ROPS and Lights
/ ROPS and Lights #1
Scotty Dive
Ct
Yanmar 2020D
I ordered my ROPS for the 2020D. Of course I was thinking of installing lights...but I believe I remember hearing that the alternator can only support 15 amps. If I install three 55 watt lights - 2 facing front and one rear thats 15 amps right there. Has anyone used a LED spot light so as to not replace/upgrade the stock aleternator? Any other light solutions that work but do not drain the battery too?
/ ROPS and Lights #2
LED's would be the way I would go.. 2 will do the work of three regulars with half the drain and 2x the life.
/ ROPS and Lights #3
Use 2 lights on 360 degree swivels.
This gives you 2 sources of light that covers all the way around the tractor and reduces the amps needed to power them .
/ ROPS and Lights
I read a post and it probably is just cheaper to replace out the alternator to a 35 or 50 amp especially if its just plug and play????
I like the idea of the 360 swivel - but I am thinking these lights will be for snow plowing and using a back blade to snowplow - need a rear light to see what I am plowing and then using the bucket to move the larger piles of snow. Would be a pain to keep having to swivel the lights.
Anyone know if there is a way to check the amperage on a alternator without removing it and brining it somewhere? I am wondering if I truly have the 15 amp installed or maybe it was replaced at some point?
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
Unused 2021 NM 2HD-18 18in. Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2021 NM...
Baby Goat Decorative Statue (A66738)
Baby Goat...
porta potty (A68842)
2014 Dodge Grand Caravan Van (A66738)
2014 Dodge Grand...
2017 GMC Sierra 2500 HD 4x4 Crew Cab SpaceKap Service Truck (A66736)
2017 GMC Sierra...
