318 mowing deck won't engage.
   / 318 mowing deck won't engage. #1
BrianCanz
I have a 1993 318 lawn tractor. The battery voltage light is on. When I attempt to engage the deck the light goes out, but the deck will not engage. Any ideas?
   / 318 mowing deck won't engage. #2
Welcome to TBN:D
The clutch is electric, so if the voltage is low it won't engage. You need to test the battery and genny for voltage-do yo have a meter?
Thanks Kenny. It seems to start up with no problem so I figured the battery was fine. The batt seems to stay fully charged after running for a while. Your saying just a light drop in voltage may make the difference?
Thanks again
   / 318 mowing deck won't engage. #4
Have you tested the voltage going into the pto clutch?
there should be an electrical connector you can undo and
use a voltmeter to check for voltage there. while you have
it unplugged, you can put a good 12v source on those wires
to see if the clutch engages (while the tractor is off obviously)
   / 318 mowing deck won't engage. #5
Sounds like a wire thats shorting out an causing a drain.chase wire an youll find something going to ground.
Army Grunt
   / 318 mowing deck won't engage. #6
I has a similar issue with my 332 a few years ago. In my case it was the connector leading to the PTO clutch.
   / 318 mowing deck won't engage. #7
It may be a short but then you'd find a blown fuse if there is one in the circuit.
Get a multi-meter and check zero resistance from the PTO clutch coil winding connector back to the engage switch source looking for a broken wire or a dirty connector. Also, unplug the PTO connector to the clutch and ohm out the winding to see if its open. It should read very low ohms.
If all is good, switch the meter to voltage and meter for 12 volts from switch to the PTO connector remembering the "close" all interlocks, ie; seat switch, etc.
   / 318 mowing deck won't engage. #8
If it has voltage and does not engage, it may need adjusting. There are three nuts that adjust the clearance of the clutch when not engaged, if it is too much the magnet won't draw it in. Set the clearance to 0.018", there is three inspection slots to do this. These clutches are reliable as can be, but if that clearance is out of spec it won't engage. It is one of the most common problems with those units.
Wayne
   / 318 mowing deck won't engage. #9
It also takes a large draw of amps to pull in the coil. If your battery is weak it will not go.
   / 318 mowing deck won't engage. #10
Wayne
The clutch on my 318 engages when cold, but after mowing for a while it won't re-engage after being turned off then switched back on. Should the clutch be adjusted when cold or hot, or do I have a different problem?
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2013 CAT 246C (A47477)
