Replcement Engine for Troy-Built Horse
/ Replcement Engine for Troy-Built Horse #41
If you are thinking of a run to HF, before you go, run a Google search on "Harbor Freight 20% coupon" and you will find online links to ones you can print and bring with you. They always have one running, as far as I can tell.
20% coupons are always posted at the Slick Deals site above in post #37
/ Replcement Engine for Troy-Built Horse #42
Just a note on the Chonda clones. I have adapted a number of these and they have all worked well, especially on the newer Troy-bilts with the high / low pulley. For the older Horse 1 and 2 (single range), they are a bit under powered. I am however going to adapt a 9hp on the next conversion, because the 6.5 just work too hard when tilling as deep as they can go in really nice soil. I think the 9 will be a better conversion, but shaft size is larger and the pulley needs modification.
/ Replcement Engine for Troy-Built Horse #43
i will say i was disappointed that the motor is made in Taiwan . i actually called Honda about it just to confirm i didn't get ripped off . they told me that most of the smaller motors are now assembled in Tawain . .
I think they are made in Tailand not Taiwan.
/ Replcement Engine for Troy-Built Horse #44
/ Replcement Engine for Troy-Built Horse #45
You are right it is Thailand . My mistake .
/ Replcement Engine for Troy-Built Horse #46
I have compared the "Thai" hondas,and a clone that I have side by side. The clone has smoother castings...go figure.
/ Replcement Engine for Troy-Built Horse #47
when you change to the HF engine, the center crank bolt goes from a 3/8 to a 5/16: does that cause any trouble with the reversing disk?? as the bolt just goes thru it, an the smaller bolt leaves a little slack?
heehaw
/ Replcement Engine for Troy-Built Horse #48
I don't understand how things work if you leave the throttle cable off?
Do you run a sepapate cable or just set the speed at the engine and go that way?
/ Replcement Engine for Troy-Built Horse #49
The throttle is just a simple lever in the front of the motor . I run my full bore when tilling and throttle it back half way for a cool down . You could reattach a cable to control the throttle if you wanted I saw no reason to do this .
/ Replcement Engine for Troy-Built Horse #50
I have read many posts stating "it just bolted right up", others say they needed to just replace the shaft bolt, and others just the mounting bolts.
Could someone please clarify what bolts are needed for the $99 Greyhound 6.5 HP engine from Harbor Freight to attach to a Troy-Bilt Horse tiller that had a Techumseh HH60 6.5 HP engine?
Thanks
/ Replcement Engine for Troy-Built Horse #51
Thanks
I know your looking for the Harbor Freight motor , but on the Honda you just have to replace the shaft bolt . I picked one up at Tractor Supply for $0.10 . I believe the HF motors are identical . I also switch out a HH60 motor off a Horse with low/high and reverse . It is a very simple swap .
/ Replcement Engine for Troy-Built Horse #52
Thanks
"you'll need to use metric bolts, 8mmX1.25 hex head, as close to the
length of the original SAE bolts that came with the tiller. The bolt for the
pulley is a 5/16-24 hex head. "
I got this off the yahoo troybilt group, loads of good info there. Check all your bolt holes by threading in a bolt by hand before you grab a wrench. Youi need to make sure the bolts thread in easily and to the correct depth, hate to see you crack a new block.
/ Replcement Engine for Troy-Built Horse #53
/ Replcement Engine for Troy-Built Horse #54
Got the HF Greyhound 6.5 engine a few days ago. With coupon it cost me only $92 dollars delivered. I learned that I needed the 4 - 8.0 X 1.25mm X 25mm bolts for the engine mount, and a 5/16 X 24 X 1-1/2" shaft bolt. I don't think I need any change in the shaft spacers but I won't know that for sure till I use it. (If anyone else is doing this I highly recommend you measure the distance from the inside of the cast pulley housing to the face of the pulley BEFORE removing the engine.) I discovered the old engine mounting bolts are 5/16 X 24 but only 1" long so you can't use one of those for the new shaft, it's too short.
I was pretty impressed with this engine. I filled it with oil and gas, set the choke on, and throttle to half. It started right up on the first pull, and that really surprised me. The manual says the critical breaking period is the first 3 hours, no full throttle and no heavy loads so I'm going to just idle the thing for 3 hours before I put it to work.
The next step is to remove the low oil cutout device and move the engine kill switch up onto the handle. I might even attempt to attach the old throttle control cable as well. I'll let you know how that works out.
/ Replcement Engine for Troy-Built Horse #55
Not sure but idling might not be the best idea for break-in.
If it were a car i would vary the engine speed during the break-in
without a concentration at any one RPM.
/ Replcement Engine for Troy-Built Horse #56
For break-in, ALL gasoline engines need a varying load with a varying speed........You are not only wearing a bit of the edges off of the machined parts but beding in various bearing surfaces.......DO NOT JUST IDLE..................Good luck.........Dennis
/ Replcement Engine for Troy-Built Horse #57
I notice that the Greyhound 6.5 HP is on sale for $100 at the stores. I believe you can still use the 20% off coupon on engines.
It looks like HF is phasing out the Greyhound series and bringing in a new engine series called Predator. I think the Predators are a clone of a newer engine, maybe more CARB compliant??
/ Replcement Engine for Troy-Built Horse #58
Thanks for the break-in tips, I'll do that.
I got my throttle hooked up with little trouble. Looking down from the top there is a throttle arm with three small holes in it between the Air Cleaner, Gas Tank, and Exhaust Cover. The end of the original throttle cable has a small offset in the end that fits into one of the smaller holes perfectly. All had to do was drill two holes in the exhaust cover and bolt in two tiny wire straps about 3" apart with 8/32 screws, nuts, and lock washers to hold the cable securely. This leaves the cable a little long but I just draped it over to the other side of the handle bars and tie-wrapped it down. Only other thing I had to do was to loosen the washer nut holding the throttle arm and put a drop of oil on it. The thing was tightened for manual use but now that the cable is connected it can be adjust to turn freely because the throttle cable has plenty of it's own resistance.
I took care of the engine kill switch and the low oil switch with one simple solution. Both the oil and kill switch just ground out the ignition, so all I needed to do was cut the low oil wire, splice a piece of wire long enough to reach the handle bar, and install a switch with one side grounded to the metal handle. Now the engine can be killed from the original switch or the handle switch.
Everything is working great!
/ Replcement Engine for Troy-Built Horse #59
Bummer---maybe stock up on them while you can.
THANKS D40 - think you could post a photo of your throttle connection?
Tracks for Takeuchi TB260 Excavator (A61166)
Tracks for...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
New/Unused Landhonor Gas Powered Water Pump (A61166)
New/Unused...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
TAKEUCHI TS50R SKID STEER (A62129)
TAKEUCHI TS50R...
