Dual Axle trailers
/ Dual Axle trailers #1
Grand_Pooba
Wyoming County, NY
Bobcat CT230 & John Deere X324
Typically do dual axle trailers have brakes on both axles? I'm replacing the axles on a 16' landscape trailer. The existing axles didn't have brakes. I plan on getting 2 3500lb axles but not sure if they both need brakes.
Thanks
/ Dual Axle trailers #2
Most of the trailers I'm looking at have brakes on one axle.
/ Dual Axle trailers #3
Typically, trailers under 10,000 lbs. GVW will have brakes on just 1 axle, 10,000 lbs. and up will have brakes on both axles. Of course, there are always exceptions.
/ Dual Axle trailers #4
Two braked axles are better than one. But generally only one is required and installed by default on 7k trailers.
Aaron Z
/ Dual Axle trailers #5
Thanks
State laws vary.. NY does require brakes on all axles with a registration weight over 3,000lbs
/ Dual Axle trailers #6
brakes on all axles can cause some control problems in snow or ice for some drivers, if all tires stop turning gravity will take over and the trailer may want to slide (to the down hill position or try to pass the vehicle if there is enough forward momentam) if you are in hills .
/ Dual Axle trailers #9
My Kaufman dual-axle 7k 16' trailer came standard with brakes on one (1) axle.
Chance Quick Attach 60" Mulching Head (A60463)
Chance Quick...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
2014 HEIL CRUDE TRAILER (A60736)
2014 HEIL CRUDE...
