RTV1140 Receiver Hitch
/ RTV1140 Receiver Hitch #21
I think they started when they started the 500's and they just carried it over into the other lines. The baby had a 2" from the get go. :laughing:
I believe it's part of Kubota's listening to needed standard updates such as zerks in U joints, etc. and is part of the updates for the new 2011 version...at least that is true for the 1140.
I'm not sure when the 500's were introduced, but my RTV 900 purchased new in the fall of 2009 has the 2" receiver.
Steve
/ RTV1140 Receiver Hitch #22
Sounds like they listened but didnt research to get the standard right. The old hitches fit like a glove with the class 1 insert. I dont know why anyone would need a 2" receiver on them anyway. A 1.25" solid bar will pull more than the RTV can put out and hold at least 300 lbs of tongue weight even if not rated for that much without bending. I think I paid less than $20 for it and Harbor Freight would have cost me about $10 or less. I used one to pull a 17 foot boat many years ago and it worked fine. I suppose there is some convenience to being able to swap from truck to RTV but heck for the price, just buy the RTV its own hitch insert and leave it in. Class III receiver hitch is way overkill for these machines especially given the way they are attached, that is assuming that they still attach them the same way since I havent looked at new models.
/ RTV1140 Receiver Hitch #23
The big deal about having a 2" hitch is that standard accessories will fit without a bunch of adapters. Things like spreaders, winch mounts,......
/ RTV1140 Receiver Hitch #24
I have numerous bumper pull devices and need to pull each with the RTV as well as pickup.
pin hitch... water wagons, cotton trailer
1 7/8 ball for small trailer
2" ball for 18 ft flatbed and boat trailer
With the 2 inch square hitch, I'm able to use what I already have rather than purchasing three new inserts!:D
I'm glad they listened. Those who need it can purchase a reducer.
/ RTV1140 Receiver Hitch #25
The 1 1/4 is not bad , around here I can find plenty cheap at garage sales.
Kolpin does make a 2 inch receiver that bolts in place of the rear tranny filter guard and you can use it on the early RTV 900 and 1100 units that have just the 1 1/4 mounts.
UTV 2" Rear Receiver Hitch - Kubota RTV
Put a stinger in the front receiver on the 1100 with a clevis for pulling things and works real good.
David Kb7uns
/ RTV1140 Receiver Hitch #26
You may not realize it but a 1 7/8" ball will work for both the 1 7/8" and on a 2" trailer hitch for moving them around or pulling them around the farm. I wouldnt recommend to use them out on the road, but they wont come off and by using the smaller ball you dont have to swap out each time you go to a smaller hitch.
/ RTV1140 Receiver Hitch #27
HECK with the way my hitch on the RTV is attached, I could have it removed and a 2" receiver hitch welded on in less than 30 minutes. There is a small tack weld on the bottom and a small plate on top. In 30 seconds with my Victor OA torch, I can have that severed and ready to slap on the 2" receiver using the same bracket. Less than 1 welding rod and 3 minutes later I could have a 2" receiver if I needed one. Maybe next trip to Harbor Freight I can pick up a receiver although at the moment the one on it does what I need. What with my Troybuilt lawnmower with hitch, ZTR mower with hitch, golf cart with hitch, two tractors and a 4 WD pickup PLUS the RTV, I am not in a bind for pulling equipment. Also my brother in law who lives about 400 feet from me has about the same amount of equipment should I find that for some reason all of mine wont work due to alien invaders sucking all the juice out like they do in the movies.
/ RTV1140 Receiver Hitch #29
Watch dumping the bed with the hitch in. Put a big dent in the wife's new shinny tail gate when dumping rocks. 1st one always hurts the worst.
/ RTV1140 Receiver Hitch #30
Hmm.....never thought about the hitch hitting tail gate during dump..... haven't looked, but can see how it might happen...will have to check and see if there is some reminder warning/sticker I can place on it to hopefully avoid the problem....I typically leave the hitch connected because I typically am pulling a small trailer which also is a manual dump.... Thanks for the tip:thumbsup:
Traskblacktail, I plead ignorance...what is a high-lead??
/ RTV1140 Receiver Hitch #31
Traskblacktail said:
Yesser, me and my wannabe a logger jargon, be glad to tell you;
Mostly used by professional loggers; it is a very tall steel tower, they use them to pull massive fir trees up the steepest hills and accross deep canyons here in Oregon. I sight to see.
I am just a mini rancher, so I use a small version of it to drag logs on my place (mostly big leaf maple) onto a deck. I use a tree for the tower. It keeps my equipment off the slopes and out of the brush hellholes.
It is a 100 foot 3/8" cable with a swivel at the choker end. I run the cable through a snatch block/pulley and attach it to a nearby standing tree with a 5/16" chain. I attach it as high as I can on the tree (8 feet).
Sometimes, I pull it straight but usually, I pull the cable at a 30 or 45 degree offset from the logs for the best pulling power. :confused2:
I like it because it lifts the leading edge of the logs just high enough to clear the soil and stumps. When I use my 98 K1500 in 4X4 low range, it pulls 20"X 40 foot logs with very little effort.
The steel hook on the RTV front receiver places the center or gravity (CG) perfectly. It is a wicked looking beefy hook, I got it for 15 bucks (I can PM the catalog company).
I will be setting up the high lead next week, I can take some picks if anyone wants them. It really is a "kick in the behind" to see the logs moving so easily; the RTV just goes back and fourth on the trail. I am a broken down old vet and I need every trick I can find.
/ RTV1140 Receiver Hitch #32
If you want to talk High Lead how about flying Cats and these do not have tails and fur.
YouTube - Flying Cats
You have to watch this and Cats do fly in the air.
David Kb7uns
/ RTV1140 Receiver Hitch #33
traskblacktail, good explanation, would enjoy seeing photos if you get some...don't know that I'd have a use for such a device, but you never know:D
By the way...I checked the dump bed of the 1140RTV... it simply cannot hit the trailer hitch plus stinger/insert.... only if you had one that raised the ball more than a foot...and that would be dangerous...pulling way over the axle/center of gravity.
/ RTV1140 Receiver Hitch #34
Guys, getting ready to pull the trigger on a 2014 RTV 1140 CPX and the dealer is telling me that the 2" UTV Receiver Cradle Winch Mount from Mile Marker (2" Receiver Winch Mount with Cradle - Fits 4500lb & Larger Mile Marker Winches) will slide nicely into the front or rear 2" receiver that appears to come standard on this machine.
I've already agreed to have them install the quick release wiring harnesses for the front and rear, so is this guy blowing smoke that this will easily slide into the receivers?
I'm looking at the Mile Marker 3,500 lob Tough Series Waterproof UTV Winch with Synthetic Rope....he got it for me for $335.....
/ RTV1140 Receiver Hitch #35
Well, some assembly may be required. At the web site it says...
Note: 4500 lb winch requires drilling to mount
also, hard for me to tell if the mount will fit into REAR 2 inch receiver....on all my REAR inserts I had to cut an inch or so off and drill holes appropriately to insert a hitch pin. Yes, a 2 inch square will fit into the provided receiver. Front does not bottom out...rear one dead ends into the rear axle.
2025 LandHonor MGB-72-44W Rotating Grapple Skid Steer Attachment (A61572)
2025 LandHonor...
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
2011 Ford Expedition SUV (A61574)
2011 Ford...
2004 CATERPILLAR 242 SKID STEER (A64279)
2004 CATERPILLAR...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
