model terminolgy 50 hp class
/ model terminolgy 50 hp class #1
hrcarver
Gold Member
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
What does all the letters mean after kubotas model numbers?
IE: m/mx/su/suh/sud
Think I want a something along the lines of a 5640su (or sud?)
/ model terminolgy 50 hp class #2
Prices are 2009
M5640SU 2WD TRACTOR 3748 $ 19,382.00 with 2 Post Foldable ROPS
M5640SUD 4WD TRACTOR 3858 $ 23,696.00 with 2-Post Foldable ROPS
/ model terminolgy 50 hp class #3
IE: m/mx/su/suh/sud
as long as you dond see
dud
after the numbers, your probibly ok..sorry, i couldnt resist.
Prices are 2009
Thank you, that answers my biggest question.
What is the difference between M and M/SU? M is supposed to be nicer I think, but what is nicer?
/ model terminolgy 50 hp class #5
The M-SU model is the economy model M with fewer options. I believe it stands for Special Utility. mdelmarcelle and Native Son both have the M7040SU, so they can tell you more.
The MX is smaller than the M and the biggest you can get is the MX5100.
http://www.tractorbynet.com/forums/...73485-m7040-variations-getting-ready-buy.html
This was posted by another member, but I don't remember who:
DT-1 = Dual Traction 4wd, ROPS model with IC/Shuttle Transmission (M7580/M9580)
DTL = Dual Traction 4wd, Low Profile (for orchards)
DTM = Dual Traction 4wd, MUDDER (for specialty, row crop and vegetable)
DTN = Dual Traction 4wd, Narrow (for vineyard/orchard tractor)
DTN-B = Dual Traction 4wd, Narrow wheel tread with Bi-Speed Turn
F = Two Wheel Drive
F-1 = (-1) = Larger two pump hydraulic system
FC = Two Wheel Drive Cab Model
F-CS = Two wheel drive with Creep Speed (Ag. tires or as Turf Special)
HC = High Clearance (2wd M7950 only)
HD = Hydraulic Shuttle, 4wd
HDC = Hydraulic Shuttle, 4wd, Cab
HDCCS = Hydraulic Shuttle, 4wd, Cab, Creep Speed
L = Low Profile
ML = Mechanical shuttle, Low profile
MDT = Mechanical shuttle, Dual traction 4wd
MDTL = Mechanical shuttle, Dual traction 4wd, Low profile
MF = Mechanical shuttle, Two wheel drive
OC = Orchard model
S = Synchro-Shuttle, 2wd
SD = Synchro-shuttle, 4wd
SCS = Synchro-Shuttle, 2wd, Creep Speed
SDN-B = Synchro-Shuttle, 4wd, Narrow with Bi-Speed Turn
SDNBC = Synchro-Shuttle, 4wd, Narrow with Bi-Speed turn, Cab model
SDNBF = Synchro-Shuttle, 4wd Narrow with Bi-Speed turn, Foldable mid-mounted ROPS
SU = Special Utility, 2wd
SU-R = Special Utility 2wd, Rigid ROPS
SU-F = Special Utility 2wd, Foldable ROPS SU-TF = Special Utility 2wd, Turf Special
SUD-R = Special Utility, 4wd, Rigid ROPS
SUD-F = Special Utility, 4wd, Foldable ROPS
SUMDT = Special Utility, Mechanical Shuttle, 4wd
SUDT = Special Utility, 4wd
W = Wide Row
H = 2WD, ROPS (Note: All H-Models are Std. Swing Shift 16F X 16R speeds)
HC = 2WD, CAB
HD = Swing Shift, 4WD, ROPS
HDC = Swing Shift, 4WD, CAB
DS = Dual speed, ROPS (Note: All Dual Speed models are 32F X 32R speeds)
DSC = Dual speed, CAB
SDSCC = Dual speed, CAB, cold weather w/high amp alternator and creep speed and second remote valve
SDSC = Swing Shift Dual Speed, CAB DSDF = Dual Speed, 4WD, ROPS
SDSL = Dual Speed, 4WD, Low Profile
M-Series Notes:
Suffix "1 models are the second generation "Wide Cab tractors. Cab is 5.7 inches wider than first models.
Suffix "2 models are factory equipped with 540 / 1000 RPM PTO kits. M95S and M105S:
The "S represents the model/tractor class in general is no specific meaning, however it can be applied to "Swing Shift as the base transmission on all "S models.
/ model terminolgy 50 hp class #6
Wait a Minute! That was me! And I thought we were good buds.
Truth be told: I stole it from elsewhere myself.
/ model terminolgy 50 hp class #7
Sorry bout that, at my age, I wake up in a new world every day.:laughing:
Thanks to both of you, that is certainly a good explanation for everything.
/ model terminolgy 50 hp class #9
You are more than welcome, GW and I have BX, L and M models and I highly recommend anything in the Kubota lineup. The SU designations in all of the models provide very good values.
/ model terminolgy 50 hp class #10
I'll add an entry to the previous excellent list.....
for example, I have a 5030 HSTC
it's a 50ish horsepower model
it's a 30 model series... current version is designated 40 series
it's an HST transmission
and it has a Cab...thus the C at the end.
2005 John Deere 7320 (A60462)
2005 John Deere...
Case Titan 3530 (A63688)
Case Titan 3530...
Wolverine 72†Skid Steer Screening Bucket (A64047)
Wolverine 72â€...
2017 International HX620 Quint Dump (A62613)
2017 International...
2018 WESTERN STAR  4900 TRI-AXLE HYDROVAC (A63569)
2018 WESTERN STAR...
KBH Tender (A63688)
KBH Tender (A63688)
