Backhoe BH77 broke - defective part?
   / BH77 broke - defective part? #1
TwinCam88
Member
Bridgeport, WV
Kubota B3200 HSD
Well, somehow :confused: I managed to break my brand new BH77 the very first time using it. :( Not sure how as I was just digging the dirt around a stump that I was planning on removing. Thing is, I didn't even start trying to rip the stump out yet...so it wasn't working the hoe very hard. :mad: Anyway, as I'm swinging the boom around to dump the bucket, I notice that the pin (about an inch thick) that connects the hydraulic-cylinder to the boom looks like it is hanging out on one side. I stop everything and get off to look, and somehow the pin is broken in half. :shocked:
I'm not sure what the terminology is for each component yet. :ashamed: so I hope this makes sense. If not, I've attached a pic and marked the location of the pin that broke.
I'd appreciate any opinion/advice/wisdom on what I could have done that would have broke this pin (or thoughts on if it could have been defective) ...and of course, what to do to fix it?
Thanks,
-Dave
   / BH77 broke - defective part? #2
That pin should last thousands of hours and slowly wear from friction but never crack in half. If this is a new unit, I'd assume a factory defect. Have the dealer replace it under warranty.
   / BH77 broke - defective part? #3
I beat the snot out of my BH on my little BX and nothing like that has happened. I vote for a defect.
   / BH77 broke - defective part? #6
Check out Kubota customer satisfaction information site
If it's not you, someone else has the identical problem.
Wow, that's an eye opener.....maybe the tensile strength and/or dia of the pin is not enough for powering both cyls in an actual working situation.....it could happen...
Something can't be engineered right here.......:mad:
I think I'd be at this real carefull to make sure the cyls and housings are not bent up.....:confused2:
   / BH77 broke - defective part? #7
Wow, that should have not broke so soon, but it has two forces on one pin. and the forces are one in the center, and two on the outside, may have been using both boom and dip sick at same time caues it to pinch some how, but like everone eles, that pin should last years. Must be some kinda defect, glad I am getting the BH76a on my B3200 Wednesday. Good luck on geting the pin quickley, so you can get back to playing.
   / BH77 broke - defective part? #9
Oh WOW I hope this dosen't happen on my 77. I might change my pin now to an aftermarket one after seeing this crap.:(
Nope, it definitely wasn't me...this is the first I've posted about this issue as it just happened yesterday. The tractor is new, only has 3 hours on it...and it was the first time using the backhoe.
   / BH77 broke - defective part? #11
TwinCam88 this is not pointed at you:
I have to throw the BS card on the link posted to the broken bh77.
Look at the wear on the bucket. There is no way you can wear the paint off a Kubota bucket in 3 hours of use.
Then look at picture of the 3200 in his heated garage. That picture is PhotoShopped:ashamed:.
   / BH77 broke - defective part? #12
That's a very common setup on the curved boom backhoes. All of the larger machines (Deere, CAT) use a similar design with two cylinders meeting at one pin. Personally, I don't think it looks like a very good idea. I'd much rather have independent pins.
And to think, here I was wishing I had the curved boom with the cylinder on the outside - I had just pulled my cylinder from inside my boom (BH75A) to replace a hose. I'm sorta glad now. Two identical failures like that on brand new backhoes is most definitely NOT coincidence. I wouldn't stop fighting until I got a new backhoe. Shouldn't happen - period.
   / BH77 broke - defective part? #13
Beckmurph: I have to respectfully disagree with the B.S. call. The garage pic is probably a picture of the tractor when new. The bucket certainly shows paint wear consistant with a few hours use. The paint on the sides of the bucket is intact - just dirty. The wear is on the back/bottom. My bucket looked very similar to that after just a short time. You can see the teeth still look sharp and new.
   / BH77 broke - defective part? #14
Looking at the picture of the other broken pin with the bent pin flanges, I would be very concerned. Are your boom flanges bent, or did you see the broken pin in time?
