model terminolgy 50 hp class
/ model terminolgy 50 hp class #1
hrcarver
Gold Member
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
What does all the letters mean after kubotas model numbers?
IE: m/mx/su/suh/sud
Think I want a something along the lines of a 5640su (or sud?)
/ model terminolgy 50 hp class #2
Prices are 2009
M5640SU 2WD TRACTOR 3748 $ 19,382.00 with 2 Post Foldable ROPS
M5640SUD 4WD TRACTOR 3858 $ 23,696.00 with 2-Post Foldable ROPS
/ model terminolgy 50 hp class #3
IE: m/mx/su/suh/sud
as long as you dond see
dud
after the numbers, your probibly ok..sorry, i couldnt resist.
Prices are 2009
Thank you, that answers my biggest question.
What is the difference between M and M/SU? M is supposed to be nicer I think, but what is nicer?
/ model terminolgy 50 hp class #5
The M-SU model is the economy model M with fewer options. I believe it stands for Special Utility. mdelmarcelle and Native Son both have the M7040SU, so they can tell you more.
The MX is smaller than the M and the biggest you can get is the MX5100.
http://www.tractorbynet.com/forums/...73485-m7040-variations-getting-ready-buy.html
This was posted by another member, but I don't remember who:
DT-1 = Dual Traction 4wd, ROPS model with IC/Shuttle Transmission (M7580/M9580)
DTL = Dual Traction 4wd, Low Profile (for orchards)
DTM = Dual Traction 4wd, MUDDER (for specialty, row crop and vegetable)
DTN = Dual Traction 4wd, Narrow (for vineyard/orchard tractor)
DTN-B = Dual Traction 4wd, Narrow wheel tread with Bi-Speed Turn
F = Two Wheel Drive
F-1 = (-1) = Larger two pump hydraulic system
FC = Two Wheel Drive Cab Model
F-CS = Two wheel drive with Creep Speed (Ag. tires or as Turf Special)
HC = High Clearance (2wd M7950 only)
HD = Hydraulic Shuttle, 4wd
HDC = Hydraulic Shuttle, 4wd, Cab
HDCCS = Hydraulic Shuttle, 4wd, Cab, Creep Speed
L = Low Profile
ML = Mechanical shuttle, Low profile
MDT = Mechanical shuttle, Dual traction 4wd
MDTL = Mechanical shuttle, Dual traction 4wd, Low profile
MF = Mechanical shuttle, Two wheel drive
OC = Orchard model
S = Synchro-Shuttle, 2wd
SD = Synchro-shuttle, 4wd
SCS = Synchro-Shuttle, 2wd, Creep Speed
SDN-B = Synchro-Shuttle, 4wd, Narrow with Bi-Speed Turn
SDNBC = Synchro-Shuttle, 4wd, Narrow with Bi-Speed turn, Cab model
SDNBF = Synchro-Shuttle, 4wd Narrow with Bi-Speed turn, Foldable mid-mounted ROPS
SU = Special Utility, 2wd
SU-R = Special Utility 2wd, Rigid ROPS
SU-F = Special Utility 2wd, Foldable ROPS SU-TF = Special Utility 2wd, Turf Special
SUD-R = Special Utility, 4wd, Rigid ROPS
SUD-F = Special Utility, 4wd, Foldable ROPS
SUMDT = Special Utility, Mechanical Shuttle, 4wd
SUDT = Special Utility, 4wd
W = Wide Row
H = 2WD, ROPS (Note: All H-Models are Std. Swing Shift 16F X 16R speeds)
HC = 2WD, CAB
HD = Swing Shift, 4WD, ROPS
HDC = Swing Shift, 4WD, CAB
DS = Dual speed, ROPS (Note: All Dual Speed models are 32F X 32R speeds)
DSC = Dual speed, CAB
SDSCC = Dual speed, CAB, cold weather w/high amp alternator and creep speed and second remote valve
SDSC = Swing Shift Dual Speed, CAB DSDF = Dual Speed, 4WD, ROPS
SDSL = Dual Speed, 4WD, Low Profile
M-Series Notes:
Suffix "1 models are the second generation "Wide Cab tractors. Cab is 5.7 inches wider than first models.
Suffix "2 models are factory equipped with 540 / 1000 RPM PTO kits. M95S and M105S:
The "S represents the model/tractor class in general is no specific meaning, however it can be applied to "Swing Shift as the base transmission on all "S models.
/ model terminolgy 50 hp class #6
Wait a Minute! That was me! And I thought we were good buds.
Truth be told: I stole it from elsewhere myself.
/ model terminolgy 50 hp class #7
Sorry bout that, at my age, I wake up in a new world every day.:laughing:
Thanks to both of you, that is certainly a good explanation for everything.
/ model terminolgy 50 hp class #9
You are more than welcome, GW and I have BX, L and M models and I highly recommend anything in the Kubota lineup. The SU designations in all of the models provide very good values.
/ model terminolgy 50 hp class #10
I'll add an entry to the previous excellent list.....
for example, I have a 5030 HSTC
it's a 50ish horsepower model
it's a 30 model series... current version is designated 40 series
it's an HST transmission
and it has a Cab...thus the C at the end.
2022 EZ-GO ELITE...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
FREIGHTLINER GRAIN TRUCK (A63291)
FREIGHTLINER GRAIN...
