Is this dangerous?
/ Is this dangerous? #41
That is a good point. If you are very intent towards your work, the ringing/vibrating phone could startle you causing bad things to happen.
The first time my first pager ever went off I was fishing. I was teasing a cutthroat trout by passing a rooster tail past his hideout under a bush along the bank. He was about to strike the lure when the pager went off. I had it set to vibrate. I about lost my pole, wet my pants, and fell in the creek all at the same time. I can only imagine what would have happened if I had my hands in a live panel at the time.
/ Is this dangerous? #42
Now THAT'S some serious focus!
/ Is this dangerous? #43
Just up the life insurance and post some pics , might as well have a list of guys ready to come play with the TYM when he does himself in ! ( that should make him pay attention !):laughing:
/ Is this dangerous? #44
Who was it here on TBN that had a signature something to the effect of "My worst fear is that my wife will sell all my tools for what I told her I paid for them"?
/ Is this dangerous? #46
...198 people in the US die every year by licking 9volt batteries to see if they are good...
I'd like to see the reference on that statistic.
/ Is this dangerous? #47
:thumbsup:
What do they call that? Tongue depressor? Hot licks? :laughing: And what...the other 2 people got thrown back by the kick of that massive 9-volt Eveready? Seriously you can't expect anyone to believe that without some sources.... Sounds like April 1st to me...
/ Is this dangerous? #48
I wonder if her husband knows she is watching another man work on the power line?:laughing:
I helped a guy install a ceiling fan. He was in a hurry and had more balls than brains and decided to wire it in hot. He must have yelped 2 dozen times in the next hour! Some time savings:confused2:
/ Is this dangerous? #49
I have yet to see a warning label on any of the 9 volt batteries I have licked. I am guessing that in 6 months and a couple billion in tax dollars, the USA will be a safer place. Maybe a better solution would be to make those cute licklicious batteries 10 volts.:laughing::laughing:
Hey Duffster, Ladia left his puter logged on again! :D I want to thank you all for your replies. I do love this man and I want to spend many more years together working on our place. I think he would like to at least, see his new shop completed...never mind our first grandchild being born this summer! You don't know this man but he is one of a kind...a good kind, mostly. He is known for cutting down neighbors trees with chainsaw in shorts and barefoot and welding in his sandals. Luckily, I am there to make sure he has a ride to the hospital Though, we haven't had to drive there...too fast, too often...:) Thanks again guys and gals? We women can wield a mean tool, too!:p Julie
/ Is this dangerous? #51
It can't happen with normal alkaline batteries because the battery internal resistance is too high. They can't discharge fast enough across skin resistance, even with a wet surface.
Rechargeables are more dangerous, but not because of shock. They have a much lower internal resistance so, when they are shorted, they can generate lots of heat. I've cut plastic with a couple of AA NiMH batteries and a piece of wire from a toaster. If you carry rechargeables in your pocket and accidently short them out, you can start a fire in your pants.
/ Is this dangerous? #52
You should still be in the corner.
Well guys in spite of trying I am still alive and in good health. All scars are healed and I have few "war stories" to tell. To add something to my defense I had the tombstone partially off. Only the feed from the transformer connected to two top terminals were hot. I only pulled the cable in and it will be connected only after I install the breaker box in the shop currently under construction. I dug the 70 ft of the trench 2 ft deep by hand meandering between wife's flowers. Some water seeped in it so the cable and the ground around was wet and slippery. So it was possible if I would slip while pulling the cable in I could hit the hot terminals. Well life is full of dangers.
My wife knows a thing or two about electric installation. In fact she wired our whole house few years back.
Somebody mentioned that the second shock is what will get you in. One time I just pricked my finger by sharp wire that had no voltage on it. While instinctively jerking my hand away I smashed it right into hot terminals.
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2015 Ford F-150...
2018 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2018 CATERPILLAR...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A61567)
2014 Jacobsen AR3...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
