about 15 years. It has served me well, but it is for sale now, with an extra 30 foot of leads and on a cart with wheels to be able to move it around easily. I was hoping to get about $200 For it, but everyone keeps dashing my hopes, with this $75 to $150 dollar talk.. tho the cart (hand truck) costs about 30 dollars and the leads cost nearly $100 now. It will work well and last nearly forever. BUT..I now have one of the Everlast DC units, and I havent fired up my AC stick welder since.. Just havent found the need to go back to the buzz. The Everlast is 25 pounds, and you can throw it over your shoulder with the included strap and take off with it. The welds are much smoother , much less spatter, and much more pleasant to weld with. Plus much greater control of the heat ranges with the infinite control of a potentiometer, and digital readout instead of a switch with a few contacts. The old Lincoln, does not owe me a dime. I fixed more stuff with it over the years, to easily pay for itself. but if you want it, and you live near southwest Missouri, You can have it. With the one from HD you will soon discover, that you need long leads, as the supplied leads are way to short to do anything with, and the unit is "darn" heavy. Yo WILL want a way to move it around. DC is the way to go, you can make good, and even pretty welds with an AC only machine, it is just a little harder to do. If you want free advice, and maybe worth what you paid for it.. Spend a little more and get the AC/DC machine or get one of the Inverter DC machines. This if from a guy that has been there.
James K0UA
   / What do you think of this stick welder? #12
...Is there anything that the AC unit can do that the DC only unit would have trouble with?
Ian
If you are interested in the the Twin Carbon Arc process that I mentioned earlier then AC works much better than DC. You can use Twin carbon arc on DC but it will not work nearly as well since one rod will consume twice as fast as the other rod making it harder to maintain the flame. On AC Twin Carbon arc burns evenly - even a hack like me can easily maintain a flame on AC. Also, I have no idea if trying to use Twin Carbon arc would even work on on an Inverter based welder or if it would be good for it - it will not hurt or shorten the lifespan of a transformer welder one bit though. This al said if you have a oxy/acetylene type torch and willing to continue buying the expensive gas then this point is not important.
Generally speaking and limited to SMAW welding (aka stick welding), Anything that can be welded with AC power and rod can be welded with possibly a little more ease on DC power even when using identical rod. DC can make out of position work a little easier too - but skilled welders have no issues with AC. DC can also burn a few specialty rods that AC can not. On the other hand: Watch old videos from the 1950's and 1960's and they will claim that AC power is superior to DC power as it eliminates arc blow. Arc blow can sometimes be eliminated with DC too with some tricks.
If you want the cheapest welder that will last you the rest of your life then it does not get any cheaper or simpler than an AC transformer based power unit - Yes AC does have some limitations, but none that prevent the job from getting done in a backyard shop when dealing with everyday common steel. Upgrade a little to an AC/DC capable transformer unit and you will spend more but also have some DC capability that tops out at 1/8 rods maximum, for bigger rods bigger than 1/8" you will pretty much have to switch to AC power in order to have enough amps to power them. With the AC/DC transformer units the AC portion is still as bulletproof just like the AC only transformer welders, but there is more that can go wrong with the DC side like the diodes and rectifier bridges - still they will last a long time though.
An Inverter based welder will almost always be DC only. They will be lighter in weight, probably more powerful, and even consume less electricity to run than a comparable transformer based DC welder that is similar in price. However, Will it still be working 40 years from now - who knows? I do know that if I ever decide to buy an inverter based welder to add DC power to my arsenal that it will be a dual voltage one (115 volt and 230 volt) in order to gain the maximum beneift from the portability factor. Regardless I will never get rid of my AC only tranformer buzzbox unless I just stumbled across a super deal on an AC/DC transformer buzzbox.
There is no one single "low cost" welder that will do it all. It is all a matter what materials you intend to weld and how much you want to pay to do it. Since my welding adds zero dollars to my income, then low cost and durability are of utmost importance to me. For a business that generates profit, then Inverters can make perfect sense too. They can almost pay for themselves since they burn less electricity if used alot in a business environment. Being portable can be good too. Even if the inverter has a relatively short lifespan (still unknown), it can pay for itself in the business world where it might not to a private individual like me.
   / What do you think of this stick welder? #13
My 2 cents. I only need a welder occasionally and I have an old Lincoln AC tombstone that I got as a gift in 1980. For what I do, it has served me well. If I was just starting, I'd look for an AC / DC model used on Craigslist. There is a tombstone model there right now for $250. Look on Search Tempest, and I'm sure you will also find one for less than the new tombstone at Home Depot. Many come with extras tossed in like a helmet and extra cables, rod, etc. If you decide to upgrade you will get all your money back with little effort.
