Root Grapple
/ Root Grapple #1
Dunmovin
Leaning towards a Kioti DK45SE with a 401 FEL. As we have a bush block and anticipate a lot of clearing trying to get a decent Root Grapple attachment. Have looked at Horst Welding version for about C$2300 with two independent hydraulic grapple arms and the Unlimited Fabrications in NC which is only $1300 with a single grapple and seems overall a little lighter construction.
Would appreciate any advice or experience people have with either or any alternatives that might be avaiable.
Txs
Dunmovin
/ Root Grapple #2
/ Root Grapple #3
Cattywampus, how did you plumb in your grapple, to the rear hydraulics? And to the first poster (Dunmovin), try CID in NC, the are an approved vendor for Kioti w/ their grapples and buckets. CIDattachments.com.
/ Root Grapple #4
I got a 48" Gator grapple rake a year ago and used it a lot for piling brush, uprooting trees and moving logs in the woods. Although I managed to put a slight twist in the grapple, I don't blame the manufacturer for that.
I would like to know: what is it about North Carolina that so many of these things are made there?
BOB
/ Root Grapple #5
Yes, I when cheap for the time being and used the rear remotes. It's not really that difficult to use since the control lever is beside the FEL control lever. CID is a good company too. I have their QA roll top snowplow. Here a review of the plow:
http://www.tractorbynet.com/forums/attachments/196104-cid-96-x-treme-roll.html
I used the front hydraulics for both the grapple and snowplow.
I purchased both the grapple and snowplow through Jeb Supply Co. See the review for Jeb contract information. Believe it or not I found that Jim @ Jeb Supply Co can get a better price then buying direct. He just sell so much equipment he gets a better price.
Children like presents under the tree, I prefer the ones that come by freight! :thumbsup:
/ Root Grapple #6
I also have the 60" Gator grapple made by Markham. The price was BY FAR the lowest I could find anywhere. Even though it is considered "light-duty", don't let that fool you. It is plenty enough heavy-duty for my DK45se and I don't believe you'd want any more weight on your FEL than this one.
It only has one light-duty cylinder for closing the jaws. At first I was concerned about that, but in reality, the top jaw is just for holding objects and it is plenty for that. I have amazed myself and several others as to what all this grapple can do. I like it and HIGHLY recommend it. Plus you'll enjoy working with the Markham folks.
/ Root Grapple
Steve
Your right on the price - they are by far theta cheapest and the products look good. Only downside is that they don't ship to Canada which surprises me when you consider the costs that people are paying for similar equipment here but it's easy enough to arrange and there's no duty.
Many thanks for advice and recommendation (going with the 60" grapple and a Stump Grapple)
Dunmovin
/ Root Grapple #8
Steve
Dunmovin
Not shipping to Canada must be a new (and unfortunate) thing. Last spring, while they were still making the transition from Markham to Gator and Melissa was on the phone, I had not trouble at all getting mine delivered to PEI.
BOB
/ Root Grapple #9
The posting about shipping reminded me about another issue I had with the Markham/Gator grapple. When I removed the shipping label, it tore off the paint underneath, so I had to dig out the rattle can of black and touch it up! I couldn't decide whether it was inadequate surface prep or really super-duper label glue that was the problem. Of course, I've knocked a lot of the paint off in the woods, since, so its a pretty picky comment!
BOB
/ Root Grapple #10
I have a 48 inch Millonzi (no longer made) that is very similar to the Gator/exMarkham. Might even be a lighter build. I beat the crap out of it and it still keeps going. A little more snaggletoothed then when I got it but it works just fine. My single favorite and most important implement in clearing land. It is mounted 75% of the time.
Main point in maintaining a grapple is to use it to dig and lift but not to twist it by putting asymmetric loads on it. You cannot hurt the grapple by lifting or pushing straight with a DK40se.
/ Root Grapple #11
IslandTractor's pictures say it all! That is pretty typical of what a grapple can do. Only thing he doesn't show is it's digging ability (like digging out that stump) Try doing all those things with anything else. Since following his advice several year ago, I could not be more happy. One note, if you are concerned about the "light duty" label, you can (or at least could when Markham was in business) get the same grapple but with 1/2 steel. I also had them add some more spacers to make the gaps smaller between tines. This beefs it up a little without adding too much weight. My tractor is 70 horse so I wanted al little more strength. Oh, get a 48" not anything wider. I think that is important.
/ Root Grapple #12
Steve
Dunmovin
just curious as why you think you need both? I think the stump grapple would be good if you plan to transplant lots of plants or small trees, and for digging holes for planting, but if you are just using it for clearing and ripping up trees and undergrowth, I think the root grapple will work fine for that. You could save some money and not have to switch out implements. I would also say the 48" is better for digging, and will carry debris just as good as the 60" and for less money. Compare it to a shovel, when you dig, you use a standard shovel not a wide snow shovel. The narrow shovel penetrates better and is more precise, and allows the limited power of a tractor (as compared to a skid steer) to focus all the pressure on a smaller area. Also having only one hydraulic thumb on top simplifies things but is plenty to hold things in place, which is all it is used for. A wider grapple, while it may be great for scooping up and carrying debris, is not as good for digging as a narrower one, and that function is what I spend most of my time doing with a grapple. And for carryin debris, it works just fine. Just my 2 cents worth.
/ Root Grapple #13
Even though I have the 60", I agree on the 48" being as good or better in some applications. In my case, the only times I'm glad I have the 60" is when I'm clearing areas with lots of vines and briar thickets. That extra width makes for a wider path and less scratching and tangling in the tractor. You'll be happy with either. Whoever said it was their favorite implement, I totally agree. They are also great for tending a burning brush pile. You can keep the pile nicely stacked without accidentally pushing dirt onto your fire like often happens while using a bucket.
/ Root Grapple #14
I would also advise if you use the grapple like I do (wading into thickets, pushing up trees, etc) to consider building a better grill guard for the front of your tractor. I have the standard Kubota guard but it offers no protection for that stray limp that will want to find a pathway to the grill area. I damaged the front of my tractor several times, bent the hood, damaged the headlights, and bent the grill assembly, before I finally made a guard from bar grating and angle iron. The problem is that grapples are so much fun to use that I get carried away pushing stuff down!
/ Root Grapple
The idea of a 48" does make a lot of sense so appreciate everyones advice. Quuick question - has anyone have experience with the Marshall Tree Saw (amazing piece of equipment for clearing smaller trees). Also to clear bush what's the best option flail, rotary or bush hog?
Thanks
Dunmovin
/ Root Grapple #16
Specifically for clearing brush I would choose a brush hog (= bush hog, slasher, rotary). That is the lowest maintenance option. A flail will also work so long as it is a rough cut and not set up for finish mowing. The flail will leave a nicer cut but for backing into thick brush I'd rather have a brush hog.
Don't even think of using a finish mower for this task if that is what you meant by rotary cutter (in general, even though they are technically rotary cutters, people assume rotary = brush hog unless you specify finish rotary cutter)
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Club Car Emergency Cart (A64557)
Club Car Emergency...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
