318 mowing deck won't engage.
/ 318 mowing deck won't engage. #1
BrianCanz
I have a 1993 318 lawn tractor. The battery voltage light is on. When I attempt to engage the deck the light goes out, but the deck will not engage. Any ideas?
/ 318 mowing deck won't engage. #2
Welcome to TBN:D
The clutch is electric, so if the voltage is low it won't engage. You need to test the battery and genny for voltage-do yo have a meter?
Thanks Kenny. It seems to start up with no problem so I figured the battery was fine. The batt seems to stay fully charged after running for a while. Your saying just a light drop in voltage may make the difference?
Thanks again
/ 318 mowing deck won't engage. #4
Have you tested the voltage going into the pto clutch?
there should be an electrical connector you can undo and
use a voltmeter to check for voltage there. while you have
it unplugged, you can put a good 12v source on those wires
to see if the clutch engages (while the tractor is off obviously)
/ 318 mowing deck won't engage. #5
Sounds like a wire thats shorting out an causing a drain.chase wire an youll find something going to ground.
Army Grunt
/ 318 mowing deck won't engage. #6
I has a similar issue with my 332 a few years ago. In my case it was the connector leading to the PTO clutch.
/ 318 mowing deck won't engage. #7
It may be a short but then you'd find a blown fuse if there is one in the circuit.
Get a multi-meter and check zero resistance from the PTO clutch coil winding connector back to the engage switch source looking for a broken wire or a dirty connector. Also, unplug the PTO connector to the clutch and ohm out the winding to see if its open. It should read very low ohms.
If all is good, switch the meter to voltage and meter for 12 volts from switch to the PTO connector remembering the "close" all interlocks, ie; seat switch, etc.
/ 318 mowing deck won't engage. #8
If it has voltage and does not engage, it may need adjusting. There are three nuts that adjust the clearance of the clutch when not engaged, if it is too much the magnet won't draw it in. Set the clearance to 0.018", there is three inspection slots to do this. These clutches are reliable as can be, but if that clearance is out of spec it won't engage. It is one of the most common problems with those units.
Wayne
/ 318 mowing deck won't engage. #9
It also takes a large draw of amps to pull in the coil. If your battery is weak it will not go.
/ 318 mowing deck won't engage. #10
Wayne
The clutch on my 318 engages when cold, but after mowing for a while it won't re-engage after being turned off then switched back on. Should the clutch be adjusted when cold or hot, or do I have a different problem?
/ 318 mowing deck won't engage. #11
I had the same problem. After many, many hours of searching, I gave up and took it to my local JD Dealer.
Diagnosis: Shorted wires due to mice feasting on same.
Turned out to be a much less expensive fix than I originally planned on.
Hope this helps.
/ 318 mowing deck won't engage. #12
If the clutch adjustment is the issue a good trick to get it going again is to jerk the hydostatic drive (bunny hop) with the switch engaged. That should get the clutch to grab. This should only be used if you really can't adjust the clutch. it is an easy job.
my dad used the trick almost half the summer before I noticed it and adjusted the clutch for him.
/ 318 mowing deck won't engage. #13
Yes, if it does not engage when hot, turn each of those nuts in 1/4 of a turn. Post the results here. If you really want to do it right, get your feeler gauge out and set the clearance at 0.018". It will fix it.
Regarding jerking the hydro to get it going.... Please don't offer to fix any of my stuff!!
When hot, the magnet does not seem quite as strong. This is a very common problem.
Wayne
/ 318 mowing deck won't engage. #15
Finally got a dry day here in the NW to try out the 318's clutch adjustment and it worked great! Always engaged at any RPM throughout the day and at any engine temperature.
It had been a few years since I had last checked it and was not surprised to have the .018 feeler gage slide easily into the slots. I adjusted the nuts about a 1/16 turn and found that to be to tight so I backed them off a hair and was just able to squeeze the gage in between the plates. So it didn't take much of an adjustment to make a big difference.
I had also installed a new battery (after 7 years) so the clutch might be getting more juice now, not sure if that was part of the fix.
2016 CATERPILLAR 259D SKID STEER (A64279)
2016 CATERPILLAR...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
Caterpillar 950/962G/IT62G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
HLA Attachments Loader Forks (A64119)
HLA Attachments...
