Dual Axle trailers
/ Dual Axle trailers #1
Grand_Pooba
Wyoming County, NY
Bobcat CT230 & John Deere X324
Typically do dual axle trailers have brakes on both axles? I'm replacing the axles on a 16' landscape trailer. The existing axles didn't have brakes. I plan on getting 2 3500lb axles but not sure if they both need brakes.
Thanks
/ Dual Axle trailers #2
Most of the trailers I'm looking at have brakes on one axle.
/ Dual Axle trailers #3
Typically, trailers under 10,000 lbs. GVW will have brakes on just 1 axle, 10,000 lbs. and up will have brakes on both axles. Of course, there are always exceptions.
/ Dual Axle trailers #4
Two braked axles are better than one. But generally only one is required and installed by default on 7k trailers.
Aaron Z
/ Dual Axle trailers #5
Thanks
State laws vary.. NY does require brakes on all axles with a registration weight over 3,000lbs
/ Dual Axle trailers #6
brakes on all axles can cause some control problems in snow or ice for some drivers, if all tires stop turning gravity will take over and the trailer may want to slide (to the down hill position or try to pass the vehicle if there is enough forward momentam) if you are in hills .
/ Dual Axle trailers #9
My Kaufman dual-axle 7k 16' trailer came standard with brakes on one (1) axle.
/ Dual Axle trailers #12
Technically not correct. According to NYSDMV law form MV529C trailer requirements if the trailer is over 1000 lb. unladen or over 3000 lb. gross weight it must have brakes. It does not specify brakes must be on all axles. If it did there would be a lot of illegal trailers in NY.
My own trailer does have brakes on both axles but typically they come with brakes on one. I bought mine in PA but asked that it have brakes on both when I ordered it.
When I called NY DMV they would only confirm the above and not say brakes were required on both and referred me to the trailer requirement form I mentioned.
/ Dual Axle trailers #13
Brakes required on all axles here. Sure helps a lot in a panic stop.
/ Dual Axle trailers #14
Around here most 7K trailers only have brakes on the rear axle. I have 2 currently and both only have brakes on one axle. As mentioned before once of 10K they put them on all axles.
Chris
/ Dual Axle trailers #16
My 16' 7000 lb trailer has brakes on both axles. Having made two panic stops in the 4 years I have owned the trailer I am glad that I went with this option instead of just one axle.
/ Dual Axle trailers #17
Ditto- personally I would not own a tandem trailer with brakes on only one axle.
I descend some pretty steep roads in the NC mountains, so beside the peace of mind, the single axle brake setup overheats much sooner too.....
/ Dual Axle trailers #18
Thanks
I wouldn't have a tandem axle trailer with brakes on only one axle.
I haven't shopped for one in a long time, but I doubt they are still made and may be illegal in some places.
Oh Ohh, this may start a flame war (-:
I believe (as in; it is largely faith based, so it guides my actions) that a properly loaded tandem axle trailer;
a) Has its center of gravity ahead of the front axle
b) Has slightly more of its load on the rear axle than the front
If these seem inconsistent with each other, consider that ball height is a factor in b above.
If you have ever locked up the brakes on a (properly loaded) 4 brake trailer you may have noticed that the front lock up sooner/easier than the rear.
Brakes on ONLY the front axle probably mean that you get less than 40% of the braking power you could/should get.
Lowering the ball to get more load on the braked axle... ??? is likely to lead to stability problems, e.g. a tendency to sway.
OK, so it is faith (& SOME experience) based.
One more thought; 2 axle brakes that allow you to stop 4ft short of a collision are a lot cheaper than 1 axle brakes that only allow you to stop 2ft INTO a collision.
IOW, this is NOT a good place to scrape a few bux of perceived "savings".
/ Dual Axle trailers #19
If it was mine I would put brakes on both axles. I would also look at putting on heavier axles like 5000 pound ones. They should not be that much more in price but may have a six hole rim instead of a five. Just my two cents.
/ Dual Axle trailers #20
here's the commercial vehicle information from the state of maine. if bored read section 7 - it's about brakes.
http://www.maine.gov/sos/bmv/commercial/CVPamphlet.pdf
basically is says brakes on all wheels of all axles of trailers. exceptions that would apply are trailers under 3000lb.
there is one other vague exception that might allow single braked axle trailers: any vehicle meeting the motor carrier safety regulations, accepted by the us dot does not need brakes on all axles. basically i take this to mean that the manufacturer may have aproval for certain models to be acceptable with only brakes on one axle, but you'd have to figure out exactly what specific ones this applies to.
though, even commercially built trailers i have seen always have both axles braked, but i can't say i've closely inspected every one out there.
2019 INTERNATIONAL LT625 DAY CAB (A60736)
2019 INTERNATIONAL...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
7021 (A55851)
7021 (A55851)
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
