A few 3215 questions
/ A few 3215 questions #1
Mahindra 3215 HST
New to the site and have a few questions about the 3215. Does anyone know the thread size for the ports of the hydraulic distribution block that feeds the loader valve? (#30 in the diagram) It is not a typical SAE (o-ring sealed) fitting. I need to replace the factory fittings and would like to convert them. Also is there a draft control option for the 3PH?
/ A few 3215 questions #2
I believe what your needing is a G 3/8 Plug size. for the T and N port. At least that's what I'm getting out of the service manual which talks about external hydraulic circuit.
T - Plug Tank
N - Plug return
P - Hydraulic Pressure external port
Hopes this helps.
/ A few 3215 questions #3
Sadly :( no.
T - Plug Tank
N - Plug return
Hopes this helps.
Thank you very much, that's what I need to know. 3/8" G is a BSPP fitting, of which I can get an adapter to NPT.
Small Cowboy Statue (A64557)
Small Cowboy...
2013 Buick Verano Sedan (A64557)
2013 Buick Verano...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
2020 John Deere 470G Hydraulic Excavator (A64553)
2020 John Deere...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
2016 International WorkStar 7500 T/A Dump Truck (A64556)
2016 International...
