Borewelding
/ Borewelding #2
We use a different brand than that (ours are Boretech) but very similar. We've been using those machines for about 25 years now. Sure beats welding bores by hand, especially those bores that are too small or long, or in places that you can't see what you are doing. They can so some pretty good tricks to. When welding a bore with a keyway, you can set it up to weld up to the edge of the keyway, stop, index up, reverse direction, weld back around to the other edge, stop, index up, reverse, etc., until the bore is welded, having never stopped the arc. Or, you could weld that same bore skipping the keyway by starting and stopping the arc at the edge of the keyway, all automatically. We use ours almost exclusively in the vertical. It can be done horizontally too, but getting them to do a good job running the weld uphill, overhead, downhill (this is the biggest problem, little penetration) , and flat is a pretty good challenge. We do bunches of slack adjusters off of D10 and D11 dozers with the Bortech. We prep them in the lathe, weld the bores (about 6 5/8" diameter by about 20" deep) rough bore them in the lathe, and finish hone them to size. No imperfections allowed. We must average 4-6 of those a week.
Kim
/ Borewelding
When looking in to purchase a borewelder, the Boretech prices scared me off....the Bore Repair System setup was less expensive and pretty basis controls......the Boretech does do more extra functions but just couldn't see going the extra for my purposes....
If I was doing more and bigger work then the payback would have been doable as with any tool it needs to be used accordingly.....
The problem (as you know) is it's still labor intensitive and even though it welds by itself you still have to set it up correctly and baby-sit it......
For horizontal work I like to hold work next to the milling machine and use the milling table to hold the borewelder for positioning, that allows for fine tuning before welding......
/ Borewelding #4
They showed this being done on American Loggers. Pretty amazing process, thanks for sharing.
/ Borewelding #6
I missed that episode......I'll watch for it....thanx.....
I want to say it was in season one. It was on their Cat grader I think. Could be wrong though. It was only about 2 min spent showing it.
/ Borewelding #7
I am lucky enough to share a bandsaw sawmill with three other people. It works well for us. We have the owner who does not maintain it. Two people that always buy something to improve it. I take care of the maintenance and buy some parts. Between the four of us the mill still sits idle too much.
2013 KENWORTH T800 SLEEPER (A59906)
2013 KENWORTH T800...
STORAGE FEES (A59906)
1667 (A57192)
1667 (A57192)
2019 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A60736)
2019 INTERNATIONAL...
2020 Chevrolet Tahoe (A60352)
2020 Chevrolet...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
