Put my gooseneck to work!
/ Put my gooseneck to work! #21
seriously.... why does ANYONE go with bagged materials for that amount of material.
i mean bulk mulch has to be 1/4 the price and topsoil a tenth of the price...
My thoughts exactly!
/ Put my gooseneck to work! #23
Here is a load on my trailer and 08 Dodge truck, To me it seems to be sitting level or maybe just a tad low in the rear. The tractor is a Mahindra 5500 4x4 around 9000lbs plus, some might disagree so I will break it down, tractor weight is 6380 lbs dry weight, FEL is 1900lbs, and tires with water is 1060lbs as per the tire water chart, tool on 3-point maybe 90lbs. The 10 round bales are 4x5, what was advertised, I am not real sure of the correct weight of the bales, but i guessed around 800 to 1000lbs. Maybe someone on here can help with the weight on round bails, I would say i might have alot of tong weight, the trailer and truck handled it very well.
Thats a heck of a load you have also but its loaded more evenly. Makes all the difference in the world.
As for stumps I am estimating my weight off the logging we do. We cut 24" to 36" rounds all the time in 8' lengths and I know what they weigh. Mainly ash and walnut and they run each.
Chris
/ Put my gooseneck to work! #24
Hey Kajun, these guys should join LS to discuss the merits of bagged vs bulk huh? :laughing:
/ Put my gooseneck to work! #25
Depends where you are working. If you have to take it all though a gate bagged material is much easier.
2 weeks ago we bought 5 pallets of colored mulch. 2cu ft per bag at $1.69 per bag. 14 bags per yard. $23.66 per yard. The cheapest I could get bulk was $31 per yard. I needed 16 yards. It was very quick to put down with my forks and 3 helpers. Just pick up the pallet up and haul it to where needed. Throw of some bags and on to the next spot. Let the helpers spread it.
Chris
/ Put my gooseneck to work! #26
If you have a dump trailer, you can buy in bulk.
If you have a flat bed only, you buy in pallets.
If you have a baby tractor to run around in a yard without tearing it up, you can distribute bulk materials.
If you use a wheelbarrow to move materials, you can use sacks to reduce handling time.
I find that I use what I have to get a job done.
lol! another world war on bag vs mulch!
/ Put my gooseneck to work! #28
Wanna start a war? :) Does this load make Kajun a CDL candidate?
For sure must require DOT numbers at least, I think :confused2:
Duff will know.
18K trailer plus 8+K truck = 26K +, obvious commercial use.
I'm not saying I know the answer, just raising the question.
JB.
/ Put my gooseneck to work! #29
Duff will know.
JB.
I think he is good without it. ;)
/ Put my gooseneck to work! #30
Anyone else see what I'm (possibly) seeing? Does the stump photo look cropped? With no description? And, are trees that big in WV? Those stumps look MIGHTY big. Having said that, I've pulled out some big stumps with my excavator in Ohio, and almost tipped the hoe over when I went full extended with a big stump and my thumb on. BUT, that's fresh outta the ground, with all the dirt on......not much dirt on them stumps. Makes a big difference.
Despite that, I'd have to say the stumps are less (or maybe close to equal) than all the bagged material. Lotta density there....
I'm tempted to show my gooseneck load, but will stay outta this one.....:D
/ Put my gooseneck to work! #31
Like to see them myself.
/ Put my gooseneck to work! #33
Yeah come on and show it, so we can all critique it, tell you what your doing wrong, and what kind of equipment you should of bought :laughing:
JB
/ Put my gooseneck to work! #34
/ Put my gooseneck to work! #35
Here's a couple small loads on my F450....
/ Put my gooseneck to work! #37
Looks like a nice load and a good reason to own a goosneck easy to load and unload. I like the photo of the stumps and I would bet with the dirt they are real heavy.
Enjoy the photo
and yes I did it safely and legally.
/ Put my gooseneck to work! #38
Enjoy the photo
LOL, I did almost the exact same thing; even measured to make sure I was only 13' tall with a shed on my trailer but caught a freaking phone line that must have only been 11' off the street! :mad: Shhh, since it was hanging too low I didn't notice it when I ripped it down. Had to replace 2 pieces on the shed and that made me mad enough! I notice that that line is now at proper height. Someone must have called and complained...
INTERNATIONAL 720 - 6 BOTTOM PLOW (A63291)
INTERNATIONAL 720...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