Obviously the pin diameter is too small. The tempering might also be wrong. I would demand a lifetime warranty on the pin, cylinder eyes, boom with full coverage for parts and labor. Have the warranty notarized or whatever it takes, to make it a binding legal document. If Kubota will not stand behind their product, then return it for a full refund. An identical pin will eventually break in the same fashion. Once the standard warranty has expired you will spend several thousand when the boom and cylinders are mangled.
After spending several thousand you will have the same setup, that will break again in the same fashion.
Everybody is building curved boom hoes, only because they look cool and modern. Looks like a poor design to me. The dipper cylinder is often times pushing on the center of the pin that is spanning a wide distance. Sand box engineering tells us that the pin only flex so many times before it breaks.
   / BH77 broke - defective part? #15
The B26 uses the exact same cylinder/boom arrangement, and I have neither seen nor heard of any failures with them (I rent them often for my business). Now granted, they are commercial duty machines, but the engineering behind it is the same, you'd think Kubota would have had it figured out by now.
And I also have to say, they aren't just building them that way because the 'look cool.' The curved boom design really is beneficial when you are digging at near maximum depth or trenching at a fair depth. The digging geometry is much better in those situations. Also better for loading trucks.
   / BH77 broke - defective part? #16
I am going to stick with they are built to look cool. Cat came out with their abortion of a curved boom, and now all loader and hoe booms are curved. It is a sales gimmick. Turn the pressure up or increase the cylinder diameter and anything will have more digging power. Of course it has to be able to handle the higher forces. The best backhoe main boom design is like what is found on a JD310,A,B,C,D. The best extendahoe is like what is found on a Case 580K,L,M.
Best loader boom on an industrial TLB is JD310C,D or Cat 416 etc.
Best CUT loader design is like Kubota 2850, 3410,L35.
   / BH77 broke - defective part? #17
I agree....Sand box engineering also dictates that a machine is only as good as its weakest part......You found it......
I wonder if the yield and tensile strength was not enough for premature failure...there are many grades of steel with different methods of hardening for strength.....could have been an oversight with these pins or weak pin bosses welded into the structure/sideplates......
After this is repaired I'd be putting on a dial indicator in a vulnerable spot to check for flexing under strain while digging or simulating digging......
If it is flexing then it would show inferior/undersized materials used in manufacturing the BH
   / BH77 broke - defective part? #18
The easiest design solution is a 50% larger diameter pin. The better solution would be to have separate pins for each cylinder, but then there is not enough room on top of the boom for both cylinders. CAT exaggerates the curve of the boom to create enough room for separate pins. Early model Fords actually had the first "curved" booms with a common pin if you look closely.
The best solution is the triangular boxed booms as I stated earlier. Kubota has already done the engineering on them.
The pin bosses are not meant to keep the pin from flexing. More SBE.
Why don't these engineers call me with their prototype designs?
   / BH77 broke - defective part? #19
Curved boom being a sales gimmick or not (not), that is besides the point. Both CAT and Deere (in addition to Kubota) are joining the boom and dipperstick cylinders with one pin. Case does not. Works for them. Kubota has a problem here and needs to fix it. Vaguely reminiscent of the bending cylinders on the BH75.
Put another way; I don't care what kind of abuse you give a machine - there is no way it should ever fail like that. That is either a design failure or a manufacturing defect plain and simple.
Here's some pics of the defective/broken pin. I've contacted the dealer that I purchased the tractor from and they are sending me another pin for it. I'm just a little worried that this may be a bigger issue than just replacing the pin now. It looks to me like it may have actually bent the frame that holds the cylinder...maybe torqued/pushed it out a little (see pic 3). Not sure how I'd get this pulled back in. I'm also concerned that it may have damaged the inside of the pin sleeve...perhaps scuffed it which could lead to additional wear later?
Feeling pretty sick about this right now...
2022 Horizon Trailer (A55973)
2022 Horizon...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
Kubota U55-4 (A57148)
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