Also, if you do the carbon arc thing, remember that you need to cover every square inch of your body or you will have a sunburn that you will not forget.
   / What do you think of this stick welder? #14
I started my career as a welder (Boilermaker) and I have used many machines through the years. Always DC on the job, but for home I have an old Lincoln tombstone type AC machine that I bought at a yard sale over 25 years ago. It came with a bunch of lead so I never have to move it. I have it near my garage door so I can weld inside or out. The only rod I have ever used with it is 6011. I use 3/32 for light stuff like emt conduit for tree stands and 1/8 for bigger stuff. In my opinion the 6011 doesn't run much different than the 6010.
I have made tree stands, numerous trailers, my box blade, my 3 point hitch drag, and many many little projects.
If I was going to weld a lot I would buy an AC / DC machine, but for what I do my good old made in USA Lincoln does just fine.
I just remembered I have used it with SS rods. I made my wifes clothesline poles out of scrap ss I got at work. It welded just fine.
   / What do you think of this stick welder? #15
...Also, if you do the carbon arc thing, remember that you need to cover every square inch of your body or you will have a sunburn that you will not forget...
Yep good advice. You defintely have to wear your welding helmet when using. Also, I do not leave any skin exposed when I weld anyway so for me it is no different than dressing like I would weld - weld rays are not good for skin either.
Not quite as easy to use as a regular oxy/acet torch, but exponentially cheaper to use as compared to oxy/acet for an infrequent homeowner user like me for heating things.
About as close as it gets to a free lunch so to speak. Adds to my capability arsenal at zero cost.
I would also recommend getting 6013 or 7014 rod to start out with.
I was at Lowes tonight looking at their welding stuff and flipped through a welding book they had.
They said that 6011 required a 1/8" gap between the rod and the weld and the 6013 was a 'contact' rod that you lightly drag through what you're welding on. Seems that would be easier to learn since you don't have to maintain a consistent gap.
What do you think?
BTW... I think I'm getting one of Mark's DC units, just have to decide if the 160 is good enough, or if I would regret not getting the 200 later.
Ian
   / What do you think of this stick welder? #17
You'll want to try several types of rods as you are learning to weld. 6011 or 6010 if you are running DC is easiest by far for out-of-position welding. 7018 lets you just lay the rod on the piece and let it weld at the rate it consumes the rod. They all stick to the workpiece once in a while.
Try Mark's "make an offer" to save a little and get the 200 amp welder. The extra power will be worth it even if it just means you get 100% duty cycle for the range you weld in. If you want even more power check out the competitor Longevity offering 250 and 315 amp models. StickWeld 250 | IGBT 250AMP DC STICK WELDER
Good point. I read that 7018 required an oven for moisture control during storage or you'd get blow holes in your weld from steam. (like I'm not going to get stuff like that anyway LOL)
Ian
   / What do you think of this stick welder? #19
What do you think?
Ian
Learning with drag rod is like learning with training wheels -you won't learn. Start with 6011 & you should be able to hold an arc within an hour, Strong & pretty takes longer. Unless you using rod heaver than 1/8" ( for example buildup or hardfacing buckets, etc) you won't use over 125 amp -200 isn't necessary. Anyone that welds 1/4" or thicker in one pass is a BSer or a serious professional welder with appropriate equipment.
MikeD74t
   / What do you think of this stick welder? #20
I don't claim to be a welder, but get by most of the time.
7018 Rod! Is very temperamental at best One professional welder says "when you get ready to weld, grab some 7018 and throw it as far as you can. Then get some 6011 and weld."
last summer when it was around 100 outside I was running some 5/32 and it looked like I knew what I was doing. That was at about 180 amps on an old AC buzz box. Same rod & welder 50 to 60 degrees outside, even at 225 amps, very hard to strike an arc and just as hard to maintain it. Best way to describe those welds is "Goober's". Not pretty and not strong.
6011 & 6013 Have slightly different qualities and uses, but both are easy to use by most anyone.
1770 (A58375)
1770 (A58375)
2014 HYUNDAI 53FT DRY VAN TRAILER (A59575)
2014 HYUNDAI 53FT...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
1605 (A57192)
1605 (A57192)
2017 Autocar Xpeditor T/A Heil Front Loader Garbage Truck (A59230)
2017 Autocar...
1986 Ford LNT9000 Dump Truck (A56436)
1986 Ford LNT9000...
